[petsc-users] DIVERGED_PCSETUP_FAILED
Michele Rosso mrosso at uci.edu
Thu Feb 11 00:05:18 CST 2016
I tried setting -mat_superlu_dist_replacetinypivot true: it does help to
advance the run past the previous "critical"  point but eventually it
stops later with the same error.
I forgot to mention my system is singular: I remove the constant null
space but I am not sure if the coarse solver needs to be explicity
informed of this.
Michele
On Wed, 2016-02-10 at 22:15 -0600, Barry Smith wrote:
>    You can try the option
> if you are luck it get you past the zero pivot but still give an adequate preconditioner.
>   Barry
> > On Feb 10, 2016, at 9:49 PM, Michele Rosso <mrosso at uci.edu> wrote:
> > Hong,
> > here if the output of grep -info:
> >         using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
> >                   Replace tiny pivots FALSE
> >         tolerance for zero pivot 2.22045e-14
> > It seems it is not replacing small pivots: could this be the problem?
> > I will also try Barry's suggestion to diagnose the problem.
> > Thanks,
> > Michele
> > On Wed, 2016-02-10 at 21:22 -0600, Barry Smith wrote:
> >> > On Feb 10, 2016, at 9:00 PM, Hong <hzhang at mcs.anl.gov> wrote:
> >> > Michele :
> >> > Superlu_dist LU is used for coarse grid PC, which likely produces a zero-pivot.
> >> > Run your code with '-info |grep pivot' to  verify.
> >>   Michele
> >>    You can also run with -ksp_error_if_not_converged in or not in the debugger and it will stop immediately when the problem is detected and hopefully provide additional useful  information about what has happened.
> >>   Barry
> >> > Hong
> >> > Hi Matt,
> >> > the ksp_view output was an attachment to my previous email.
> >> > Here it is:
> >> > KSP Object: 1 MPI processes
> >> >   type: cg
> >> >   maximum iterations=10000
> >> >   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
> >> >   left preconditioning
> >> >   using nonzero initial guess
> >> >   using UNPRECONDITIONED norm type for convergence test
> >> > PC Object: 1 MPI processes
> >> >   type: mg
> >> >     MG: type is MULTIPLICATIVE, levels=4 cycles=v
> >> >       Cycles per PCApply=1
> >> >       Using Galerkin computed coarse grid matrices
> >> >   Coarse grid solver -- level -------------------------------
> >> >     KSP Object:    (mg_coarse_)     1 MPI processes
> >> >       type: preonly
> >> >       maximum iterations=1, initial guess is zero
> >> >       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
> >> >       using NONE norm type for convergence test
> >> >     PC Object:    (mg_coarse_)     1 MPI processes
> >> >       type: lu
> >> >         LU: out-of-place factorization
> >> >         matrix ordering: nd
> >> >         factor fill ratio given 0., needed 0.
> >> >           Factored matrix follows:
> >> >             Mat Object:             1 MPI processes
> >> >               type: seqaij
> >> >               rows=16, cols=16
> >> >               package used to perform factorization: superlu_dist
> >> >               total: nonzeros=0, allocated nonzeros=0
> >> >               total number of mallocs used during MatSetValues calls =0
> >> >                 SuperLU_DIST run parameters:
> >> >                   Process grid nprow 1 x npcol 1
> >> >                   Equilibrate matrix TRUE
> >> >                   Matrix input mode 0
> >> >                   Use iterative refinement FALSE
> >> >                   Processors in row 1 col partition 1
> >> >                   Row permutation LargeDiag
> >> >                   Column permutation METIS_AT_PLUS_A
> >> >                   Parallel symbolic factorization FALSE
> >> >                   Repeated factorization SamePattern
> >> >       linear system matrix = precond matrix:
> >> >         type: seqaij
> >> >         rows=16, cols=16
> >> >         total: nonzeros=72, allocated nonzeros=72
> >> >           not using I-node routines
> >> >   Down solver (pre-smoother) on level 1 -------------------------------
> >> >     KSP Object:    (mg_levels_1_)     1 MPI processes
> >> >       type: richardson
> >> >         Richardson: damping factor=1.
> >> >       maximum iterations=2
> >> >     PC Object:    (mg_levels_1_)     1 MPI processes
> >> >       type: sor
> >> >         SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.
> >> >         type: seqaij
> >> >         rows=64, cols=64
> >> >         total: nonzeros=304, allocated nonzeros=304
> >> >   Up solver (post-smoother) same as down solver (pre-smoother)
> >> >   Down solver (pre-smoother) on level 2 -------------------------------
> >> >     KSP Object:    (mg_levels_2_)     1 MPI processes
> >> >       type: richardson
> >> >     PC Object:    (mg_levels_2_)     1 MPI processes
> >> >       type: sor
> >> >         type: seqaij
> >> >         rows=256, cols=256
> >> >         total: nonzeros=1248, allocated nonzeros=1248
> >> >   Down solver (pre-smoother) on level 3 -------------------------------
> >> >     KSP Object:    (mg_levels_3_)     1 MPI processes
> >> >       type: richardson
> >> >     PC Object:    (mg_levels_3_)     1 MPI processes
> >> >       type: sor
> >> >         type: seqaij
> >> >         rows=1024, cols=1024
> >> >         total: nonzeros=5056, allocated nonzeros=5056
> >> >           has attached null space
> >> >     type: seqaij
> >> > Michele
> >> > On Wed, 2016-02-10 at 19:37 -0600, Matthew Knepley wrote:
> >> >> On Wed, Feb 10, 2016 at 7:33 PM, Michele Rosso <mrosso at uci.edu> wrote:
> >> >> Hi,
> >> >> I encountered the following error while solving a symmetric positive defined system:
> >> >> Linear solve did not converge due to DIVERGED_PCSETUP_FAILED iterations 0
> >> >>                PCSETUP_FAILED due to SUBPC_ERROR
> >> >> This error appears only if I use the  optimized version of both petsc and my code ( compiler: gfortran, flags: -O3 ).
> >> >> It is weird since I am solving  a time-dependent problem and everything, i.e. results and convergence rate, are as expected until the above error shows up. If I run both petsc and my code in debug mode, everything goes smooth till the end of the simulation.
> >> >> However, if I reduce the ksp_rtol, even the debug run fails, after running as expected for a while, because of a KSP_DIVERGED_INDEFINITE_PC .
> >> >> The options I am using are:
> >> >> -ksp_type        cg
> >> >> -ksp_norm_type   unpreconditioned
> >> >> -ksp_rtol        1e-8
> >> >> -ksp_lag_norm
> >> >> -ksp_initial_guess_nonzero  yes
> >> >> -pc_type mg
> >> >> -pc_mg_galerkin
> >> >> -pc_mg_levels 4
> >> >> -mg_levels_ksp_type richardson
> >> >> -mg_coarse_ksp_constant_null_space
> >> >> -mg_coarse_pc_type lu
> >> >> -mg_coarse_pc_factor_mat_solver_package superlu_dist
> >> >> -options_left
> >> >> I attached a copy of ksp_view. I am currently using petsc-master (last updated yesterday).
> >> >> I would appreciate any suggestion on this matter.
> >> >> I suspect you have a nonlinear PC. Can you send the output of -ksp_view?
> >> >>    Matt
> >> >> Thanks,
> >> >> Michele
> >> >> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> >> >> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160210/61d32c28/attachment-0001.html>
