[petsc-users] TS and snes_grid_sequence
Emil Constantinescu emconsta at mcs.anl.gov
Wed Feb 10 19:13:01 CST 2016
Francesco,
It could be a problem of ODE stability, error control, nonlinear solver
(cold start), etc.
In addition to what's been recommended, I would suggest trying a
different integrator with better properties: try
-ts_type arkimex -ts_arkimex_type 2e -ts_arkimex_fully_implicit
In case it's a cold-start problem, arkimex methods can provide warmer
guesses: to do that try adding
-ts_arkimex_initial_guess_extrapolate
To take off the error controller, use -ts_adapt_type none
This should take care of the common things.
Emil
On 2/10/16 6:33 PM, Francesco Magaletti wrote:
> First of all thank you everybody for the fast replies.
> Barry,
> I think the solution 1 is a good suggestion but I confess I’m a bit scared of going deep into the modification of the ODE integrator.
> I’m now using TSCN, the classical Crank-Nicolson 2nd order full implicit time integration. Maybe I can try to implement your solution
> together with BEULER, as suggested by Hong.
> By the way the solution changes rapidly, but not so fast to justify that small timestep value. The space variation instead are really fast and this is the reason why I need so many grid points.
> Jed,
> I hope you could solve soon the problem with the FAS scheme.
> Thank you again
> Francesco
