[petsc-users] PCFIELDSPLIT question
Hom Nath Gharti hng.email at gmail.com
Thu Feb 11 11:47:14 CST 2016
Thanks all. With further help from Stefano Zhampini I was able to
solve my small test case using PCFieldSPlit option. I had to add
call PCSetType(pc,PCFIELDSPLIT,ierr)
Now I am trying to use same technique in my actual problem and got the error:
PETSC ERROR: Fields must be sorted when creating split
Does this mean I have to sort the global matrix rows according the split fields?
Thanks
Hom Nath
On Tue, Feb 9, 2016 at 10:57 AM, Hom Nath Gharti <hng.email at gmail.com> wrote:
> Sounds interesting! Thanks a lot Matt! I will have a look.
> Hom Nath
> On Tue, Feb 9, 2016 at 10:36 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Feb 9, 2016 at 9:31 AM, Hom Nath Gharti <hng.email at gmail.com> wrote:
>>> Thanks a lot Matt!
>>> Were you referring to
>>> http://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex62.c.html
>>> I do not see any statements related to PCFieldSplit there. Am I
>>> missing something here?
>> Yes. The whole point is not to put anything specific to FIELDSPLIT in the
>> code. It is all in options. For example,
>>   ./ex62 -run_type full -refinement_limit 0.00625 -bc_type dirichlet
>> -interpolate 1 -vel_petscspace_order 2 -pres_petscspace_order 1 -ksp_type
>> fgmres -ksp_gmres_restart 100 -ksp_rtol 1.0e-9 -pc_type fieldsplit
>> -pc_fieldsplit_type schur -pc_fieldsplit_schur_factorization_type upper
>> -fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_velocity_ksp_type gmres
>> -fieldsplit_velocity_pc_type lu -fieldsplit_pressure_pc_type jacobi
>> -snes_monitor_short -ksp_monitor_short -snes_converged_reason
>> -ksp_converged_reason -snes_view -show_solution 0
>> The reason that it works is that the DM calls PCFIeldSplitSetIS() for each
>> field in the DM.
>>   Thanks,
>>     Matt
>>> Thanks,
>>> Hom Nath
>>> On Tue, Feb 9, 2016 at 10:19 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> > On Tue, Feb 9, 2016 at 9:10 AM, Hom Nath Gharti <hng.email at gmail.com>
>>> > wrote:
>>> >> Thank you so much Barry!
>>> >> For my small test case, with -pc_fieldsplit_block_size 4, the program
>>> >> runs, although the answer was not correct. At least now I get
>>> >> something to look upon. I am using PCFieldSplitSetIS to set the
>>> >> fields. Do I still need to use -pc_fieldsplit_block_size?
>>> > No, this is only for co-located discretizations.
>>> >> In my case each grid point may have different variable sets. For
>>> >> example, the grid point in the solid region has displacement and
>>> >> gravity potential: ux, uy, uz, and \phi. Whereas the grid point in the
>>> >> fluid region has scalar potential, pressure and gravity potential:
>>> >> \chi, p, and \phi. And the solid-fluid interface has all of them. Do
>>> >> you think I can still use PCFIELDSPLIT in this situation?
>>> > We have examples, like SNES ex62, which do exactly this.
>>> >   Thanks,
>>> >     Matt
>>> >> Best,
>>> >> Hom Nath
>>> >> On Mon, Feb 8, 2016 at 2:27 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> >> >    In this case you need to provide two pieces of information to the
>>> >> > PCFIELDSPLIT. What we call the "block size" or bs which is the number
>>> >> > of
>>> >> > "basic fields" in the problem. For example if at each grid point you
>>> >> > have
>>> >> > x-velocity, y-velocity, and pressure the block size is 3. The second
>>> >> > is you
>>> >> > need to tell PCFIELDSPLIT what "basic fields" are in each split you
>>> >> > want to
>>> >> > use.
>>> >> >    In your case you can do this with -pc_fieldsplit_block_size 4.
>>> >> > (Note if you use a DM to define your problem the PCFIELDSPLIT will
>>> >> > automatically get the bs from the DM so you do not need to provide
>>> >> > it.
>>> >> > Similarly if you set a block size on your Mat the PCFIELDSPLIT will
>>> >> > use that
>>> >> > so you don't need to set it).
>>> >> >    Then use -pc_fieldsplit_0_fields 0,1 to indicate your first split
>>> >> > is
>>> >> > the 0 and 1 basic fields and -pc_fieldsplit_1_fields 2,3 to indicate
>>> >> > the
>>> >> > second split is the 2 and 3 basic fields.
>>> >> > (By default if you do not provide this then PCFIELDSPLIT will use bs
>>> >> > splits (4 in your case) one for each basic field.
>>> >> >    Barry
>>> >> >> On Feb 8, 2016, at 11:20 AM, Hom Nath Gharti <hng.email at gmail.com>
>>> >> >> wrote:
>>> >> >> Hi Matt, Hi all,
>>> >> >> I am trying to have some feel for PCFIELDSPLIT testing on a very
>>> >> >> small
>>> >> >> matrix (attached below). I have 4 degrees of freedoms. I use 4
>>> >> >> processors. I want to split 4 dofs into two fields each having two
>>> >> >> dofs. I don't know whether this my be a problem for petsc. When I
>>> >> >> use
>>> >> >> the command:
>>> >> >> srun -n 4 ./xtestfs -ksp_monitor -ksp_view
>>> >> >> It runs fine.
>>> >> >> But when I want to use field split options using the command:
>>> >> >> srun -n 4 ./xtestfs -ksp_monitor -ksp_type fgmres -pc_type
>>> >> >> fieldsplit
>>> >> >> -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type bjacobi
>>> >> >> -fieldsplit_1_pc_type jacobi
>>> >> >> I get the following error message:
>>> >> >> [0]PETSC ERROR: Petsc has generated inconsistent data
>>> >> >> [0]PETSC ERROR: Unhandled case, must have at least two fields, not 1
>>> >> >> [0]PETSC ERROR: See
>>> >> >> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>> >> >> shooting.
>>> >> >> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>>> >> >> [0]PETSC ERROR: /tigress/hgharti/test/testfs/./xtestfs on a
>>> >> >> arch-linux2-c-debug named tiger-r11n1 by hgharti Mon Feb  8 11:40:03
>>> >> >> 2016
>>> >> >> [0]PETSC ERROR: Configure options
>>> >> >> --with-blas-lapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64/
>>> >> >> --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
>>> >> >> --with-mpiexec=mpiexec --with-debugging=1 --download-scalapack
>>> >> >> --download-mumps --download-pastix --download-superlu
>>> >> >> --download-superlu_dist --download-metis --download-parmetis
>>> >> >> --download-ptscotch --download-hypre
>>> >> >> [0]PETSC ERROR: #1 PCFieldSplitSetDefaults() line 469 in
>>> >> >> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>> >> >> [0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 486 in
>>> >> >> [0]PETSC ERROR: #3 PCSetUp() line 983 in
>>> >> >> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/interface/precon.c
>>> >> >> [0]PETSC ERROR: #4 KSPSetUp() line 332 in
>>> >> >> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/ksp/interface/itfunc.c
>>> >> >> [0]PETSC ERROR: #5 KSPSolve() line 546 in
>>> >> >> WARNING! There are options you set that were not used!
>>> >> >> WARNING! could be spelling mistake, etc!
>>> >> >> Option left: name:-fieldsplit_0_ksp_type value: gmres
>>> >> >> Option left: name:-fieldsplit_0_pc_type value: bjacobi
>>> >> >> Option left: name:-fieldsplit_1_pc_type value: jacobi
>>> >> >> forrtl: error (76): Abort trap signal
>>> >> >> I tried several trials but could not fix the problem. Is it the
>>> >> >> FORTRAN problem or am I doing something wrong? Any suggestions would
>>> >> >> be greatly appreciated.
>>> >> >> For your information I use:
>>> >> >> PETSc-3.6.3
>>> >> >> intel-16.0 compiler
>>> >> >> intel-mpi-5.1.1
>>> >> >> Program
>>> >> >> Best,
>>> >> >> Hom Nath
>>> >> >> ! simple test case for PCFIELDSPLIT
>>> >> >> program testfs
>>> >> >> implicit none
>>> >> >> #include "petsc/finclude/petscsys.h"
>>> >> >> #include "petsc/finclude/petscvec.h"
>>> >> >> #include "petsc/finclude/petscvec.h90"
>>> >> >> #include "petsc/finclude/petscmat.h"
>>> >> >> #include "petsc/finclude/petscksp.h"
>>> >> >> #include "petsc/finclude/petscpc.h"
>>> >> >> #include "petsc/finclude/petscviewer.h"
>>> >> >> #include "petsc/finclude/petscviewer.h90"
>>> >> >> Vec              x,b,u
>>> >> >> Mat              A
>>> >> >> KSP              ksp
>>> >> >> PC               pc
>>> >> >> PetscErrorCode   ierr
>>> >> >> PetscBool        flg
>>> >> >> PetscInt         errcode,its,maxitr,myrank,nproc
>>> >> >> PetscInt         nedof,nelmt,ndof,nenod,ngdof,fixdof,nsparse,neq
>>> >> >> PetscInt,allocatable  :: krow_sparse(:),ggdof_elmt(:,:),           &
>>> >> >> inode_elmt(:,:)
>>> >> >> PetscReal,allocatable :: storef(:,:),storekmat(:,:,:)
>>> >> >> PetscInt gdof0(2),gdof1(2)
>>> >> >> ! initialize MPI
>>> >> >> call MPI_INIT(errcode)
>>> >> >> if(errcode /= 0)stop 'ERROR: cannot initialize MPI!'
>>> >> >> call MPI_COMM_RANK(MPI_COMM_WORLD,myrank,errcode)
>>> >> >> if(errcode /= 0)stop 'ERROR: cannot find processor ID'
>>> >> >> call MPI_COMM_SIZE(MPI_COMM_WORLD,nproc,errcode)
>>> >> >> if(errcode /= 0)stop 'ERROR: cannot find number of processors!'
>>> >> >> ! define some parameters
>>> >> >> ! 1D model with 4 elements. Each elements consits of 2 nodes. Node 0
>>> >> >> is
>>> >> >> fixed.
>>> >> >> ! 1-----------2-----------3-----------4-----------5
>>> >> >> nelmt=1 ! per processor
>>> >> >> nenod=2 ! number of nodes per element
>>> >> >> nedof=2 ! number of DOFs per element
>>> >> >> ndof=2  ! number of DOFs
>>> >> >> ngdof=4 ! total number of global DOFs
>>> >> >> fixdof=1
>>> >> >> if(myrank==0)then
>>> >> >>  neq=1 ! number of equations
>>> >> >>  nsparse=1
>>> >> >> else
>>> >> >>  neq=2 ! number of equations
>>> >> >>  nsparse=4
>>> >> >> endif
>>> >> >> allocate(storef(nedof,nelmt),storekmat(nedof,nedof,nelmt),
>>> >> >> ggdof_elmt(nedof,nelmt),inode_elmt(nenod,nelmt),krow_sparse(nsparse))
>>> >> >> storef=0.0_8 ! local RHS vector
>>> >> >> storekmat=0.0_8 ! local stiffness matrix
>>> >> >> if(myrank==0)then
>>> >> >>  krow_sparse(:)=1
>>> >> >>  storef(:,1)=(/12.5000_8, 12.5000_8/)
>>> >> >>  storekmat(:,:,1) = reshape((/1.2333333332_8, 0.0166666667_8, &
>>> >> >>                               0.0166666667_8,
>>> >> >> 1.2333333332_8/),(/nedof,nedof/))
>>> >> >>  inode_elmt(:,1)  = (/1,2/)
>>> >> >>  ggdof_elmt(:,1)  = (/0,1/) ! 0 because left node is fixed
>>> >> >> elseif(myrank==1)then
>>> >> >>  krow_sparse(:)=(/1,1,2,2/)
>>> >> >>                               0.0166666667_8,
>>> >> >>  ggdof_elmt(:,1)  = (/1,2/)
>>> >> >> elseif(myrank==2)then
>>> >> >>                               0.0166666667_8,
>>> >> >>  ggdof_elmt(:,1)  = (/2,3/)
>>> >> >> elseif(myrank==3)then
>>> >> >>  storef(:,1)=(/12.5000_8, 22.5000_8/)
>>> >> >>                               0.0166666667_8,
>>> >> >>  ggdof_elmt(:,1)  = (/3,4/)
>>> >> >> endif
>>> >> >> call petsc_initialize
>>> >> >> call petsc_set_matrix
>>> >> >> call petsc_set_vector
>>> >> >> call petsc_solve
>>> >> >> call petsc_finalize
>>> >> >> ! deallocate
>>> >> >> deallocate(storef,storekmat,ggdof_elmt,inode_elmt)
>>> >> >> deallocate(krow_sparse)
>>> >> >> contains
>>> >> >> subroutine petsc_initialize()
>>> >> >> implicit none
>>> >> >> PetscInt :: istart,iend
>>> >> >> PetscInt :: nzeros_max,nzeros_min
>>> >> >> PetscReal :: atol,dtol,rtol
>>> >> >> PetscInt,allocatable :: nzeros(:)
>>> >> >> IS gdof0_is,gdof1_is
>>> >> >> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>> >> >> call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-n',ngdof,flg,ierr)
>>> >> >> ! count number of nonzeros per row
>>> >> >> allocate(nzeros(neq))
>>> >> >> nzeros=0
>>> >> >> nzeros(krow_sparse)=nzeros(krow_sparse)+1
>>> >> >> nzeros_max=maxval(nzeros)
>>> >> >> nzeros_min=minval(nzeros)
>>> >> >> ! create matrix
>>> >> >> call MatCreate(PETSC_COMM_WORLD,A,ierr)
>>> >> >> call MatSetType(A,MATMPIAIJ,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,ngdof,ngdof,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> ! preallocation
>>> >> >> call
>>> >> >> MatMPIAIJSetPreallocation(A,nzeros_max,PETSC_NULL_INTEGER,nzeros_max,     &
>>> >> >> PETSC_NULL_INTEGER,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> call MatGetOwnershipRange(A,istart,iend,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> print*,'ownership:',myrank,istart,iend
>>> >> >> ! create vector
>>> >> >> call VecCreate(PETSC_COMM_WORLD,x,ierr)
>>> >> >> call VecSetSizes(x,PETSC_DECIDE,ngdof,ierr)
>>> >> >> call VecSetType(x,VECMPI,ierr)
>>> >> >> call VecDuplicate(x,b,ierr)
>>> >> >> call VecDuplicate(x,u,ierr)
>>> >> >> ! get IS for split fields
>>> >> >> gdof0=(/0,1/)
>>> >> >> gdof1=(/2,3/)
>>> >> >> call
>>> >> >> ISCreateGeneral(PETSC_COMM_WORLD,2,gdof0,PETSC_COPY_VALUES,gdof0_is,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> call
>>> >> >> ISCreateGeneral(PETSC_COMM_WORLD,2,gdof1,PETSC_COPY_VALUES,gdof1_is,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> ! Create linear solver context
>>> >> >> call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>>> >> >> call KSPSetOperators(ksp,A,A,ierr)
>>> >> >> call KSPGetPC(ksp,pc,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> ! split PC
>>> >> >> call PCFieldSplitSetIS(pc,"0",gdof0_is,ierr);
>>> >> >> CHKERRQ(ierr)
>>> >> >> call ISDestroy(gdof0_is,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> call PCFieldSplitSetIS(pc,"1",gdof1_is,ierr);
>>> >> >> CHKERRQ(ierr)
>>> >> >> call ISDestroy(gdof1_is,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> rtol = 1.0d-6
>>> >> >> atol = 1.0d-6
>>> >> >> dtol = 1.0d10
>>> >> >> maxitr = 1000
>>> >> >> call KSPSetTolerances(ksp,rtol,atol,dtol,maxitr,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> call KSPSetFromOptions(ksp,ierr)
>>> >> >> end subroutine petsc_initialize
>>> >> >> subroutine petsc_set_matrix()
>>> >> >> implicit none
>>> >> >> integer :: i,i_elmt,j,ncount
>>> >> >> integer :: ggdof(NEDOF),idof(NEDOF),igdof(NEDOF)
>>> >> >> ! Set and assemble matrix.
>>> >> >> call MatZeroEntries(A,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> do i_elmt=1,nelmt
>>> >> >>  ggdof(:)=ggdof_elmt(:,i_elmt)
>>> >> >>  ggdof(:)=ggdof(:)-1 ! petsc index starts from 0
>>> >> >>  ncount=0; idof=-1; igdof=-1
>>> >> >>  do i=1,NEDOF
>>> >> >>    do j=1,NEDOF
>>> >> >>    if(ggdof(i).ge.0.and.ggdof(j).ge.0)then
>>> >> >>      call
>>> >> >> MatSetValues(A,1,ggdof(i),1,ggdof(j),storekmat(i,j,i_elmt),
>>> >> >>      ADD_VALUES,ierr)
>>> >> >>      CHKERRQ(ierr)
>>> >> >>    endif
>>> >> >>    enddo
>>> >> >>  enddo
>>> >> >> enddo
>>> >> >> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>>> >> >> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>>> >> >> if(myrank==0)print*,'matrix setting & assembly complete!'
>>> >> >> end subroutine petsc_set_matrix
>>> >> >> subroutine petsc_set_vector()
>>> >> >> implicit none
>>> >> >> PetscScalar      zero
>>> >> >> integer :: i,i_elmt,ncount
>>> >> >> ! set vector
>>> >> >> zero=0.0_8
>>> >> >> call VecSet(b,zero,ierr)
>>> >> >> do i_elmt=1,nelmt
>>> >> >>  do i=1,NEDOF
>>> >> >>    if(ggdof(i).ge.0)then
>>> >> >>      call
>>> >> >> VecSetValues(b,1,ggdof(i),storef(i,i_elmt),ADD_VALUES,ierr);
>>> >> >>      CHKERRQ(ierr)
>>> >> >>    endif
>>> >> >>  enddo
>>> >> >> enddo
>>> >> >> ! assemble vector
>>> >> >> call VecAssemblyBegin(b,ierr)
>>> >> >> call VecAssemblyEnd(b,ierr)
>>> >> >> if(myrank==0)print*,'vector setting & assembly complete!'
>>> >> >> end subroutine petsc_set_vector
>>> >> >> subroutine petsc_solve()
>>> >> >> implicit none
>>> >> >> PetscInt ireason
>>> >> >> PetscScalar a_v(1)
>>> >> >> PetscOffset a_i
>>> >> >> PetscInt n
>>> >> >> PetscReal,allocatable :: sdata(:)
>>> >> >> call VecGetSize(b,n,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> allocate(sdata(n))
>>> >> >> sdata=0.0_8
>>> >> >> call VecGetArray(b,a_v,a_i,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> sdata(1:n)=a_v(a_i+1:a_i+n)
>>> >> >> call VecRestoreArray(b,a_v,a_i,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> print*,'rhs:',sdata
>>> >> >> call KSPSolve(ksp,b,x,ierr)
>>> >> >> sdata=0.0_8
>>> >> >> call VecGetArray(x,a_v,a_i,ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> print*,'solution:',sdata
>>> >> >> ! Check convergence
>>> >> >> call KSPGetConvergedReason(ksp,ireason,ierr)
>>> >> >> if(myrank==0)print*,'converges reason',myrank,ireason
>>> >> >> call KSPGetIterationNumber(ksp,its,ierr)
>>> >> >> if(myrank==0)print*,'Iterations:',its
>>> >> >> deallocate(sdata)
>>> >> >> end subroutine petsc_solve
>>> >> >> subroutine petsc_finalize()
>>> >> >> implicit none
>>> >> >> ! Free work space.
>>> >> >> call VecDestroy(x,ierr)
>>> >> >> call VecDestroy(u,ierr)
>>> >> >> call VecDestroy(b,ierr)
>>> >> >> call MatDestroy(A,ierr)
>>> >> >> call KSPDestroy(ksp,ierr)
>>> >> >> call PetscFinalize(ierr)
>>> >> >> CHKERRQ(ierr)
>>> >> >> end subroutine petsc_finalize
>>> >> >> end program testfs
>>> >> >> On Tue, Feb 2, 2016 at 4:54 PM, Matthew Knepley <knepley at gmail.com>
>>> >> >> wrote:
>>> >> >>> On Tue, Feb 2, 2016 at 3:11 PM, Hom Nath Gharti
>>> >> >>> wrote:
>>> >> >>>> Thanks a lot. I will try.
>>> >> >>> Also, if you send a small test case, we can run it and tell you the
>>> >> >>> problem.
>>> >> >>>  Matt
>>> >> >>>> Hom Nath
>>> >> >>>> On Tue, Feb 2, 2016 at 4:02 PM, Matthew Knepley
>>> >> >>>> wrote:
>>> >> >>>>> On Tue, Feb 2, 2016 at 3:01 PM, Hom Nath Gharti
>>> >> >>>>> wrote:
>>> >> >>>>>> Thanks again Matt. Unfortunately got the same errors with '0'. I
>>> >> >>>>>> think
>>> >> >>>>>> both are valid in Fortran.
>>> >> >>>>> Then you will have to go in the debugger and see why its not
>>> >> >>>>> creating 4
>>> >> >>>>> splits, since this is exactly
>>> >> >>>>> what it does in our tests. This is how all the SNES tests that I
>>> >> >>>>> use
>>> >> >>>>> work. I
>>> >> >>>>> am sure its a Fortran
>>> >> >>>>> problem.
>>> >> >>>>>  Thanks,
>>> >> >>>>>     Matt
>>> >> >>>>>> Hom Nath
>>> >> >>>>>> On Tue, Feb 2, 2016 at 3:42 PM, Matthew Knepley
>>> >> >>>>>> wrote:
>>> >> >>>>>>> On Tue, Feb 2, 2016 at 2:35 PM, Hom Nath Gharti
>>> >> >>>>>>> wrote:
>>> >> >>>>>>>> Thank you so much Matt.
>>> >> >>>>>>>> I now tried the following:
>>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"0",gdofu_is,ierr);
>>> >> >>>>>>>> call ISDestroy(gdofu_is,ierr)
>>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"1",gdofchi_is,ierr);
>>> >> >>>>>>>> call ISDestroy(gdofchi_is,ierr)
>>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"2",gdofp_is,ierr);
>>> >> >>>>>>>> call ISDestroy(gdofp_is,ierr)
>>> >> >>>>>>>> call PCFieldSplitSetIS(pc,"3",gdofphi_is,ierr);
>>> >> >>>>>>>> call ISDestroy(gdofphi_is,ierr)
>>> >> >>>>>>>> ! Amat changes in each time steps
>>> >> >>>>>>>> call KSPSetOperators(ksp,Amat,Amat,ierr) !version >= 3.5.0
>>> >> >>>>>>>> call KSPSolve(ksp,bvec,xvec,ierr)
>>> >> >>>>>>> I am guessing that "0" is not a valid string for your Fortran
>>> >> >>>>>>> compiler.
>>> >> >>>>>>> Are
>>> >> >>>>>>> you sure
>>> >> >>>>>>> its not single quotes '0'?
>>> >> >>>>>>>  Matt
>>> >> >>>>>>>> But I get the following error:
>>> >> >>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>> >> >>>>>>>> not 1
>>> >> >>>>>>>> [0]PETSC ERROR: See
>>> >> >>>>>>>> trouble
>>> >> >>>>>>>> shooting.
>>> >> >>>>>>>> [0]PETSC ERROR:
>>> >> >>>>>>>> /tigress/hgharti/gitwork/SPECFEM3D_GLOBEVSPP/./bin/xspecfem3D
>>> >> >>>>>>>> on
>>> >> >>>>>>>> a
>>> >> >>>>>>>> arch-linux2-c-debug named tiger-r3c1n7 by hgharti Tue Feb  2
>>> >> >>>>>>>> 15:
>>> >> >>>>>>>> 29:30 2016
>>> >> >>>>>>>> h-fc=mpif90 --with-mpiexec=mpiexec --with-debugging=1
>>> >> >>>>>>>> --download-scalapack --download-mumps --download-pastix
>>> >> >>>>>>>> --download-superlu --download-superlu_dist --download-metis
>>> >> >>>>>>>> --download-parmetis --download-ptscotch --download-hypre
>>> >> >>>>>>>> Am I missing something?
>>> >> >>>>>>>> Thanks,
>>> >> >>>>>>>> Hom Nath
>>> >> >>>>>>>> On Tue, Feb 2, 2016 at 3:24 PM, Matthew Knepley
>>> >> >>>>>>>> wrote:
>>> >> >>>>>>>>> On Tue, Feb 2, 2016 at 2:20 PM, Hom Nath Gharti
>>> >> >>>>>>>>> wrote:
>>> >> >>>>>>>>>> Hi Matt, hi all,
>>> >> >>>>>>>>>> I am trying to use PCFIELDSPLIT for my solver which consists
>>> >> >>>>>>>>>> of
>>> >> >>>>>>>>>> 4
>>> >> >>>>>>>>>> different variables, namely, u (displacement vector), \chi
>>> >> >>>>>>>>>> (displacement potential), p(pressure), and \phi (gravity
>>> >> >>>>>>>>>> potential).
>>> >> >>>>>>>>>> My code segment looks like the following:
>>> >> >>>>>>>>>> nsplit=4
>>> >> >>>>>>>>>> call PCFieldSplitSetBlockSize(pc,nsplit,ierr);
>>> >> >>>>>>>>> You do not need the statement above.
>>> >> >>>>>>>>>> call PCFieldSplitGetSubKSP(pc,nsplit,subksp,ierr);
>>> >> >>>>>>>>> These SetOperators() calls are wrong. I am not sure why you
>>> >> >>>>>>>>> want
>>> >> >>>>>>>>> them
>>> >> >>>>>>>>> here.
>>> >> >>>>>>>>> Also, that means you do not need the call above.
>>> >> >>>>>>>>>  Thanks,
>>> >> >>>>>>>>>     Matt
>>> >> >>>>>>>>>> call KSPSetOperators(subksp(1),Amat,Amat,ierr);
>>> >> >>>>>>>>>> call KSPSetOperators(subksp(2),Amat,Amat,ierr);
>>> >> >>>>>>>>>> call KSPSetOperators(subksp(3),Amat,Amat,ierr);
>>> >> >>>>>>>>>> call KSPSetOperators(subksp(4),Amat,Amat,ierr);
>>> >> >>>>>>>>>> But I am getting the following error:
>>> >> >>>>>>>>>> [79]PETSC ERROR: Null argument, when expecting valid pointer
>>> >> >>>>>>>>>> [79]PETSC ERROR: Null Object: Parameter # 1
>>> >> >>>>>>>>>> [79]PETSC ERROR: #1 KSPSetOperators() line 536 in
>>> >> >>>>>>>>>> It looks like I am doing something wrong in "call
>>> >> >>>>>>>>>> KSPSetOperators"
>>> >> >>>>>>>>>> but
>>> >> >>>>>>>>>> I could not figure that out.
>>> >> >>>>>>>>>> Could anybody help me to fix this problem? I looked into
>>> >> >>>>>>>>>> almost
>>> >> >>>>>>>>>> all
>>> >> >>>>>>>>>> related examples but I could not really figure out the
>>> >> >>>>>>>>>> correct
>>> >> >>>>>>>>>> steps
>>> >> >>>>>>>>>> after "call PCFieldSplitSetIS".
>>> >> >>>>>>>>>> Any help will be greatly appreciated.
>>> >> >>>>>>>>>> Best,
>>> >> >>>>>>>>>> Hom nath
>>> >> >>>>>>>>>> On Sun, Jan 24, 2016 at 7:14 PM, Hom Nath Gharti
>>> >> >>>>>>>>>> wrote:
>>> >> >>>>>>>>>>> Thank you so much Matt! I will try.
>>> >> >>>>>>>>>>> Hom Nath
>>> >> >>>>>>>>>>> On Sun, Jan 24, 2016 at 6:26 AM, Matthew Knepley
>>> >> >>>>>>>>>>> wrote:
>>> >> >>>>>>>>>>>> On Fri, Jan 22, 2016 at 2:19 PM, Hom Nath Gharti
>>> >> >>>>>>>>>>>> wrote:
>>> >> >>>>>>>>>>>>> Dear all,
>>> >> >>>>>>>>>>>>> I am new to PcFieldSplit.
>>> >> >>>>>>>>>>>>> I have a matrix formed using MATMPIAIJ. Is it possible to
>>> >> >>>>>>>>>>>>> use
>>> >> >>>>>>>>>>>>> PCFIELDSPLIT operations in this type of matrix? Or does
>>> >> >>>>>>>>>>>>> it
>>> >> >>>>>>>>>>>>> have
>>> >> >>>>>>>>>>>>> to
>>> >> >>>>>>>>>>>>> be
>>> >> >>>>>>>>>>>>> MATMPIBIJ or MATNEST format?
>>> >> >>>>>>>>>>>> Yes, you can split AIJ.
>>> >> >>>>>>>>>>>>> If possible for MATMPIAIJ, could anybody provide me a
>>> >> >>>>>>>>>>>>> simple
>>> >> >>>>>>>>>>>>> example
>>> >> >>>>>>>>>>>>> or few steps? Variables in the equations are displacement
>>> >> >>>>>>>>>>>>> vector,
>>> >> >>>>>>>>>>>>> scalar potential and pressure.
>>> >> >>>>>>>>>>>> If you do not have a collocated discretization, then you
>>> >> >>>>>>>>>>>> have
>>> >> >>>>>>>>>>>> to
>>> >> >>>>>>>>>>>> use
>>> >> >>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetIS.html
>>> >> >>>>>>>>>>>>  Thanks,
>>> >> >>>>>>>>>>>>     Matt
>>> >> >>>>>>>>>>>>> Thanks for help.
>>> >> >>>>>>>>>>>>> Hom Nath
>>> >> >>>>>>>>>>>> What most experimenters take for granted before they begin
>>> >> >>>>>>>>>>>> their
>>> >> >>>>>>>>>>>> experiments
>>> >> >>>>>>>>>>>> is infinitely more interesting than any results to which
>>> >> >>>>>>>>>>>> their
>>> >> >>>>>>>>>>>> experiments
>>> >> >>>>>>>>>>>> lead.
>>> >> >>>>>>>>>>>> -- Norbert Wiener
>>> >> >>>>>>>>> their
>>> >> >>>>>>>>> experiments
>>> >> >>>>>>>>> their
>>> >> >>>>>>>>> experiments
>>> >> >>>>>>>>> lead.
>>> >> >>>>>>>>> -- Norbert Wiener
>>> >> >>>>>>> their
>>> >> >>>>>>> experiments
>>> >> >>>>>>> is infinitely more interesting than any results to which their
>>> >> >>>>>>> experiments
>>> >> >>>>>>> lead.
>>> >> >>>>>>> -- Norbert Wiener
>>> >> >>>>> What most experimenters take for granted before they begin their
>>> >> >>>>> experiments
>>> >> >>>>> experiments
>>> >> >>>>> lead.
>>> >> >>>>> -- Norbert Wiener
>>> >> >>> experiments
>>> >> >>> experiments
>>> >> >>> lead.
>>> >> >>> -- Norbert Wiener
>>> > experiments
>>> > experiments
>>> > lead.
>>> > -- Norbert Wiener
>> What most experimenters take for granted before they begin their experiments
>> is infinitely more interesting than any results to which their experiments
>> lead.
>> -- Norbert Wiener
