[petsc-users] log_summary time ratio and flops ratio
Fri Feb 5 21:34:08 CST 2016
  Make the same run with no IO and see if the numbers are much better and if the load balance is better.
> On Feb 5, 2016, at 8:59 PM, Xiangdong <epscodes at gmail.com> wrote:
> If I want to know whether only rank 0 is slow (since it may has more io) or actually a portion of cores are slow, what tools can I start with?
> Thanks.
> Xiangdong
> On Fri, Feb 5, 2016 at 5:27 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> I attached the full summary. At the end, it has
> >> Average time to get PetscTime(): 0
> >> Average time for MPI_Barrier(): 8.3971e-05
> >> Average time for zero size MPI_Send(): 7.16746e-06
> >> Is it an indication of slow network?
> > I think so. It takes nearly 100 microseconds to synchronize processes.
> Edison with 65536 processes:
> Average time for MPI_Barrier(): 4.23908e-05
> Average time for zero size MPI_Send(): 2.46466e-06
> Mira with 16384 processes:
> Average time for MPI_Barrier(): 5.7075e-06
> Average time for zero size MPI_Send(): 1.33179e-05
> Titan with 131072 processes:
> Average time for MPI_Barrier(): 0.000368595
> Average time for zero size MPI_Send(): 1.71567e-05
