[petsc-users] how to compile the program with c++11 support.
Sun Apr 17 23:12:17 CDT 2016
you have to be a bit more specific on the issue you are encountering.
- are you using PETSc makefiles?
- where did you add "-std=c++11" in the makefile?
- what is the compile command and its warnings/errors you are getting
  from the makefile? [after whatever you did]
Usually it should work if you add it to CXXFLAGS in makefile - or run 'make CXXFLAGS="-std=c++11"
Or you can configure petsc with the option --with-cxx-dialect=C++11
Satish
On Sun, 17 Apr 2016, 丁老师 wrote:
> Dear friends:
>      I add the "-std=c++11" in the make file, but it still give me warning.
