[petsc-users] petsc externalpackage directory
Tue Feb 2 09:46:20 CST 2016
On Tue, Feb 2, 2016 at 9:21 AM, Xiangdong <epscodes at gmail.com> wrote:
> the package is untar and compiled in $PETSC_ARCH/externalpackages, but the
> original tarball .tar file is deleted. Is it correct?
If you want the tarball URL, you can see it in the Python;
https://bitbucket.org/petsc/petsc/src/e03cc9b84019b00a431ca4cfdfeb76830ce7201c/config/BuildSystem/config/packages/PaStiX.py?at=master&fileviewer=file-view-default#PaStiX.py-6
  Matt
> Xiangdong
> On Tue, Feb 2, 2016 at 10:15 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Feb 2, 2016 at 9:15 AM, Xiangdong <epscodes at gmail.com> wrote:
>>> Not really. My question is if I use download-pastix=1, which directory
>>> is the tarball (package pastix_5.2.2.20.tar.bz2) downloaded into?
>>   Matt
>>> Thanks.
>>> Xiangdong
>>> On Tue, Feb 2, 2016 at 9:59 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Feb 2, 2016 at 8:46 AM, Xiangdong <epscodes at gmail.com> wrote:
>>>>> Hello everyone,
>>>>> If I use the option -download-pastix=1, which directory is the package
>>>>> pastix_5.2.2.20.tar.bz2 downloaded to? It was compiled and installed in
>>>>> arch/externalpackages, but I want to know where the tar file is. I want to
>>>>> copy these tar files into a computer without internet connection and
>>>>> install petsc there.
>>>> If I understand your question correctly, you can just give
>>>>   --download-pastix=<path/to/tarball>
>>>> and it will do what you want.
>>>>   Thanks,
>>>>     Matt
>>>>> Thanks.
>>>>> Xiangdong
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160202/e3921818/attachment.html>
