[petsc-users] Modifying built files for use with Japan's K computer
TAY wee-beng zonexo at gmail.com
Sun Apr 24 21:31:46 CDT 2016
On 25/4/2016 2:52 AM, Matthew Knepley wrote:
> On Sun, Apr 24, 2016 at 10:12 AM, Wee-beng TAY <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi Matt,
>     I have attached the page which explains what to modify to use
>     PETSc with the K computer.
> These changes are now in knepley/feature-configure-kcomputer, so you
>   cd $PETSC_DIR
>   git fetch
>   git checkout knepley/feature-configure-kcomputer
>   <follow configure instructions from your email>
I got the warning and error:
" --LD_SHARED="" --LDDFLAGS="" --with-openmp=1 --with-mpiexec=mpiexec
--known-endian=big --with-shared-libraries=0
--with-blas-lapack-lib="-SSL2" --with-scalapack-lib="-SCALAPACK"
--prefix=/home/hp150306/t00196/lib/petsc-3.6.4_rel
--with-fortran-interfaces=1 --download-hypre=1 --with-debugging=0
--with-batch=1
              Configuring PETSc to compile on your system
*****WARNING: PETSC_DIR appears to be a Git clone - but git is not found
in PATH********
TESTING: checkCCompiler from
config.setCompilers(config/BuildSystem/config/setCompilers.py:553)
Exception AttributeError: AttributeError("Popen3 instance has no
attribute 'pid'",) in <bound method Popen3.__del__ of <popen2.Popen3
instance at 0x107bbf38>> ignored
                     UNABLE to EXECUTE BINARIES for ./configure
[Errno 12] Cannot allocate memory
Any other solution?
Thanks!
>   Thanks,
>     Matt
>     Thanks
>     On 24/4/2016 10:52 PM, Matthew Knepley wrote:
>>     On Sun, Apr 24, 2016 at 4:14 AM, Wee-beng TAY <zonexo at gmail.com
>>         Hi,
>>         I was recently given access to Japan's K computer. I'm trying
>>         to compile PETSc on their sys, which uses Fujitsu's compiler.
>>         There's a help file but it's in Japanese. I guess I need to
>>         change some options to make PETSc compile with Fujitsu's
>>         compiler.
>>     It looks like they want us to include some different options for
>>     the build. If you send what you want,
>>     I will make a branch for you to try out.
>>       Thanks,
>>          Matt
>>         Part of the help is below. So how should I use the diff or
>>         some other command to do the correction? I tried to run:
>>          diff -u petsc-3.6.4/config/BuildSystem/config/package.py.org
>>         <http://package.py.org>
>>         but got the err:
>>         diff: petsc-3.6.4/config/BuildSystem/config/package.py.org
>>         <http://package.py.org>: No such file or directory
>>         Please advice. Thanks.
>>         /|$ diff -u
>>         petsc-|//|3.6|//|.|//|3|//|/config/BuildSystem/config/|//|package|//|.py.org
>>         <http://py.org>
>>         petsc-|//|3.6|//|.|//|3|//|/config/BuildSystem/config/|//|package|//|.py|/
>>         <http://py.org>
>>         |//|2015|//|-|//|12|//|-|//|04|////|14|//|:|//|06|//|:|//|42.000000000|////|+|//|0900|/
>>         |//|2016|//|-|//|01|//|-|//|22|////|11|//|:|//|09|//|:|//|37.000000000|////|+|//|0900|/
>>         /|@@ -|//|174|//|,|//|7|////|+|//|174|//|,|//|7|////|@@|/
>>         /||//|return|////|''|/
>>         /||//|def getSharedFlag(self,cflags):|/
>>         /|- |//|for|////|flag in
>>         [|//|'-PIC'|//|,|//|'-fPIC'|//|,|//|'-KPIC'|//|,|//|'-qpic'|//|]:|/
>>         /|+ |//|for|////|flag in
>>         [|//|'-KPIC'|//|,|//|'-fPIC'|//|,|//|'-PIC'|//|,|//|'-qpic'|//|]:|/
>>         /||//|if|////|cflags.find(flag)
>>         >=|//|0|//|:|//|return|////|flag|/
>>         /|$ diff -u
>>         petsc-|//|3.6|//|.|//|3|//|/config/BuildSystem/config/setCompilers.py.org
>>         <http://setCompilers.py.org>
>>         petsc-|//|3.6|//|.|//|3|//|/config/BuildSystem/config/setCompilers.py|/
>>         |//|2015|//|-|//|07|//|-|//|23|////|00|//|:|//|22|//|:|//|46.000000000|////|+|//|0900|/
>>         |//|2016|//|-|//|01|//|-|//|22|////|11|//|:|//|10|//|:|//|05.000000000|////|+|//|0900|/
>>         /|@@ -|//|1017|//|,|//|7|////|+|//|1017|//|,|//|7|////|@@|/
>>         /||//|self.pushLanguage(language)|/
>>         /||//|#different compilers are sensitive to the order of
>>         testing these flags. So separete out GCC test.|/
>>         /||//|if|////|config.setCompilers.Configure.isGNU(self.getCompiler()):
>>         testFlags = [|//|'-fPIC'|//|]|/
>>         /|- |//|else|//|: testFlags =
>>         [|//|'-PIC'|//|,|//|'-fPIC'|//|,|//|'-KPIC'|//|,|//|'-qpic'|//|]|/
>>         /|+ |//|else|//|: testFlags =
>>         [|//|'-KPIC'|//|,|//|'-fPIC'|//|,|//|'-PIC'|//|,|//|'-qpic'|//|]|/
>>         /||//|for|////|testFlag in testFlags:|/
>>         /||//|try|//|:|/
>>         /||//|self.logPrint(|//|'Trying '|//|+language+|//|' compiler
>>         flag '|//|+testFlag)|/
>>         /|$ diff -u
>>         petsc-|//|3.6|//|.|//|3|//|/config/BuildSystem/config/packages/openmp.py.org
>>         <http://openmp.py.org>
>>         petsc-|//|3.6|//|.|//|3|//|/config/BuildSystem/config/packages/openmp.py|/
>>         |//|2016|//|-|//|01|//|-|//|25|////|15|//|:|//|42|//|:|//|23.000000000|//|+|//|0900|/
>>         |//|2016|//|-|//|01|//|-|//|22|////|17|//|:|//|13|//|:|//|52.000000000|////|+|//|0900|/
>>         /|@@ -|//|19|//|,|//|7|////|+|//|19|//|,|//|8|////|@@|/
>>         /||//|self.found =|//|0|/
>>         /||//|self.setCompilers.pushLanguage(|//|'C'|//|)|/
>>         /|- |//|for|////|flag in [|//|"-fopenmp"|//|, # Gnu|/
>>         /|+ |//|for|////|flag in [|//|"-Kopenmp"|//|, # Fujitsu|/
>>         /|+ |//|"-fopenmp"|//|, # Gnu|/
>>         /||//|"-qsmp=omp"|//|,# IBM XL C/C++|/
>>         /||//|"-h omp"|//|,   # Cray. Must come after XL because XL
>>         interprets|//|this|////|option as meaning|//|"-soname omp"|/
>>         /||//|"-mp"|//|, # Portland Group|/
>>         /|$ diff -u
>>         ./petsc-|//|3.6|//|.|//|3|//|/config/BuildSystem/config/compilers.py.org
>>         <http://compilers.py.org>
>>         ./petsc-|//|3.6|//|.|//|3|//|/config/BuildSystem/config/compilers.py|/
>>         |//|2015|//|-|//|06|//|-|//|10|////|06|//|:|//|24|//|:|//|49.000000000|////|+|//|0900|/
>>         |//|2016|//|-|//|02|//|-|//|19|////|11|//|:|//|56|//|:|//|12.000000000|////|+|//|0900|/
>>         /|@@ -|//|164|//|,|//|7|////|+|//|164|//|,|//|7|////|@@|/
>>         /||//|def checkCLibraries(self):|/
>>         /||//|''|//|'Determines the libraries needed to link with
>>         C'|//|''|/
>>         /||//|oldFlags = self.setCompilers.LDFLAGS|/
>>         /|- self.setCompilers.LDFLAGS +=|//|' -v'|/
>>         /|+ self.setCompilers.LDFLAGS +=|//|' -###'|/
>>         /||//|self.pushLanguage(|//|'C'|//|)|/
>>         /||//|(output, returnCode) =
>>         self.outputLink(|//|''|//|,|//|''|//|)|/
>>         /||//|self.setCompilers.LDFLAGS = oldFlags|/
>>         /|@@ -|//|413|//|,|//|7|////|+|//|413|//|,|//|7|////|@@|/
>>         /||//|def checkCxxLibraries(self):|/
>>         C++'|//|''|/
>>         /||//|self.pushLanguage(|//|'Cxx'|//|)|/
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160425/51dd6f83/attachment-0001.html>
