[petsc-users] log_summary time ratio and flops ratio
Fri Feb 5 16:05:53 CST 2016
On Fri, Feb 5, 2016 at 11:32 AM, Xiangdong <epscodes at gmail.com> wrote:
> On Fri, Feb 5, 2016 at 12:18 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Fri, Feb 5, 2016 at 11:12 AM, Xiangdong <epscodes at gmail.com> wrote:
>>> Hello everyone,
>>> When I looked at the log_summary, I found that flops ratio of VecDot is
>>> 1.1, but the time ratio is 1.8. Also the flops ratio of MatMult is 1.2, but
>>> the time ratio is 1.6. I am using the simple SOR preconditioner on 256
>>> procs. Since each of them consumes about 20% of total time, is it worth
>>> looking into these imbalance issue? If yes, how do I know which procs are
>>> causing the issue? What tools should I start with?
>> 1) Always send all the output
>> 2) You have a large number of dot products, and I am guessing you have a
>> slow reduce on this machine (we could see the data at the end of
>> log_summary).
>>      The waiting time comes from slow collective communication, load
>> imbalance, system noise, etc. You can see this by looking at the difference
>> between
>>      VecDot() and VecMDot(). For the latter there is enough work to cover
>> up the latency, and its imbalance is only 1.1, not 1.8. Thus I think it is
>> clear that your
>>      problem is due to a slow communication network rather than load
>> imbalance.
> I attached the full summary. At the end, it has
> Average time to get PetscTime(): 0
> Average time for MPI_Barrier(): 8.3971e-05
> Average time for zero size MPI_Send(): 7.16746e-06
> Is it an indication of slow network?
I think so. It takes nearly 100 microseconds to synchronize processes.
     Matt
>> 3) Thus you would be better served with a stronger preconditioner (more
>> flops) which resulted in fewer iterations (less synchronization).
> Yes, the preconditioner I am using is simple (just sor). I am also trying
> other advanced preconditioners.
>>   Thanks,
>>      Matt
>>> Thanks.
>>> Xiangdong
>>> Event                Count      Time (sec)     Flops
>>>         --- Global ---  --- Stage ---   Total
>>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
>>> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>>> --- Event Stage 0: Main Stage
>>> VecView               44 1.0 3.9026e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 4.8e+01  1  0  0  0  0   1  0  0  0  0     0
>>> VecDot            817452 1.0 1.5972e+02 1.8 1.51e+10 1.1 0.0e+00 0.0e+00
>>> 8.2e+05 18  3  0  0 40  18  3  0  0 40 22969
>>> VecMDot           613089 1.0 5.8918e+01 1.1 2.27e+10 1.1 0.0e+00 0.0e+00
>>> 6.1e+05  8  4  0  0 30   8  4  0  0 30 93397
>>> VecNorm           618619 1.0 1.4426e+02 2.2 1.14e+10 1.1 0.0e+00 0.0e+00
>>> 6.2e+05 15  2  0  0 30  15  2  0  0 30 19145
>>> VecScale             938 1.0 8.3907e-03 1.2 8.67e+06 1.1 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0 250859
>>> VecCopy             8159 1.0 1.0394e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>> VecSet              1884 1.0 3.9701e-02 2.1 0.00e+00 0.0 0.0e+00 0.0e+00
>>> VecAXPY          1021815 1.0 2.2148e+01 2.1 1.89e+10 1.1 0.0e+00 0.0e+00
>>> 0.0e+00  2  4  0  0  0   2  4  0  0  0 207057
>>> VecAYPX           613089 1.0 6.5360e+00 1.9 1.13e+10 1.1 0.0e+00 0.0e+00
>>> 0.0e+00  1  2  0  0  0   1  2  0  0  0 420336
>>> VecAXPBYCZ           191 1.0 3.7365e-03 1.4 7.06e+06 1.1 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0 458830
>>> VecWAXPY             938 1.0 3.8502e-02 1.4 8.67e+06 1.1 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0 54669
>>> VecMAXPY          613089 1.0 1.3276e+01 2.2 2.27e+10 1.1 0.0e+00 0.0e+00
>>> 0.0e+00  1  4  0  0  0   1  4  0  0  0 414499
>>> VecLoad                5 1.0 2.0913e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> VecScatterBegin   820695 1.0 1.8959e+01 2.8 0.00e+00 0.0 1.1e+09 4.6e+03
>>> 0.0e+00  2  0100100  0   2  0100100  0     0
>>> VecScatterEnd     820695 1.0 5.2002e+01 4.2 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
>>> VecReduceArith      2814 1.0 1.8517e-02 1.2 5.20e+07 1.1 0.0e+00 0.0e+00
>>> 0.0e+00  0  0  0  0  0   0  0  0  0  0 681995
>>> VecReduceComm        938 1.0 2.6041e+00 3.4 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 9.4e+02  0  0  0  0  0   0  0  0  0  0     0
>>> MatMult           817452 1.0 1.9379e+02 1.6 2.04e+11 1.2 1.0e+09 4.6e+03
>>> 0.0e+00 23 40100100  0  23 40100100  0 253083
>>> MatSOR            818390 1.0 1.9608e+02 1.5 2.00e+11 1.1 0.0e+00 0.0e+00
>>> 0.0e+00 22 40  0  0  0  22 40  0  0  0 247472
>>> MatAssemblyBegin     939 1.0 7.9671e+00 6.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 1.9e+03  1  0  0  0  0   1  0  0  0  0     0
>>> MatAssemblyEnd       939 1.0 2.0570e-01 1.2 0.00e+00 0.0 2.6e+03 1.2e+03
>>> 8.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>> MatZeroEntries       938 1.0 1.8202e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00
>>> SNESSolve            210 1.0 6.8585e+02 1.0 5.06e+11 1.2 1.1e+09 4.6e+03
>>> 2.1e+06 98100100100100  98100100100100 178411
>>> SNESFunctionEval    2296 1.0 2.0512e+01 1.3 0.00e+00 0.0 2.9e+06 3.5e+03
>>> 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
>>> SNESJacobianEval     938 1.0 2.7680e+01 1.0 0.00e+00 0.0 1.2e+06 3.5e+03
>>> 1.9e+03  4  0  0  0  0   4  0  0  0  0     0
>>> SNESLineSearch       938 1.0 9.2491e+00 1.0 6.07e+07 1.1 1.2e+06 3.5e+03
>>> 9.4e+02  1  0  0  0  0   1  0  0  0  0  1593
>>> KSPSetUp             938 1.0 2.7661e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
>>> 2.0e+01  0  0  0  0  0   0  0  0  0  0     0
>>> KSPSolve             938 1.0 6.3433e+02 1.0 5.06e+11 1.2 1.0e+09 4.6e+03
>>> 2.0e+06 91100100100 99  91100100100 99 192852
>>> PCSetUp              938 1.0 2.1005e-04 3.1 0.00e+00 0.0 0.0e+00 0.0e+00
>>> PCApply           818390 1.0 1.9675e+02 1.5 2.00e+11 1.1 0.0e+00 0.0e+00
>>> 0.0e+00 22 40  0  0  0  22 40  0  0  0 246626
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160205/b3e50927/attachment.html>
