[petsc-users] log_summary time ratio and flops ratio
Xiangdong epscodes at gmail.com
Wed Feb 10 08:12:14 CST 2016
On Mon, Feb 8, 2016 at 6:45 PM, Jed Brown <jed at jedbrown.org> wrote:
> Xiangdong <epscodes at gmail.com> writes:
> > iii) since the time ratios of VecDot (2.5) and MatMult (1.5) are still
> > high, I rerun the program with ipm module. The IPM summary is here:
> https://drive.google.com/file/d/0BxEfb1tasJxhYXI0VkV0cjlLWUU/view?usp=sharing
> > From this IPM reuslts, MPI_Allreduce takes 74% of MPI time. The
> > communication by task figure (1st figure in p4) in above link showed that
> > it is not well-balanced. Is this related to the hardware and network
> (which
> > the users cannot control) or can I do something on my codes to improve?
> Here are a few functions that don't have any communication, but still
> have significant load imbalance.
>   VecAXPY          1021815 1.0 2.2148e+01 2.1 1.89e+10 1.1 0.0e+00 0.0e+00
> 0.0e+00  2  4  0  0  0   2  4  0  0  0 207057
>   VecMAXPY          613089 1.0 1.3276e+01 2.2 2.27e+10 1.1 0.0e+00 0.0e+00
> 0.0e+00  1  4  0  0  0   1  4  0  0  0 414499
>   MatSOR            818390 1.0 1.9608e+02 1.5 2.00e+11 1.1 0.0e+00 0.0e+00
> 0.0e+00 22 40  0  0  0  22 40  0  0  0 247472
The result above is from a run with 256 cores (16 nodes * 16 cores/node). I
did another run with 64 nodes * 4 cores/node. Now these functions are much
better balanced ( a factor of 1.2-1.3, instead of 1.5-2.1).
VecAXPY           987215 1.0 6.8469e+00 1.3 1.82e+10 1.1 0.0e+00 0.0e+00
0.0e+00  1  4  0  0  0   1  4  0  0  0 647096
VecMAXPY          592329 1.0 6.0866e+00 1.3 2.19e+10 1.1 0.0e+00 0.0e+00
0.0e+00  1  4  0  0  0   1  4  0  0  0 873511
MatSOR            790717 1.0 1.2933e+02 1.2 1.93e+11 1.1 0.0e+00 0.0e+00
0.0e+00 24 40  0  0  0  24 40  0  0  0 362525
For the functions requires communication, the time ratio is about (1.4-1.6)
VecDot            789772 1.0 8.4804e+01 1.4 1.46e+10 1.1 0.0e+00 0.0e+00
7.9e+05 14  3  0  0 40  14  3  0  0 40 41794
VecNorm           597914 1.0 7.6259e+01 1.6 1.10e+10 1.1 0.0e+00 0.0e+00
6.0e+05 12  2  0  0 30  12  2  0  0 30 34996
The full logsummary for this new run is here:
https://googledrive.com/host/0BxEfb1tasJxhVkZ2NHJkSmF4LUU
Can we say now the load imbalance is from the network communication,
instead of memory bandwidth?
Thanks.
Xiangdong
You can and should improve load balance before stressing about network
> costs.  This could be that the nodes aren't clean (running at different
> speeds) or that the partition is not balancing data.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160210/2a1e7a86/attachment.html>
