[petsc-users] Fwd: Problem linking code with MS MPI + PETSc
TAY wee-beng zonexo at gmail.com
Tue Dec 27 02:24:03 CST 2016
Sorry I just realised that I was pointing to the wrong library. It's ok now.
-------- Forwarded Message --------
Subject: 	Problem linking code with MS MPI + PETSc
Date: 	Tue, 27 Dec 2016 16:02:40 +0800
To: 	PETSc list <petsc-users at mcs.anl.gov>
I am now trying to use MS MPI after compiling with PETSc. I was using
MPICH before.
During linking, I got the error:
1>Compiling manifest to resources...
1>Microsoft (R) Windows (R) Resource Compiler Version 6.1.6723.1
1>Copyright (C) Microsoft Corporation.  All rights reserved.
1>Linking...
1>libpetsc.lib(somefort.o) : warning LNK4049: locally defined symbol
MPIFCMB1 imported
1>libpetsc.lib(f90_fwrap.o) : warning LNK4049: locally defined symbol
MPIFCMB1 imported
MPIFCMB2 imported
MPIFCMB2 imported
MPIFCMB3 imported
MPIFCMB3 imported
MPIFCMB4 imported
MPIFCMB4 imported
MPIFCMB7 imported
MPIFCMB7 imported
MPIFCMB8 imported
MPIFCMB8 imported
1>libpetsc.lib(pinit.o) : error LNK2019: unresolved external symbol
MPI_Reduce_scatter_block referenced in function PetscMaxSum
1>libpetsc.lib(mpits.o) : error LNK2001: unresolved external symbol
1>C:\Obj_tmp\ibm3d_IIB_mpi\Debug\ibm3d_IIB_mpi.exe : fatal error
LNK1120: 1 unresolved externals
1>
May I know what's wrong?
Thank you
Yours sincerely,
TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161227/ed551928/attachment.html>
