[petsc-users] Different results with different distribution of rows
Tue Feb 9 08:00:54 CST 2016
On Tue, Feb 9, 2016 at 7:06 AM, Florian Lindner <mailinglists at xgm.de> wrote:
> Hello,
> I use PETSc with 4 MPI processes and I experience different results
> when using different distribution of rows amoung ranks. The code looks
> like that:
The default PC is BJacobi/ILU. This depends on the parallel layout because
each
subdomain block is approximately factored. ILU is not very reliable, so it
can fail
as you see below. If you change to LU, you will see the problem
  -sub_pc_type lu
     Matt
> KSPSetOperators(_solver, _matrixC.matrix, _matrixC.matrix);
> // _solverRtol = 1e-9
> KSPSetTolerances(_solver, _solverRtol, PETSC_DEFAULT, PETSC_DEFAULT,
> PETSC_DEFAULT);
> KSPSetFromOptions(_solver);
> // means: MatGetVecs(matrix, nullptr, &vector);
> petsc::Vector Au(_matrixC, "Au");
> petsc::Vector out(_matrixC, "out");
> petsc::Vector in(_matrixA, "in");
> // is an identity mapping here
> ierr = VecSetLocalToGlobalMapping(in.vector, _ISmapping);
> // fill and assemble vector in
> in.view();
> MatMultTranspose(_matrixA.matrix, in.vector, Au.vector);
> Au.view();
> KSPSolve(_solver, Au.vector, out.vector);
> out.view();
> I have experimented with two variants. The first one, non-working has
> MatrixC rows distributed like that: 3, 4, 2, 2. The other, working, one
> has 4, 3, 2, 2.
> All input values: _matrixA, _matrixC, in are identival, Au is identical
> too, but out differs. See the results from object::view below.
> Could the bad condition of matrixC be a problem? I'm not using any
> special KSP options. matrixC is of type MATSBAIJ, matrixA is MATAIJ.
> Thanks,
> Florian
> WRONG
> Vec Object:in 4 MPI processes
>   type: mpi
> Process [0]
> 1
> 2
> Process [1]
> 3
> 4
> Process [2]
> 5
> 6
> Process [3]
> 7
> 8
> Vec Object:Au 4 MPI processes
>   type: mpi
> Process [0]
> 36
> 74
> 20
> Process [1]
> 1.09292
> 2.09259
> 3.18584
> 4.20349
> Process [2]
> 5.29708
> 6.31472
> Process [3]
> 7.24012
> 8.23978
> // should not be result
> Vec Object:out 4 MPI processes
>   type: mpi
> Process [0]
> -1.10633e+07
> 618058
> 9.01497e+06
> Process [1]
> 0.996195
> 1.98711
> 3.01111
> 4.00203
> Process [2]
> 5.00736
> 6.01644
> Process [3]
> 6.98534
> 7.99442
> Mat Object:C 4 MPI processes
>   type: mpisbaij
> row 0: (0, 0)  (3, 1)  (4, 1)  (5, 1)  (6, 1)  (7, 1)  (8, 1)  (9, 1)
> (10, 1)
> row 1: (1, 0)  (3, 0)  (4, 0)  (5, 1)  (6, 1)  (7, 2)  (8, 2)  (9, 3)
> (10, 3)
> row 2: (2, 0)  (3, 0)  (4, 1)  (5, 0)  (6, 1)  (7, 0)  (8, 1)  (9, 0)
> (10, 1)
> row 3: (3, 1)  (4, 0.0183156)  (5, 0.0183156)  (6, 0.000335463)  (7,
> 1.12535e-07)  (8, 2.06115e-09)
> row 4: (4, 1)  (5, 0.000335463)  (6, 0.0183156)  (7, 2.06115e-09)  (8,
> 1.12535e-07)
> row 5: (5, 1)  (6, 0.0183156)  (7, 0.0183156)  (8, 0.000335463)  (9,
> 1.12535e-07)  (10, 2.06115e-09)
> row 6: (6, 1)  (7, 0.000335463)  (8, 0.0183156)  (9, 2.06115e-09)  (10,
> 1.12535e-07)
> row 7: (7, 1)  (8, 0.0183156)  (9, 0.0183156)  (10, 0.000335463)
> row 8: (8, 1)  (9, 0.000335463)  (10, 0.0183156)
> row 9: (9, 1)  (10, 0.0183156)
> row 10: (10, 1)
> Mat Object:A 4 MPI processes
>   type: mpiaij
>  1.00000e+00  0.00000e+00  0.00000e+00  1.00000e+00  1.83156e-02
> 1.83156e-02  3.35463e-04  1.12535e-07  2.06115e-09  0.00000e+00  0.00000e+00
>  1.00000e+00  0.00000e+00  1.00000e+00  1.83156e-02  1.00000e+00
> 3.35463e-04  1.83156e-02  2.06115e-09  1.12535e-07  0.00000e+00  0.00000e+00
>  1.00000e+00  1.00000e+00  0.00000e+00  1.83156e-02  3.35463e-04
> 1.00000e+00  1.83156e-02  1.83156e-02  3.35463e-04  1.12535e-07  2.06115e-09
>  1.00000e+00  1.00000e+00  1.00000e+00  3.35463e-04  1.83156e-02
> 1.83156e-02  1.00000e+00  3.35463e-04  1.83156e-02  2.06115e-09  1.12535e-07
>  1.00000e+00  2.00000e+00  0.00000e+00  1.12535e-07  2.06115e-09
> 1.83156e-02  3.35463e-04  1.00000e+00  1.83156e-02  1.83156e-02  3.35463e-04
>  1.00000e+00  2.00000e+00  1.00000e+00  2.06115e-09  1.12535e-07
> 3.35463e-04  1.83156e-02  1.83156e-02  1.00000e+00  3.35463e-04  1.83156e-02
>  1.00000e+00  3.00000e+00  0.00000e+00  0.00000e+00  0.00000e+00
> 1.12535e-07  2.06115e-09  1.83156e-02  3.35463e-04  1.00000e+00  1.83156e-02
>  1.00000e+00  3.00000e+00  1.00000e+00  0.00000e+00  0.00000e+00
> 2.06115e-09  1.12535e-07  3.35463e-04  1.83156e-02  1.83156e-02  1.00000e+00
> RIGHT
>   type: mpi
> Process [0]
> 1
> 2
> Process [1]
> 3
> 4
> Process [2]
> 5
> 6
> Process [3]
> 7
> 8
>   type: mpi
> Process [0]
> 36
> 74
> 20
> 1.09292
> Process [1]
> 2.09259
> 3.18584
> 4.20349
> Process [2]
> 5.29708
> 6.31472
> Process [3]
> 7.24012
> 8.23978
> // should be result
>   type: mpi
> Process [0]
> 0
> 0
> 0
> 1
> Process [1]
> 2
> 3
> 4
> Process [2]
> 5
> 6
> Process [3]
> 7
> 8
>   type: mpisbaij
> (10, 1)
> (10, 3)
> (10, 1)
> 1.12535e-07)
> 1.12535e-07)
> row 10: (10, 1)
>   type: mpiaij
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160209/f0def05b/attachment.html>
