[petsc-users] TS and snes_grid_sequence
Jed Brown jed at jedbrown.org
Wed Feb 10 19:43:32 CST 2016
Matthew Knepley <knepley at gmail.com> writes:
> On Wed, Feb 10, 2016 at 4:19 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Barry Smith <bsmith at mcs.anl.gov> writes:
>> >      We do not currently have library code to do grid sequence within a
>> time-step. I believe that providing this requires a great deal of
>> "replumbing" of the TS solvers to make them "grid sequence aware". This is
>> true I believe for both traditional grid sequencing and FAS (I would be
>> happy if Emil or Jed could prove me wrong).  There are seemingly multiple
>> ways to do the grid sequencing:
>> I'm pretty sure you could use TS solved by FAS when Peter and I were
>> working on it.  But my test just failed and it looks like some work
>> vectors aren't being obtained correctly.  I'm afraid I can't dig into it
>> right now.
> I use FAS with TS for the magma runs and it works.
The problem I encountered would only affect the case where you have both
an IFunction and an RHSFunction with a fully implicit method.
Thanks for the report that it works otherwise.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160210/76c4b148/attachment.pgp>
