[petsc-users] Different results with different distribution of rows
Florian Lindner mailinglists at xgm.de
Tue Feb 9 07:06:01 CST 2016
Hello,
I use PETSc with 4 MPI processes and I experience different results
when using different distribution of rows amoung ranks. The code looks
like that:
KSPSetOperators(_solver, _matrixC.matrix, _matrixC.matrix);
// _solverRtol = 1e-9
KSPSetTolerances(_solver, _solverRtol, PETSC_DEFAULT, PETSC_DEFAULT,
PETSC_DEFAULT);
KSPSetFromOptions(_solver);
// means: MatGetVecs(matrix, nullptr, &vector);
petsc::Vector Au(_matrixC, "Au");
petsc::Vector out(_matrixC, "out");
petsc::Vector in(_matrixA, "in");
// is an identity mapping here
ierr = VecSetLocalToGlobalMapping(in.vector, _ISmapping);
// fill and assemble vector in
in.view();
MatMultTranspose(_matrixA.matrix, in.vector, Au.vector);
Au.view();
KSPSolve(_solver, Au.vector, out.vector);
out.view();
I have experimented with two variants. The first one, non-working has
MatrixC rows distributed like that: 3, 4, 2, 2. The other, working, one
has 4, 3, 2, 2.
All input values: _matrixA, _matrixC, in are identival, Au is identical
too, but out differs. See the results from object::view below.
Could the bad condition of matrixC be a problem? I'm not using any
special KSP options. matrixC is of type MATSBAIJ, matrixA is MATAIJ.
Florian
WRONG
Vec Object:in 4 MPI processes
  type: mpi
Process [0]
1
2
Process [1]
3
4
Process [2]
5
6
Process [3]
7
8
Vec Object:Au 4 MPI processes
  type: mpi
Process [0]
36
74
20
Process [1]
1.09292
2.09259
3.18584
4.20349
Process [2]
5.29708
6.31472
Process [3]
7.24012
8.23978
// should not be result
Vec Object:out 4 MPI processes
  type: mpi
Process [0]
-1.10633e+07
618058
9.01497e+06
Process [1]
0.996195
1.98711
3.01111
4.00203
Process [2]
5.00736
6.01644
Process [3]
6.98534
7.99442
Mat Object:C 4 MPI processes
  type: mpisbaij
row 0: (0, 0)  (3, 1)  (4, 1)  (5, 1)  (6, 1)  (7, 1)  (8, 1)  (9, 1)  (10, 1)
row 1: (1, 0)  (3, 0)  (4, 0)  (5, 1)  (6, 1)  (7, 2)  (8, 2)  (9, 3)  (10, 3)
row 2: (2, 0)  (3, 0)  (4, 1)  (5, 0)  (6, 1)  (7, 0)  (8, 1)  (9, 0)  (10, 1)
row 3: (3, 1)  (4, 0.0183156)  (5, 0.0183156)  (6, 0.000335463)  (7, 1.12535e-07)  (8, 2.06115e-09)
row 4: (4, 1)  (5, 0.000335463)  (6, 0.0183156)  (7, 2.06115e-09)  (8, 1.12535e-07)
row 5: (5, 1)  (6, 0.0183156)  (7, 0.0183156)  (8, 0.000335463)  (9, 1.12535e-07)  (10, 2.06115e-09)
row 6: (6, 1)  (7, 0.000335463)  (8, 0.0183156)  (9, 2.06115e-09)  (10, 1.12535e-07)
row 7: (7, 1)  (8, 0.0183156)  (9, 0.0183156)  (10, 0.000335463)
row 8: (8, 1)  (9, 0.000335463)  (10, 0.0183156)
row 9: (9, 1)  (10, 0.0183156)
row 10: (10, 1)
Mat Object:A 4 MPI processes
  type: mpiaij
 1.00000e+00  0.00000e+00  0.00000e+00  1.00000e+00  1.83156e-02  1.83156e-02  3.35463e-04  1.12535e-07  2.06115e-09  0.00000e+00  0.00000e+00
 1.00000e+00  0.00000e+00  1.00000e+00  1.83156e-02  1.00000e+00  3.35463e-04  1.83156e-02  2.06115e-09  1.12535e-07  0.00000e+00  0.00000e+00
 1.00000e+00  1.00000e+00  0.00000e+00  1.83156e-02  3.35463e-04  1.00000e+00  1.83156e-02  1.83156e-02  3.35463e-04  1.12535e-07  2.06115e-09
 1.00000e+00  1.00000e+00  1.00000e+00  3.35463e-04  1.83156e-02  1.83156e-02  1.00000e+00  3.35463e-04  1.83156e-02  2.06115e-09  1.12535e-07
 1.00000e+00  2.00000e+00  0.00000e+00  1.12535e-07  2.06115e-09  1.83156e-02  3.35463e-04  1.00000e+00  1.83156e-02  1.83156e-02  3.35463e-04
 1.00000e+00  2.00000e+00  1.00000e+00  2.06115e-09  1.12535e-07  3.35463e-04  1.83156e-02  1.83156e-02  1.00000e+00  3.35463e-04  1.83156e-02
 1.00000e+00  3.00000e+00  0.00000e+00  0.00000e+00  0.00000e+00  1.12535e-07  2.06115e-09  1.83156e-02  3.35463e-04  1.00000e+00  1.83156e-02
 1.00000e+00  3.00000e+00  1.00000e+00  0.00000e+00  0.00000e+00  2.06115e-09  1.12535e-07  3.35463e-04  1.83156e-02  1.83156e-02  1.00000e+00
RIGHT
  type: mpi
Process [0]
1
2
Process [1]
3
4
Process [2]
5
6
Process [3]
7
8
  type: mpi
Process [0]
36
74
20
1.09292
Process [1]
2.09259
3.18584
4.20349
Process [2]
5.29708
6.31472
Process [3]
7.24012
8.23978
// should be result
  type: mpi
Process [0]
0
0
0
1
Process [1]
2
3
4
Process [2]
5
6
Process [3]
7
8
  type: mpisbaij
row 10: (10, 1)
  type: mpiaij
