[petsc-users] Error with SuperLU_DIST (mkl related?)
Sat Dec 31 12:17:27 CST 2016
                          Trying to download git://https://github.com/xiaoyeli/superlu_dist for SUPERLU_DIST
Executing: git clone https://github.com/xiaoyeli/superlu_dist /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/externalpackages/git.superlu_dist
stdout: Cloning into '/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/externalpackages/git.superlu_dist'...
                    Looking for SUPERLU_DIST at git.superlu_dist, hg.superlu_dist or a directory starting with ['superlu_dist']
                    Found a copy of SUPERLU_DIST in git.superlu_dist
Executing: ['git', 'rev-parse', '--git-dir']
stdout: .git
Executing: ['git', 'cat-file', '-e', 'v5.1.3^{commit}']
Executing: ['git', 'rev-parse', 'v5.1.3']
stdout: 7306f704c6c8d5113def649b76def3c8eb607690
Executing: ['git', 'stash']
stdout: No local changes to save
Executing: ['git', 'clean', '-f', '-d', '-x']
Executing: ['git', 'checkout', '-f', '7306f704c6c8d5113def649b76def3c8eb607690']
Per log below - its using 5.1.3. Why did you think you got 5.1.0?
Satish
On Sat, 31 Dec 2016, Eric Chamberland wrote:
> Hi,
> ok I will test with 5.1.3 with the option you gave me
> (--download-superlu_dit-commit=v5.1.3).
> But from what you and Matthew said, I should have 5.1.3 with petsc-master, but
> the last night log shows me library file name 5.1.0:
> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.12.31.02h00m01s_configure.log
> So I am a bit confused: Why did I got 5.1.0 last night? (I use the
> petsc-master tarball, is it the reason?)
> Thanks,
> Eric
> > > Hi,
> > > I am just starting to debug a bug encountered with and only with
> > > SuperLU_Dist
> > > combined with MKL on a 2 processes validation test.
> > > (the same test works fine with MUMPS on 2 processes).
> > > I just noticed that the SuperLU_Dist version installed by PETSc configure
> > > script is 5.1.0 and the latest SuperLU_DIST is 5.1.3.
> > If you use petsc-master - it will install 5.1.3 by default.
> > > Before going further, I just want to ask:
> > > Is there any specific reason to stick to 5.1.0?
> > We don't usually upgrade externalpackage version in PETSc releases
> > [unless its tested to work and fixes known bugs]. There could be API
> > changes - or build changes that can potentially conflict.
> > >From what I know - 5.1.3 should work with petsc-3.7 [it fixes a couple of
> > bugs].
> > You might be able to do the following with petsc-3.7 [with git
> > externalpackage repos]
> > --download-superlu_dist --download-superlu_dit-commit=v5.1.3
> > Satish
> > > Here is some more information:
> > > On process 2 I have this printed in stdout:
> > > Intel MKL ERROR: Parameter 6 was incorrect on entry to DTRSM .
> > > and in stderr:
> > > Test.ProblemeEFGen.opt: malloc.c:2369: sysmalloc: Assertion `(old_top ==
> > > (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) - __builtin_offsetof
> > > (struct malloc_chunk, fd)))) && old_size == 0) || ((unsigned long)
> > > (old_size)
> > > > = (unsigned long)((((__builtin_offsetof (struct malloc_chunk,
> > > fd_nextsize))+((2 *(sizeof(size_t))) - 1)) & ~((2 *(sizeof(size_t))) -
> > > 1))) &&
> > > ((old_top)->size & 0x1) && ((unsigned long) old_end & pagemask) == 0)'
> > > failed.
> > > [saruman:15771] *** Process received signal ***
> > > This is the 7th call to KSPSolve in the same execution. Here is the last
> > > KSPView:
> > > KSP Object:(o_slin) 2 MPI processes
> > >    type: preonly
> > >    maximum iterations=10000, initial guess is zero
> > >    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
> > >    left preconditioning
> > >    using NONE norm type for convergence test
> > > PC Object:(o_slin) 2 MPI processes
> > >    type: lu
> > >      LU: out-of-place factorization
> > >      tolerance for zero pivot 2.22045e-14
> > >      matrix ordering: natural
> > >      factor fill ratio given 0., needed 0.
> > >        Factored matrix follows:
> > >          Mat Object:         2 MPI processes
> > >            type: mpiaij
> > >            rows=382, cols=382
> > >            package used to perform factorization: superlu_dist
> > >            total: nonzeros=0, allocated nonzeros=0
> > >            total number of mallocs used during MatSetValues calls =0
> > >              SuperLU_DIST run parameters:
> > >                Process grid nprow 2 x npcol 1
> > >                Equilibrate matrix TRUE
> > >                Matrix input mode 1
> > >                Replace tiny pivots FALSE
> > >                Use iterative refinement FALSE
> > >                Processors in row 2 col partition 1
> > >                Row permutation LargeDiag
> > >                Column permutation METIS_AT_PLUS_A
> > >                Parallel symbolic factorization FALSE
> > >                Repeated factorization SamePattern
> > >    linear system matrix = precond matrix:
> > >    Mat Object:  (o_slin)   2 MPI processes
> > >      type: mpiaij
> > >      rows=382, cols=382
> > >      total: nonzeros=4458, allocated nonzeros=4458
> > >        using I-node (on process 0) routines: found 109 nodes, limit used
> > >        is 5
> > > I know this information is not enough to help debug, but I would like to
> > > know
> > > if PETSc guys will upgrade to 5.1.3 before trying to debug anything.
> > > Thanks,
> > > Eric
