[petsc-users] Deactivate PETSc error handling
marco restelli mrestelli at gmail.com
Tue Apr 19 03:26:12 CDT 2016
Dear all,
   running a code linked against PETSc I get the following error:
PETSC ERROR: Caught signal number 8 FPE: Floating Point
Exception,probably divide by zero
This message from PETSc is suppressing a much more useful error
message from the compiler, which typically indicates the source line
where the floating point exception happened. Is there a way to switch
off any error handling from PETSc?
Thank you,
   Marco
