[petsc-users] Segmentation faults: Derived types
Santiago Ospina De Los Rios sospinar at unal.edu.co
Sun Aug 21 05:09:46 CDT 2016
wow, what a dumb mistake. thank you very much!
Since you've noticed me such error, I am taking the time to learn all of
your advice about management and debugging code
<https://www.mcs.anl.gov/petsc/documentation/codemanagement.html>. Then I'm
learning emacs and so... the matter is that you recommend to use PETSc tags
which it's supposed to be in ${PETSC_DIR}/TAGS, but it seems to be changed
or something because I wasn't able to find it.
So, how can I use the tags you are referring to?
2016-08-19 14:40 GMT-05:00 Barry Smith <bsmith at mcs.anl.gov>:
>    You code has a bug right at the top:
>    CALL PetscInitialize(PETSC_COMM_WORLD,ierr)
> should be
>    CALL PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> you were just lucky previously that the stack frame was different enough
> that it did not previously crash. Once I corrected the code the new version
> ran without crashing. I found the bug very easily by simply running the new
> version directly in the debugger
> lldb ./ANSIFLOW
> and seeing it crashed with a crazy stack in petscinitialize_
>   Barry
> > On Aug 5, 2016, at 11:34 PM, Santiago Ospina De Los Rios <
> sospinar at unal.edu.co> wrote:
> > Dear Barry,
> > I tried to build a simple code with the same things I mentioned to you
> on last e-mail but it worked, which is more strange to me. So I built two
> branches on my git code to show you the problem:
> > git code: https://github.com/SoilRos/ANISOFLOWPACK
> > Branch:  PETSc_debug_boolean_0
> > The first one is a simple code which is working for what was designed.
> Forget sample problems, just compile and run the ANISOFLOW executable on
> src folder, if there are some verbose messages then the program is working.
> > Branch:  PETSc_debug_boolean_1
> > The second one is just a modification of the first one adding the two
> booleans mentioned above in 01_Types.F90 file. I tried it in mac El Capitan
> and Ubuntu (with Valgrind) and PETSc 3.7.3 and 3.7.2 respectively, both
> with the same segmentation fault.
> > PD: Although I already fixed it compressing the three booleans into one
> integer, I think is better if we try to figure out why there is a
> segmentation fault because I had similar problems before.
> > PD2: Please obviate the variable description because are pretty out of
> date. I'm trying to change it, so it can be confusing.
> > Best wishes,
> > Santiago Ospina
> > 2016-08-05 15:54 GMT-05:00 Barry Smith <bsmith at mcs.anl.gov>:
> > > On Aug 1, 2016, at 4:41 PM, Santiago Ospina De Los Rios <
> > > Hello there,
> > > I'm having problems defining some variables into derived types in
> Fortran. Before, I had a similar problems with an allocatable array
> "PetsInt" but I solved it just doing a non-collective Petsc Vec. Today I'm
> having troubles with "PetscBool" or "Logical":
> > > In a module which define the variables, I have the following:
> > > MODULE ANISOFLOW_Types
> > >     IMPLICIT NONE
> > > #include <petsc/finclude/petscsys.h>
> > > #include <petsc/finclude/petscvec.h>
> > >      TYPE ConductivityField
> > >          PetscBool                               ::
> DefinedByCvtZones=.FALSE.    ! It produces the segmentation fault.
> > >          PetscBool                               ::
> DefinedByPptZones=.FALSE.    ! It produces the segmentation fault.
> > >          PetscBool                               ::
> DefinedByCell=.FALSE.
> > >          ! Conductivity defined by zones (Local):
> > >          Vec                                     :: ZoneID
> > >          TYPE(Tensor),ALLOCATABLE                :: Zone(:)
> > >          ! Conductivity defined on every cell (Local):
> > >          Vec                                     :: Cell
> > >      END TYPE ConductivityField
> > >     TYPE SpecificStorageField
> > >         PetscBool                               ::
> DefinedByStoZones=.FALSE.    ! It produces the segmentation fault.
> > >         PetscBool                               ::
> > >         PetscBool                               ::
> > >         ! Specific Storage defined by zones (Local):
> > >         Vec                                     :: ZoneID
> > >         Vec                                     :: Zone
> > >         ! Specific Storage defined on every cell (Global).:
> > >         Vec                                     :: Cell
> > >     END TYPE SpecificStorageField
> > >     TYPE PropertiesField
> > >         TYPE(ConductivityField)         :: Cvt
> > >         TYPE(SpecificStorageField)      :: Sto
> > >         ! Property defined by zones (Local):
> > >         PetscBool                       :: DefinedByPptZones=.FALSE.
> > >         Vec                             :: ZoneID
> > >     END TYPE PropertiesField
> > > CONTAINS
> > > END MODULE ANISOFLOW_Types
> > > Later I use it in the main program, with something like this
> > > PROGRAM ANISOFLOW
> > >     USE ANISOFLOW_Types,                ONLY : ... ,PropertiesField,
> > >     IMPLICIT NONE
> > >     TYPE(PropertiesField)       :: PptFld
> > >     CALL PetscFinalize(ierr)
> > > END PROGRAM
> > > When I run the program appears a Segmentation Fault, which disappears
> when I comment the booleans marked in the code. Because I need them, I used
> Valgrind to figure out what is happening but it is yet a mistery to me.
> > > Valgrind message:
> > > ==5160==
> > > ==5160== Invalid read of size 1
> >    It is curious that it says "of size 1" when we declare PetscBool to
> be a logical*4 I don't see anything obviously wrong.
> >    Please send a simple code we can compile and run that reproduces the
> problem.
> >    Barry
> > > ==5160==    at 0x4FB2156: petscinitialize_ (zstart.c:433)
> > > ==5160==    by 0x4030EA: MAIN__ (ANISOFLOW.F90:29) # line of petsc
> inizalitation
> > > ==5160==    by 0x404380: main (ANISOFLOW.F90:3) # line of "USE
> ANISOFLOW_Types,                ONLY : ... ,PropertiesField, ..."
> > > ==5160==  Address 0xc54fff is not stack'd, malloc'd or (recently)
> free'd
> > > ==5160==
> > > Program received signal SIGSEGV: Segmentation fault - invalid memory
> reference.
> > > Backtrace for this error:
> > > #0  0x699E777
> > > #1  0x699ED7E
> > > #2  0x6F0BCAF
> > > #3  0x4FB2156
> > > #4  0x4030EA in anisoflow at ANISOFLOW.F90:29
> > > I think it is maybe related with petsc because the error popped out
> just in its initialization, so if you know what's going on, I would
> appreciate to tell me.
> > > Santiago Ospina
> > > Att:
> > > Santiago Ospina De Los Ríos
> > > National University of Colombia
> > Att:
Att:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160821/517a8151/attachment-0001.html>
