[petsc-users] About the MatGetOrdering in Petsc
Wei Deng deng106 at purdue.edu
Thu Apr 21 22:59:13 CDT 2016
Dear Sir/Madam,
When I was trying to change a sparse matrix into a banded one, I can use RCM
in matlab to change it perfectly. But this does not work in Petsc, most
points were moved to the diagonal position. However, there are still some
points left, leading the width unacceptable.
Do you know why?
The attachment is the code with which I have trouble.
Thanks a lot.
Wei Deng
Purdue Uni.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160421/8336ad9c/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160421/8336ad9c/attachment.ksh>
