[petsc-users] petsc externalpackage directory
Jed Brown jed at jedbrown.org
Tue Feb 2 19:00:48 CST 2016
Satish Balay <balay at mcs.anl.gov> writes:
> Or you can copy the whole '$PETSC_ARCH/externalpackages' dir over to
> this other machine [and place in the same location - for any
> PETSC_ARCH you plan to use..]
This sounds unreliable.  We used to have a unified externalpackages
directory, but made it per-PETSC_ARCH partly to avoid dirty source trees
causing incorrect builds (and so that configure could run in parallel
for different PETSC_ARCH).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160202/220f0ae9/attachment.pgp>
