[petsc-users] fieldsplit preconditioner for indefinite matrix
Sun Apr 17 08:16:07 CDT 2016
On Sun, Apr 17, 2016 at 4:25 AM, Hoang Giang Bui <hgbk2008 at gmail.com> wrote:
>> It could be taking time in the MatMatMult() here if that matrix is dense.
>> Is there any reason to
>> believe that is a good preconditioner for your problem?
> This is the first approach to the problem, so I chose the most simple
> setting. Do you have any other recommendation?
This is in no way the simplest PC. We need to make it simpler first.
  1) Run on only 1 proc
  2) Use -pc_fieldsplit_schur_fact_type full
  3) Use -fieldsplit_lu_ksp_type gmres
-fieldsplit_lu_ksp_monitor_true_residual
This should converge in 1 outer iteration, but we will see how good your
Schur complement preconditioner
is for this problem.
You need to start out from something you understand and then start making
approximations.
   Matt
> For any solver question, please send us the output of
>>   -ksp_view -ksp_monitor_true_residual -ksp_converged_reason
> I sent here the full output (after changed to fgmres), again it takes long
> at the first iteration but after that, it does not converge
> -ksp_type fgmres
> -ksp_max_it 300
> -ksp_gmres_restart 300
> -ksp_gmres_modifiedgramschmidt
> -pc_fieldsplit_type schur
> -pc_fieldsplit_schur_fact_type diag
> -pc_fieldsplit_schur_precondition selfp
> -pc_fieldsplit_detect_saddle_point
> -fieldsplit_u_ksp_type preonly
> -fieldsplit_u_pc_type lu
> -fieldsplit_u_pc_factor_mat_solver_package mumps
> -fieldsplit_lu_ksp_type preonly
> -fieldsplit_lu_pc_type lu
> -fieldsplit_lu_pc_factor_mat_solver_package mumps
>   0 KSP unpreconditioned resid norm 3.037772453815e+06 true resid norm
> 3.037772453815e+06 ||r(i)||/||b|| 1.000000000000e+00
>   1 KSP unpreconditioned resid norm 3.024368791893e+06 true resid norm
> 3.024368791296e+06 ||r(i)||/||b|| 9.955876673705e-01
>   2 KSP unpreconditioned resid norm 3.008534454663e+06 true resid norm
> 3.008534454904e+06 ||r(i)||/||b|| 9.903751846607e-01
>   3 KSP unpreconditioned resid norm 4.633282412600e+02 true resid norm
> 4.607539866185e+02 ||r(i)||/||b|| 1.516749505184e-04
>   4 KSP unpreconditioned resid norm 4.630592911836e+02 true resid norm
> 4.605625897903e+02 ||r(i)||/||b|| 1.516119448683e-04
>   5 KSP unpreconditioned resid norm 2.145735509629e+02 true resid norm
> 2.111697416683e+02 ||r(i)||/||b|| 6.951466736857e-05
>   6 KSP unpreconditioned resid norm 2.145734219762e+02 true resid norm
> 2.112001242378e+02 ||r(i)||/||b|| 6.952466896346e-05
>   7 KSP unpreconditioned resid norm 1.892914067411e+02 true resid norm
> 1.831020928502e+02 ||r(i)||/||b|| 6.027511791420e-05
>   8 KSP unpreconditioned resid norm 1.892906351597e+02 true resid norm
> 1.831422357767e+02 ||r(i)||/||b|| 6.028833250718e-05
>   9 KSP unpreconditioned resid norm 1.891426729822e+02 true resid norm
> 1.835600473014e+02 ||r(i)||/||b|| 6.042587128964e-05
>  10 KSP unpreconditioned resid norm 1.891425181679e+02 true resid norm
> 1.855772578041e+02 ||r(i)||/||b|| 6.108991395027e-05
>  11 KSP unpreconditioned resid norm 1.891417382057e+02 true resid norm
> 1.833302669042e+02 ||r(i)||/||b|| 6.035023020699e-05
>  12 KSP unpreconditioned resid norm 1.891414749001e+02 true resid norm
> 1.827923591605e+02 ||r(i)||/||b|| 6.017315712076e-05
>  13 KSP unpreconditioned resid norm 1.891414702834e+02 true resid norm
> 1.849895606391e+02 ||r(i)||/||b|| 6.089645075515e-05
>  14 KSP unpreconditioned resid norm 1.891414687385e+02 true resid norm
> 1.852700958573e+02 ||r(i)||/||b|| 6.098879974523e-05
>  15 KSP unpreconditioned resid norm 1.891399614701e+02 true resid norm
> 1.817034334576e+02 ||r(i)||/||b|| 5.981469521503e-05
>  16 KSP unpreconditioned resid norm 1.891393964580e+02 true resid norm
> 1.823173574739e+02 ||r(i)||/||b|| 6.001679199012e-05
>  17 KSP unpreconditioned resid norm 1.890868604964e+02 true resid norm
> 1.834754811775e+02 ||r(i)||/||b|| 6.039803308740e-05
>  18 KSP unpreconditioned resid norm 1.888442703508e+02 true resid norm
> 1.852079421560e+02 ||r(i)||/||b|| 6.096833945658e-05
>  19 KSP unpreconditioned resid norm 1.888131521870e+02 true resid norm
> 1.810111295757e+02 ||r(i)||/||b|| 5.958679668335e-05
>  20 KSP unpreconditioned resid norm 1.888038471618e+02 true resid norm
> 1.814080717355e+02 ||r(i)||/||b|| 5.971746550920e-05
>  21 KSP unpreconditioned resid norm 1.885794485272e+02 true resid norm
> 1.843223565278e+02 ||r(i)||/||b|| 6.067681478129e-05
>  22 KSP unpreconditioned resid norm 1.884898771362e+02 true resid norm
> 1.842766260526e+02 ||r(i)||/||b|| 6.066176083110e-05
>  23 KSP unpreconditioned resid norm 1.884840498049e+02 true resid norm
> 1.813011285152e+02 ||r(i)||/||b|| 5.968226102238e-05
>  24 KSP unpreconditioned resid norm 1.884105698955e+02 true resid norm
> 1.811513025118e+02 ||r(i)||/||b|| 5.963294001309e-05
>  25 KSP unpreconditioned resid norm 1.881392557375e+02 true resid norm
> 1.835706567649e+02 ||r(i)||/||b|| 6.042936380386e-05
>  26 KSP unpreconditioned resid norm 1.881234481250e+02 true resid norm
> 1.843633799886e+02 ||r(i)||/||b|| 6.069031923609e-05
>  27 KSP unpreconditioned resid norm 1.852572648925e+02 true resid norm
> 1.791532195358e+02 ||r(i)||/||b|| 5.897519391579e-05
>  28 KSP unpreconditioned resid norm 1.852177694782e+02 true resid norm
> 1.800935543889e+02 ||r(i)||/||b|| 5.928474141066e-05
>  29 KSP unpreconditioned resid norm 1.844720976468e+02 true resid norm
> 1.806835899755e+02 ||r(i)||/||b|| 5.947897438749e-05
>  30 KSP unpreconditioned resid norm 1.843525447108e+02 true resid norm
> 1.811351238391e+02 ||r(i)||/||b|| 5.962761417881e-05
>  31 KSP unpreconditioned resid norm 1.834262885149e+02 true resid norm
> 1.778584233423e+02 ||r(i)||/||b|| 5.854896179565e-05
>  32 KSP unpreconditioned resid norm 1.833523213017e+02 true resid norm
> 1.773290649733e+02 ||r(i)||/||b|| 5.837470306591e-05
>  33 KSP unpreconditioned resid norm 1.821645929344e+02 true resid norm
> 1.781151248933e+02 ||r(i)||/||b|| 5.863346501467e-05
>  34 KSP unpreconditioned resid norm 1.820831279534e+02 true resid norm
> 1.789778939067e+02 ||r(i)||/||b|| 5.891747872094e-05
>  35 KSP unpreconditioned resid norm 1.814860919375e+02 true resid norm
> 1.757339506869e+02 ||r(i)||/||b|| 5.784960965928e-05
>  36 KSP unpreconditioned resid norm 1.812512010159e+02 true resid norm
> 1.764086437459e+02 ||r(i)||/||b|| 5.807171090922e-05
>  37 KSP unpreconditioned resid norm 1.804298150360e+02 true resid norm
> 1.780147196442e+02 ||r(i)||/||b|| 5.860041275333e-05
>  38 KSP unpreconditioned resid norm 1.799675012847e+02 true resid norm
> 1.780554543786e+02 ||r(i)||/||b|| 5.861382216269e-05
>  39 KSP unpreconditioned resid norm 1.793156052097e+02 true resid norm
> 1.747985717965e+02 ||r(i)||/||b|| 5.754169361071e-05
>  40 KSP unpreconditioned resid norm 1.789109248325e+02 true resid norm
> 1.734086984879e+02 ||r(i)||/||b|| 5.708416319009e-05
>  41 KSP unpreconditioned resid norm 1.788931581371e+02 true resid norm
> 1.766103879126e+02 ||r(i)||/||b|| 5.813812278494e-05
>  42 KSP unpreconditioned resid norm 1.785522436483e+02 true resid norm
> 1.762597032909e+02 ||r(i)||/||b|| 5.802268141233e-05
>  43 KSP unpreconditioned resid norm 1.783317950582e+02 true resid norm
> 1.752774080448e+02 ||r(i)||/||b|| 5.769932103530e-05
>  44 KSP unpreconditioned resid norm 1.782832982797e+02 true resid norm
> 1.741667594885e+02 ||r(i)||/||b|| 5.733370821430e-05
>  45 KSP unpreconditioned resid norm 1.781302427969e+02 true resid norm
> 1.760315735899e+02 ||r(i)||/||b|| 5.794758372005e-05
>  46 KSP unpreconditioned resid norm 1.780557458973e+02 true resid norm
> 1.757279911034e+02 ||r(i)||/||b|| 5.784764783244e-05
>  47 KSP unpreconditioned resid norm 1.774691940686e+02 true resid norm
> 1.729436852773e+02 ||r(i)||/||b|| 5.693108615167e-05
>  48 KSP unpreconditioned resid norm 1.771436357084e+02 true resid norm
> 1.734001323688e+02 ||r(i)||/||b|| 5.708134332148e-05
>  49 KSP unpreconditioned resid norm 1.756105727417e+02 true resid norm
> 1.740222172981e+02 ||r(i)||/||b|| 5.728612657594e-05
>  50 KSP unpreconditioned resid norm 1.756011794480e+02 true resid norm
> 1.736979026533e+02 ||r(i)||/||b|| 5.717936589858e-05
>  51 KSP unpreconditioned resid norm 1.751096154950e+02 true resid norm
> 1.713154407940e+02 ||r(i)||/||b|| 5.639508666256e-05
>  52 KSP unpreconditioned resid norm 1.712639990486e+02 true resid norm
> 1.684444278579e+02 ||r(i)||/||b|| 5.544998199137e-05
>  53 KSP unpreconditioned resid norm 1.710183053728e+02 true resid norm
> 1.692712952670e+02 ||r(i)||/||b|| 5.572217729951e-05
>  54 KSP unpreconditioned resid norm 1.655470115849e+02 true resid norm
> 1.631767858448e+02 ||r(i)||/||b|| 5.371593439788e-05
>  55 KSP unpreconditioned resid norm 1.648313805392e+02 true resid norm
> 1.617509396670e+02 ||r(i)||/||b|| 5.324656211951e-05
>  56 KSP unpreconditioned resid norm 1.643417766012e+02 true resid norm
> 1.614766932468e+02 ||r(i)||/||b|| 5.315628332992e-05
>  57 KSP unpreconditioned resid norm 1.643165564782e+02 true resid norm
> 1.611660297521e+02 ||r(i)||/||b|| 5.305401645527e-05
>  58 KSP unpreconditioned resid norm 1.639561245303e+02 true resid norm
> 1.616105878219e+02 ||r(i)||/||b|| 5.320035989496e-05
>  59 KSP unpreconditioned resid norm 1.636859175366e+02 true resid norm
> 1.601704798933e+02 ||r(i)||/||b|| 5.272629281109e-05
>  60 KSP unpreconditioned resid norm 1.633269681891e+02 true resid norm
> 1.603249334191e+02 ||r(i)||/||b|| 5.277713714789e-05
>  61 KSP unpreconditioned resid norm 1.633257086864e+02 true resid norm
> 1.602922744638e+02 ||r(i)||/||b|| 5.276638619280e-05
>  62 KSP unpreconditioned resid norm 1.629449737049e+02 true resid norm
> 1.605812790996e+02 ||r(i)||/||b|| 5.286152321842e-05
>  63 KSP unpreconditioned resid norm 1.629422151091e+02 true resid norm
> 1.589656479615e+02 ||r(i)||/||b|| 5.232967589850e-05
>  64 KSP unpreconditioned resid norm 1.624767340901e+02 true resid norm
> 1.601925152173e+02 ||r(i)||/||b|| 5.273354658809e-05
>  65 KSP unpreconditioned resid norm 1.614000473427e+02 true resid norm
> 1.600055285874e+02 ||r(i)||/||b|| 5.267199272497e-05
>  66 KSP unpreconditioned resid norm 1.599192711038e+02 true resid norm
> 1.602225820054e+02 ||r(i)||/||b|| 5.274344423136e-05
>  67 KSP unpreconditioned resid norm 1.562002802473e+02 true resid norm
> 1.582069452329e+02 ||r(i)||/||b|| 5.207991962471e-05
>  68 KSP unpreconditioned resid norm 1.552436010567e+02 true resid norm
> 1.584249134588e+02 ||r(i)||/||b|| 5.215167227548e-05
>  69 KSP unpreconditioned resid norm 1.507627069906e+02 true resid norm
> 1.530713322210e+02 ||r(i)||/||b|| 5.038933447066e-05
>  70 KSP unpreconditioned resid norm 1.503802419288e+02 true resid norm
> 1.526772130725e+02 ||r(i)||/||b|| 5.025959494786e-05
>  71 KSP unpreconditioned resid norm 1.483645684459e+02 true resid norm
> 1.509599328686e+02 ||r(i)||/||b|| 4.969428591633e-05
>  72 KSP unpreconditioned resid norm 1.481979533059e+02 true resid norm
> 1.535340885300e+02 ||r(i)||/||b|| 5.054166856281e-05
>  73 KSP unpreconditioned resid norm 1.481400704979e+02 true resid norm
> 1.509082933863e+02 ||r(i)||/||b|| 4.967728678847e-05
>  74 KSP unpreconditioned resid norm 1.481132272449e+02 true resid norm
> 1.513298398754e+02 ||r(i)||/||b|| 4.981605507858e-05
>  75 KSP unpreconditioned resid norm 1.481101708026e+02 true resid norm
> 1.502466334943e+02 ||r(i)||/||b|| 4.945947590828e-05
>  76 KSP unpreconditioned resid norm 1.481010335860e+02 true resid norm
> 1.533384206564e+02 ||r(i)||/||b|| 5.047725693339e-05
>  77 KSP unpreconditioned resid norm 1.480865328511e+02 true resid norm
> 1.508354096349e+02 ||r(i)||/||b|| 4.965329428986e-05
>  78 KSP unpreconditioned resid norm 1.480582653674e+02 true resid norm
> 1.493335938981e+02 ||r(i)||/||b|| 4.915891370027e-05
>  79 KSP unpreconditioned resid norm 1.480031554288e+02 true resid norm
> 1.505131104808e+02 ||r(i)||/||b|| 4.954719708903e-05
>  80 KSP unpreconditioned resid norm 1.479574822714e+02 true resid norm
> 1.540226621640e+02 ||r(i)||/||b|| 5.070250142355e-05
>  81 KSP unpreconditioned resid norm 1.479574535946e+02 true resid norm
> 1.498368142318e+02 ||r(i)||/||b|| 4.932456808727e-05
>  82 KSP unpreconditioned resid norm 1.479436001532e+02 true resid norm
> 1.512355315895e+02 ||r(i)||/||b|| 4.978500986785e-05
>  83 KSP unpreconditioned resid norm 1.479410419985e+02 true resid norm
> 1.513924042216e+02 ||r(i)||/||b|| 4.983665054686e-05
>  84 KSP unpreconditioned resid norm 1.477087197314e+02 true resid norm
> 1.519847216835e+02 ||r(i)||/||b|| 5.003163469095e-05
>  85 KSP unpreconditioned resid norm 1.477081559094e+02 true resid norm
> 1.507153721984e+02 ||r(i)||/||b|| 4.961377933660e-05
>  86 KSP unpreconditioned resid norm 1.476420890986e+02 true resid norm
> 1.512147907360e+02 ||r(i)||/||b|| 4.977818221576e-05
>  87 KSP unpreconditioned resid norm 1.476086929880e+02 true resid norm
> 1.508513380647e+02 ||r(i)||/||b|| 4.965853774704e-05
>  88 KSP unpreconditioned resid norm 1.475729830724e+02 true resid norm
> 1.521640656963e+02 ||r(i)||/||b|| 5.009067269183e-05
>  89 KSP unpreconditioned resid norm 1.472338605465e+02 true resid norm
> 1.506094588356e+02 ||r(i)||/||b|| 4.957891386713e-05
>  90 KSP unpreconditioned resid norm 1.472079944867e+02 true resid norm
> 1.504582871439e+02 ||r(i)||/||b|| 4.952914987262e-05
>  91 KSP unpreconditioned resid norm 1.469363056078e+02 true resid norm
> 1.506425446156e+02 ||r(i)||/||b|| 4.958980532804e-05
>  92 KSP unpreconditioned resid norm 1.469110799022e+02 true resid norm
> 1.509842019134e+02 ||r(i)||/||b|| 4.970227500870e-05
>  93 KSP unpreconditioned resid norm 1.468779696240e+02 true resid norm
> 1.501105195969e+02 ||r(i)||/||b|| 4.941466876770e-05
>  94 KSP unpreconditioned resid norm 1.468777757710e+02 true resid norm
> 1.491460779150e+02 ||r(i)||/||b|| 4.909718558007e-05
>  95 KSP unpreconditioned resid norm 1.468774588833e+02 true resid norm
> 1.519041612996e+02 ||r(i)||/||b|| 5.000511513258e-05
>  96 KSP unpreconditioned resid norm 1.468771672305e+02 true resid norm
> 1.508986277767e+02 ||r(i)||/||b|| 4.967410498018e-05
>  97 KSP unpreconditioned resid norm 1.468771086724e+02 true resid norm
> 1.500987040931e+02 ||r(i)||/||b|| 4.941077923878e-05
>  98 KSP unpreconditioned resid norm 1.468769529855e+02 true resid norm
> 1.509749203169e+02 ||r(i)||/||b|| 4.969921961314e-05
>  99 KSP unpreconditioned resid norm 1.468539019917e+02 true resid norm
> 1.505087391266e+02 ||r(i)||/||b|| 4.954575808916e-05
> 100 KSP unpreconditioned resid norm 1.468527260351e+02 true resid norm
> 1.519470484364e+02 ||r(i)||/||b|| 5.001923308823e-05
> 101 KSP unpreconditioned resid norm 1.468342327062e+02 true resid norm
> 1.489814197970e+02 ||r(i)||/||b|| 4.904298200804e-05
> 102 KSP unpreconditioned resid norm 1.468333201903e+02 true resid norm
> 1.491479405434e+02 ||r(i)||/||b|| 4.909779873608e-05
> 103 KSP unpreconditioned resid norm 1.468287736823e+02 true resid norm
> 1.496401088908e+02 ||r(i)||/||b|| 4.925981493540e-05
> 104 KSP unpreconditioned resid norm 1.468269778777e+02 true resid norm
> 1.509676608058e+02 ||r(i)||/||b|| 4.969682986500e-05
> 105 KSP unpreconditioned resid norm 1.468214752527e+02 true resid norm
> 1.500441644659e+02 ||r(i)||/||b|| 4.939282541636e-05
> 106 KSP unpreconditioned resid norm 1.468208033546e+02 true resid norm
> 1.510964155942e+02 ||r(i)||/||b|| 4.973921447094e-05
> 107 KSP unpreconditioned resid norm 1.467590018852e+02 true resid norm
> 1.512302088409e+02 ||r(i)||/||b|| 4.978325767980e-05
> 108 KSP unpreconditioned resid norm 1.467588908565e+02 true resid norm
> 1.501053278370e+02 ||r(i)||/||b|| 4.941295969963e-05
> 109 KSP unpreconditioned resid norm 1.467570731153e+02 true resid norm
> 1.485494378220e+02 ||r(i)||/||b|| 4.890077847519e-05
> 110 KSP unpreconditioned resid norm 1.467399860352e+02 true resid norm
> 1.504418099302e+02 ||r(i)||/||b|| 4.952372576205e-05
> 111 KSP unpreconditioned resid norm 1.467095654863e+02 true resid norm
> 1.507288583410e+02 ||r(i)||/||b|| 4.961821882075e-05
> 112 KSP unpreconditioned resid norm 1.467065865602e+02 true resid norm
> 1.517786399520e+02 ||r(i)||/||b|| 4.996379493842e-05
> 113 KSP unpreconditioned resid norm 1.466898232510e+02 true resid norm
> 1.491434236258e+02 ||r(i)||/||b|| 4.909631181838e-05
> 114 KSP unpreconditioned resid norm 1.466897921426e+02 true resid norm
> 1.505605420512e+02 ||r(i)||/||b|| 4.956281102033e-05
> 115 KSP unpreconditioned resid norm 1.466593121787e+02 true resid norm
> 1.500608650677e+02 ||r(i)||/||b|| 4.939832306376e-05
> 116 KSP unpreconditioned resid norm 1.466590894710e+02 true resid norm
> 1.503102560128e+02 ||r(i)||/||b|| 4.948041971478e-05
> 117 KSP unpreconditioned resid norm 1.465338856917e+02 true resid norm
> 1.501331730933e+02 ||r(i)||/||b|| 4.942212604002e-05
> 118 KSP unpreconditioned resid norm 1.464192893188e+02 true resid norm
> 1.505131429801e+02 ||r(i)||/||b|| 4.954720778744e-05
> 119 KSP unpreconditioned resid norm 1.463859793112e+02 true resid norm
> 1.504355712014e+02 ||r(i)||/||b|| 4.952167204377e-05
> 120 KSP unpreconditioned resid norm 1.459254939182e+02 true resid norm
> 1.526513923221e+02 ||r(i)||/||b|| 5.025109505170e-05
> 121 KSP unpreconditioned resid norm 1.456973020864e+02 true resid norm
> 1.496897691500e+02 ||r(i)||/||b|| 4.927616252562e-05
> 122 KSP unpreconditioned resid norm 1.456904663212e+02 true resid norm
> 1.488752755634e+02 ||r(i)||/||b|| 4.900804053853e-05
> 123 KSP unpreconditioned resid norm 1.449254956591e+02 true resid norm
> 1.494048196254e+02 ||r(i)||/||b|| 4.918236039628e-05
> 124 KSP unpreconditioned resid norm 1.448408616171e+02 true resid norm
> 1.507801939332e+02 ||r(i)||/||b|| 4.963511791142e-05
> 125 KSP unpreconditioned resid norm 1.447662934870e+02 true resid norm
> 1.495157701445e+02 ||r(i)||/||b|| 4.921888404010e-05
> 126 KSP unpreconditioned resid norm 1.446934748257e+02 true resid norm
> 1.511098625097e+02 ||r(i)||/||b|| 4.974364104196e-05
> 127 KSP unpreconditioned resid norm 1.446892504333e+02 true resid norm
> 1.493367018275e+02 ||r(i)||/||b|| 4.915993679512e-05
> 128 KSP unpreconditioned resid norm 1.446838883996e+02 true resid norm
> 1.510097796622e+02 ||r(i)||/||b|| 4.971069491153e-05
> 129 KSP unpreconditioned resid norm 1.446696373784e+02 true resid norm
> 1.463776964101e+02 ||r(i)||/||b|| 4.818586600396e-05
> 130 KSP unpreconditioned resid norm 1.446690766798e+02 true resid norm
> 1.495018999638e+02 ||r(i)||/||b|| 4.921431813499e-05
> 131 KSP unpreconditioned resid norm 1.446480744133e+02 true resid norm
> 1.499605592408e+02 ||r(i)||/||b|| 4.936530353102e-05
> 132 KSP unpreconditioned resid norm 1.446220543422e+02 true resid norm
> 1.498225445439e+02 ||r(i)||/||b|| 4.931987066895e-05
> 133 KSP unpreconditioned resid norm 1.446156526760e+02 true resid norm
> 1.481441673781e+02 ||r(i)||/||b|| 4.876736807329e-05
> 134 KSP unpreconditioned resid norm 1.446152477418e+02 true resid norm
> 1.501616466283e+02 ||r(i)||/||b|| 4.943149920257e-05
> 135 KSP unpreconditioned resid norm 1.445744489044e+02 true resid norm
> 1.505958339620e+02 ||r(i)||/||b|| 4.957442871432e-05
> 136 KSP unpreconditioned resid norm 1.445307936181e+02 true resid norm
> 1.502091787932e+02 ||r(i)||/||b|| 4.944714624841e-05
> 137 KSP unpreconditioned resid norm 1.444543817248e+02 true resid norm
> 1.491871661616e+02 ||r(i)||/||b|| 4.911071136162e-05
> 138 KSP unpreconditioned resid norm 1.444176915911e+02 true resid norm
> 1.478091693367e+02 ||r(i)||/||b|| 4.865709054379e-05
> 139 KSP unpreconditioned resid norm 1.444173719058e+02 true resid norm
> 1.495962731374e+02 ||r(i)||/||b|| 4.924538470600e-05
> 140 KSP unpreconditioned resid norm 1.444075340820e+02 true resid norm
> 1.515103203654e+02 ||r(i)||/||b|| 4.987546719477e-05
> 141 KSP unpreconditioned resid norm 1.444050342939e+02 true resid norm
> 1.498145746307e+02 ||r(i)||/||b|| 4.931724706454e-05
> 142 KSP unpreconditioned resid norm 1.443757787691e+02 true resid norm
> 1.492291154146e+02 ||r(i)||/||b|| 4.912452057664e-05
> 143 KSP unpreconditioned resid norm 1.440588930707e+02 true resid norm
> 1.485032724987e+02 ||r(i)||/||b|| 4.888558137795e-05
> 144 KSP unpreconditioned resid norm 1.438299468441e+02 true resid norm
> 1.506129385276e+02 ||r(i)||/||b|| 4.958005934200e-05
> 145 KSP unpreconditioned resid norm 1.434543079403e+02 true resid norm
> 1.471733741230e+02 ||r(i)||/||b|| 4.844779402032e-05
> 146 KSP unpreconditioned resid norm 1.433157223870e+02 true resid norm
> 1.481025707968e+02 ||r(i)||/||b|| 4.875367495378e-05
> 147 KSP unpreconditioned resid norm 1.430111913458e+02 true resid norm
> 1.485000481919e+02 ||r(i)||/||b|| 4.888451997299e-05
> 148 KSP unpreconditioned resid norm 1.430056153071e+02 true resid norm
> 1.496425172884e+02 ||r(i)||/||b|| 4.926060775239e-05
> 149 KSP unpreconditioned resid norm 1.429327762233e+02 true resid norm
> 1.467613264791e+02 ||r(i)||/||b|| 4.831215264157e-05
> 150 KSP unpreconditioned resid norm 1.424230217603e+02 true resid norm
> 1.460277537447e+02 ||r(i)||/||b|| 4.807066887493e-05
> 151 KSP unpreconditioned resid norm 1.421912821676e+02 true resid norm
> 1.470486188164e+02 ||r(i)||/||b|| 4.840672599809e-05
> 152 KSP unpreconditioned resid norm 1.420344275315e+02 true resid norm
> 1.481536901943e+02 ||r(i)||/||b|| 4.877050287565e-05
> 153 KSP unpreconditioned resid norm 1.420071178597e+02 true resid norm
> 1.450813684108e+02 ||r(i)||/||b|| 4.775912963085e-05
> 154 KSP unpreconditioned resid norm 1.419367456470e+02 true resid norm
> 1.472052819440e+02 ||r(i)||/||b|| 4.845829771059e-05
> 155 KSP unpreconditioned resid norm 1.419032748919e+02 true resid norm
> 1.479193155584e+02 ||r(i)||/||b|| 4.869334942209e-05
> 156 KSP unpreconditioned resid norm 1.418899781440e+02 true resid norm
> 1.478677351572e+02 ||r(i)||/||b|| 4.867636974307e-05
> 157 KSP unpreconditioned resid norm 1.418895621075e+02 true resid norm
> 1.455168237674e+02 ||r(i)||/||b|| 4.790247656128e-05
> 158 KSP unpreconditioned resid norm 1.418061469023e+02 true resid norm
> 1.467147028974e+02 ||r(i)||/||b|| 4.829680469093e-05
> 159 KSP unpreconditioned resid norm 1.417948698213e+02 true resid norm
> 1.478376854834e+02 ||r(i)||/||b|| 4.866647773362e-05
> 160 KSP unpreconditioned resid norm 1.415166832324e+02 true resid norm
> 1.475436433192e+02 ||r(i)||/||b|| 4.856968241116e-05
> 161 KSP unpreconditioned resid norm 1.414939087573e+02 true resid norm
> 1.468361945080e+02 ||r(i)||/||b|| 4.833679834170e-05
> 162 KSP unpreconditioned resid norm 1.414544622036e+02 true resid norm
> 1.475730757600e+02 ||r(i)||/||b|| 4.857937123456e-05
> 163 KSP unpreconditioned resid norm 1.413780373982e+02 true resid norm
> 1.463891808066e+02 ||r(i)||/||b|| 4.818964653614e-05
> 164 KSP unpreconditioned resid norm 1.413741853943e+02 true resid norm
> 1.481999741168e+02 ||r(i)||/||b|| 4.878573901436e-05
> 165 KSP unpreconditioned resid norm 1.413725682642e+02 true resid norm
> 1.458413423932e+02 ||r(i)||/||b|| 4.800930438685e-05
> 166 KSP unpreconditioned resid norm 1.412970845566e+02 true resid norm
> 1.481492296610e+02 ||r(i)||/||b|| 4.876903451901e-05
> 167 KSP unpreconditioned resid norm 1.410100899597e+02 true resid norm
> 1.468338434340e+02 ||r(i)||/||b|| 4.833602439497e-05
> 168 KSP unpreconditioned resid norm 1.409983320599e+02 true resid norm
> 1.485378957202e+02 ||r(i)||/||b|| 4.889697894709e-05
> 169 KSP unpreconditioned resid norm 1.407688141293e+02 true resid norm
> 1.461003623074e+02 ||r(i)||/||b|| 4.809457078458e-05
> 170 KSP unpreconditioned resid norm 1.407072771004e+02 true resid norm
> 1.463217409181e+02 ||r(i)||/||b|| 4.816744609502e-05
> 171 KSP unpreconditioned resid norm 1.407069670790e+02 true resid norm
> 1.464695099700e+02 ||r(i)||/||b|| 4.821608997937e-05
> 172 KSP unpreconditioned resid norm 1.402361094414e+02 true resid norm
> 1.493786053835e+02 ||r(i)||/||b|| 4.917373096721e-05
> 173 KSP unpreconditioned resid norm 1.400618325859e+02 true resid norm
> 1.465475533254e+02 ||r(i)||/||b|| 4.824178096070e-05
> 174 KSP unpreconditioned resid norm 1.400573078320e+02 true resid norm
> 1.471993735980e+02 ||r(i)||/||b|| 4.845635275056e-05
> 175 KSP unpreconditioned resid norm 1.400258865388e+02 true resid norm
> 1.479779387468e+02 ||r(i)||/||b|| 4.871264750624e-05
> 176 KSP unpreconditioned resid norm 1.396589283831e+02 true resid norm
> 1.476626943974e+02 ||r(i)||/||b|| 4.860887266654e-05
> 177 KSP unpreconditioned resid norm 1.395796112440e+02 true resid norm
> 1.443093901655e+02 ||r(i)||/||b|| 4.750500320860e-05
> 178 KSP unpreconditioned resid norm 1.394749154493e+02 true resid norm
> 1.447914005206e+02 ||r(i)||/||b|| 4.766367551289e-05
> 179 KSP unpreconditioned resid norm 1.394476969416e+02 true resid norm
> 1.455635964329e+02 ||r(i)||/||b|| 4.791787358864e-05
> 180 KSP unpreconditioned resid norm 1.391990722790e+02 true resid norm
> 1.457511594620e+02 ||r(i)||/||b|| 4.797961719582e-05
> 181 KSP unpreconditioned resid norm 1.391686315799e+02 true resid norm
> 1.460567495143e+02 ||r(i)||/||b|| 4.808021395114e-05
> 182 KSP unpreconditioned resid norm 1.387654475794e+02 true resid norm
> 1.468215388414e+02 ||r(i)||/||b|| 4.833197386362e-05
> 183 KSP unpreconditioned resid norm 1.384925240232e+02 true resid norm
> 1.456091052791e+02 ||r(i)||/||b|| 4.793285458106e-05
> 184 KSP unpreconditioned resid norm 1.378003249970e+02 true resid norm
> 1.453421051371e+02 ||r(i)||/||b|| 4.784496118351e-05
> 185 KSP unpreconditioned resid norm 1.377904214978e+02 true resid norm
> 1.441752187090e+02 ||r(i)||/||b|| 4.746083549740e-05
> 186 KSP unpreconditioned resid norm 1.376670282479e+02 true resid norm
> 1.441674745344e+02 ||r(i)||/||b|| 4.745828620353e-05
> 187 KSP unpreconditioned resid norm 1.376636051755e+02 true resid norm
> 1.463118783906e+02 ||r(i)||/||b|| 4.816419946362e-05
> 188 KSP unpreconditioned resid norm 1.363148994276e+02 true resid norm
> 1.432997756128e+02 ||r(i)||/||b|| 4.717264962781e-05
> 189 KSP unpreconditioned resid norm 1.363051099558e+02 true resid norm
> 1.451009062639e+02 ||r(i)||/||b|| 4.776556126897e-05
> 190 KSP unpreconditioned resid norm 1.362538398564e+02 true resid norm
> 1.438957985476e+02 ||r(i)||/||b|| 4.736885357127e-05
> 191 KSP unpreconditioned resid norm 1.358335705250e+02 true resid norm
> 1.436616069458e+02 ||r(i)||/||b|| 4.729176037047e-05
> 192 KSP unpreconditioned resid norm 1.337424103882e+02 true resid norm
> 1.432816138672e+02 ||r(i)||/||b|| 4.716667098856e-05
> 193 KSP unpreconditioned resid norm 1.337419543121e+02 true resid norm
> 1.405274691954e+02 ||r(i)||/||b|| 4.626003801533e-05
> 194 KSP unpreconditioned resid norm 1.322568117657e+02 true resid norm
> 1.417123189671e+02 ||r(i)||/||b|| 4.665007702902e-05
> 195 KSP unpreconditioned resid norm 1.320880115122e+02 true resid norm
> 1.413658215058e+02 ||r(i)||/||b|| 4.653601402181e-05
> 196 KSP unpreconditioned resid norm 1.312526182172e+02 true resid norm
> 1.420574070412e+02 ||r(i)||/||b|| 4.676367608204e-05
> 197 KSP unpreconditioned resid norm 1.311651332692e+02 true resid norm
> 1.398984125128e+02 ||r(i)||/||b|| 4.605295973934e-05
> 198 KSP unpreconditioned resid norm 1.294482397720e+02 true resid norm
> 1.380390703259e+02 ||r(i)||/||b|| 4.544088552537e-05
> 199 KSP unpreconditioned resid norm 1.293598434732e+02 true resid norm
> 1.373830689903e+02 ||r(i)||/||b|| 4.522493737731e-05
> 200 KSP unpreconditioned resid norm 1.265165992897e+02 true resid norm
> 1.375015523244e+02 ||r(i)||/||b|| 4.526394073779e-05
> 201 KSP unpreconditioned resid norm 1.263813235463e+02 true resid norm
> 1.356820166419e+02 ||r(i)||/||b|| 4.466497037047e-05
> 202 KSP unpreconditioned resid norm 1.243190164198e+02 true resid norm
> 1.366420975402e+02 ||r(i)||/||b|| 4.498101803792e-05
> 203 KSP unpreconditioned resid norm 1.230747513665e+02 true resid norm
> 1.348856851681e+02 ||r(i)||/||b|| 4.440282714351e-05
> 204 KSP unpreconditioned resid norm 1.198014010398e+02 true resid norm
> 1.325188356617e+02 ||r(i)||/||b|| 4.362368731578e-05
> 205 KSP unpreconditioned resid norm 1.195977240348e+02 true resid norm
> 1.299721846860e+02 ||r(i)||/||b|| 4.278535889769e-05
> 206 KSP unpreconditioned resid norm 1.130620928393e+02 true resid norm
> 1.266961052950e+02 ||r(i)||/||b|| 4.170691097546e-05
> 207 KSP unpreconditioned resid norm 1.123992882530e+02 true resid norm
> 1.270907813369e+02 ||r(i)||/||b|| 4.183683382120e-05
> 208 KSP unpreconditioned resid norm 1.063236317163e+02 true resid norm
> 1.182163029843e+02 ||r(i)||/||b|| 3.891545689533e-05
> 209 KSP unpreconditioned resid norm 1.059802897214e+02 true resid norm
> 1.187516613498e+02 ||r(i)||/||b|| 3.909169075539e-05
> 210 KSP unpreconditioned resid norm 9.878733567790e+01 true resid norm
> 1.124812677115e+02 ||r(i)||/||b|| 3.702754877846e-05
> 211 KSP unpreconditioned resid norm 9.861048081032e+01 true resid norm
> 1.117192174341e+02 ||r(i)||/||b|| 3.677669052986e-05
> 212 KSP unpreconditioned resid norm 9.169383217455e+01 true resid norm
> 1.102172324977e+02 ||r(i)||/||b|| 3.628225424167e-05
> 213 KSP unpreconditioned resid norm 9.146164223196e+01 true resid norm
> 1.121134424773e+02 ||r(i)||/||b|| 3.690646491198e-05
> 214 KSP unpreconditioned resid norm 8.692213412954e+01 true resid norm
> 1.056264039532e+02 ||r(i)||/||b|| 3.477100591276e-05
> 215 KSP unpreconditioned resid norm 8.685846611574e+01 true resid norm
> 1.029018845366e+02 ||r(i)||/||b|| 3.387412523521e-05
> 216 KSP unpreconditioned resid norm 7.808516472373e+01 true resid norm
> 9.749023000535e+01 ||r(i)||/||b|| 3.209267036539e-05
> 217 KSP unpreconditioned resid norm 7.786400257086e+01 true resid norm
> 1.004515546585e+02 ||r(i)||/||b|| 3.306750462244e-05
> 218 KSP unpreconditioned resid norm 6.646475864029e+01 true resid norm
> 9.429020541969e+01 ||r(i)||/||b|| 3.103925881653e-05
> 219 KSP unpreconditioned resid norm 6.643821996375e+01 true resid norm
> 8.864525788550e+01 ||r(i)||/||b|| 2.918100655438e-05
> 220 KSP unpreconditioned resid norm 5.625046780791e+01 true resid norm
> 8.410041684883e+01 ||r(i)||/||b|| 2.768489678784e-05
> 221 KSP unpreconditioned resid norm 5.623343238032e+01 true resid norm
> 8.815552919640e+01 ||r(i)||/||b|| 2.901979346270e-05
> 222 KSP unpreconditioned resid norm 4.491016868776e+01 true resid norm
> 8.557052117768e+01 ||r(i)||/||b|| 2.816883834410e-05
> 223 KSP unpreconditioned resid norm 4.461976108543e+01 true resid norm
> 7.867894425332e+01 ||r(i)||/||b|| 2.590020992340e-05
> 224 KSP unpreconditioned resid norm 3.535718264955e+01 true resid norm
> 7.609346753983e+01 ||r(i)||/||b|| 2.504910051583e-05
> 225 KSP unpreconditioned resid norm 3.525592897743e+01 true resid norm
> 7.926812413349e+01 ||r(i)||/||b|| 2.609416121143e-05
> 226 KSP unpreconditioned resid norm 2.633469451114e+01 true resid norm
> 7.883483297310e+01 ||r(i)||/||b|| 2.595152670968e-05
> 227 KSP unpreconditioned resid norm 2.614440577316e+01 true resid norm
> 7.398963634249e+01 ||r(i)||/||b|| 2.435654331172e-05
> 228 KSP unpreconditioned resid norm 1.988460252721e+01 true resid norm
> 7.147825835126e+01 ||r(i)||/||b|| 2.352982635730e-05
> 229 KSP unpreconditioned resid norm 1.975927240058e+01 true resid norm
> 7.488507147714e+01 ||r(i)||/||b|| 2.465131033205e-05
> 230 KSP unpreconditioned resid norm 1.505732242656e+01 true resid norm
> 7.888901529160e+01 ||r(i)||/||b|| 2.596936291016e-05
> 231 KSP unpreconditioned resid norm 1.504120870628e+01 true resid norm
> 7.126366562975e+01 ||r(i)||/||b|| 2.345918488406e-05
> 232 KSP unpreconditioned resid norm 1.163470506257e+01 true resid norm
> 7.142763663542e+01 ||r(i)||/||b|| 2.351316226655e-05
> 233 KSP unpreconditioned resid norm 1.157114340949e+01 true resid norm
> 7.464790352976e+01 ||r(i)||/||b|| 2.457323735226e-05
> 234 KSP unpreconditioned resid norm 8.702850618357e+00 true resid norm
> 7.798031063059e+01 ||r(i)||/||b|| 2.567022771329e-05
> 235 KSP unpreconditioned resid norm 8.702017371082e+00 true resid norm
> 7.032943782131e+01 ||r(i)||/||b|| 2.315164775854e-05
> 236 KSP unpreconditioned resid norm 6.422855779486e+00 true resid norm
> 6.800345168870e+01 ||r(i)||/||b|| 2.238595968678e-05
> 237 KSP unpreconditioned resid norm 6.413921210094e+00 true resid norm
> 7.408432731879e+01 ||r(i)||/||b|| 2.438771449973e-05
> 238 KSP unpreconditioned resid norm 4.949111361190e+00 true resid norm
> 7.744087979524e+01 ||r(i)||/||b|| 2.549265324267e-05
> 239 KSP unpreconditioned resid norm 4.947369357666e+00 true resid norm
> 7.104259266677e+01 ||r(i)||/||b|| 2.338641018933e-05
> 240 KSP unpreconditioned resid norm 3.873645232239e+00 true resid norm
> 6.908028336929e+01 ||r(i)||/||b|| 2.274044037845e-05
> 241 KSP unpreconditioned resid norm 3.841473653930e+00 true resid norm
> 7.431718972562e+01 ||r(i)||/||b|| 2.446437014474e-05
> 242 KSP unpreconditioned resid norm 3.057267436362e+00 true resid norm
> 7.685939322732e+01 ||r(i)||/||b|| 2.530123450517e-05
> 243 KSP unpreconditioned resid norm 2.980906717815e+00 true resid norm
> 6.975661521135e+01 ||r(i)||/||b|| 2.296308109705e-05
> 244 KSP unpreconditioned resid norm 2.415633545154e+00 true resid norm
> 6.989644258184e+01 ||r(i)||/||b|| 2.300911067057e-05
> 245 KSP unpreconditioned resid norm 2.363923146996e+00 true resid norm
> 7.486631867276e+01 ||r(i)||/||b|| 2.464513712301e-05
> 246 KSP unpreconditioned resid norm 1.947823635306e+00 true resid norm
> 7.671103669547e+01 ||r(i)||/||b|| 2.525239722914e-05
> 247 KSP unpreconditioned resid norm 1.942156637334e+00 true resid norm
> 6.835715877902e+01 ||r(i)||/||b|| 2.250239602152e-05
> 248 KSP unpreconditioned resid norm 1.675749569790e+00 true resid norm
> 7.111781390782e+01 ||r(i)||/||b|| 2.341117216285e-05
> 249 KSP unpreconditioned resid norm 1.673819729570e+00 true resid norm
> 7.552508026111e+01 ||r(i)||/||b|| 2.486199391474e-05
> 250 KSP unpreconditioned resid norm 1.453311843294e+00 true resid norm
> 7.639099426865e+01 ||r(i)||/||b|| 2.514704291716e-05
> 251 KSP unpreconditioned resid norm 1.452846325098e+00 true resid norm
> 6.951401359923e+01 ||r(i)||/||b|| 2.288321941689e-05
> 252 KSP unpreconditioned resid norm 1.335008887441e+00 true resid norm
> 6.912230871414e+01 ||r(i)||/||b|| 2.275427464204e-05
> 253 KSP unpreconditioned resid norm 1.334477013356e+00 true resid norm
> 7.412281497148e+01 ||r(i)||/||b|| 2.440038419546e-05
> 254 KSP unpreconditioned resid norm 1.248507835050e+00 true resid norm
> 7.801932499175e+01 ||r(i)||/||b|| 2.568307079543e-05
> 255 KSP unpreconditioned resid norm 1.248246596771e+00 true resid norm
> 7.094899926215e+01 ||r(i)||/||b|| 2.335560030938e-05
> 256 KSP unpreconditioned resid norm 1.208952722414e+00 true resid norm
> 7.101235824005e+01 ||r(i)||/||b|| 2.337645736134e-05
> 257 KSP unpreconditioned resid norm 1.208780664971e+00 true resid norm
> 7.562936418444e+01 ||r(i)||/||b|| 2.489632299136e-05
> 258 KSP unpreconditioned resid norm 1.179956701653e+00 true resid norm
> 7.812300941072e+01 ||r(i)||/||b|| 2.571720252207e-05
> 259 KSP unpreconditioned resid norm 1.179219541297e+00 true resid norm
> 7.131201918549e+01 ||r(i)||/||b|| 2.347510232240e-05
> 260 KSP unpreconditioned resid norm 1.160215487467e+00 true resid norm
> 7.222079766175e+01 ||r(i)||/||b|| 2.377426181841e-05
> 261 KSP unpreconditioned resid norm 1.159115040554e+00 true resid norm
> 7.481372509179e+01 ||r(i)||/||b|| 2.462782391678e-05
> 262 KSP unpreconditioned resid norm 1.151973184765e+00 true resid norm
> 7.709040836137e+01 ||r(i)||/||b|| 2.537728204907e-05
> 263 KSP unpreconditioned resid norm 1.150882463576e+00 true resid norm
> 7.032588895526e+01 ||r(i)||/||b|| 2.315047951236e-05
> 264 KSP unpreconditioned resid norm 1.137617003277e+00 true resid norm
> 7.004055871264e+01 ||r(i)||/||b|| 2.305655205500e-05
> 265 KSP unpreconditioned resid norm 1.137134003401e+00 true resid norm
> 7.610459827221e+01 ||r(i)||/||b|| 2.505276462582e-05
> 266 KSP unpreconditioned resid norm 1.131425778253e+00 true resid norm
> 7.852741072990e+01 ||r(i)||/||b|| 2.585032681802e-05
> 267 KSP unpreconditioned resid norm 1.131176695314e+00 true resid norm
> 7.064571495865e+01 ||r(i)||/||b|| 2.325576258022e-05
> 268 KSP unpreconditioned resid norm 1.125420065063e+00 true resid norm
> 7.138837220124e+01 ||r(i)||/||b|| 2.350023686323e-05
> 269 KSP unpreconditioned resid norm 1.124779989266e+00 true resid norm
> 7.585594020759e+01 ||r(i)||/||b|| 2.497090923065e-05
> 270 KSP unpreconditioned resid norm 1.119805446125e+00 true resid norm
> 7.703631305135e+01 ||r(i)||/||b|| 2.535947449079e-05
> 271 KSP unpreconditioned resid norm 1.119024433863e+00 true resid norm
> 7.081439585094e+01 ||r(i)||/||b|| 2.331129040360e-05
> 272 KSP unpreconditioned resid norm 1.115694452861e+00 true resid norm
> 7.134872343512e+01 ||r(i)||/||b|| 2.348718494222e-05
> 273 KSP unpreconditioned resid norm 1.113572716158e+00 true resid norm
> 7.600475566242e+01 ||r(i)||/||b|| 2.501989757889e-05
> 274 KSP unpreconditioned resid norm 1.108711406381e+00 true resid norm
> 7.738835220359e+01 ||r(i)||/||b|| 2.547536175937e-05
> 275 KSP unpreconditioned resid norm 1.107890435549e+00 true resid norm
> 7.093429729336e+01 ||r(i)||/||b|| 2.335076058915e-05
> 276 KSP unpreconditioned resid norm 1.103340227961e+00 true resid norm
> 7.145267197866e+01 ||r(i)||/||b|| 2.352140361564e-05
> 277 KSP unpreconditioned resid norm 1.102897652964e+00 true resid norm
> 7.448617654625e+01 ||r(i)||/||b|| 2.451999867624e-05
> 278 KSP unpreconditioned resid norm 1.102576754158e+00 true resid norm
> 7.707165090465e+01 ||r(i)||/||b|| 2.537110730854e-05
> 279 KSP unpreconditioned resid norm 1.102564028537e+00 true resid norm
> 7.009637628868e+01 ||r(i)||/||b|| 2.307492656359e-05
> 280 KSP unpreconditioned resid norm 1.100828424712e+00 true resid norm
> 7.059832880916e+01 ||r(i)||/||b|| 2.324016360096e-05
> 281 KSP unpreconditioned resid norm 1.100686341559e+00 true resid norm
> 7.460867988528e+01 ||r(i)||/||b|| 2.456032537644e-05
> 282 KSP unpreconditioned resid norm 1.099417185996e+00 true resid norm
> 7.763784632467e+01 ||r(i)||/||b|| 2.555749237477e-05
> 283 KSP unpreconditioned resid norm 1.099379061087e+00 true resid norm
> 7.017139420999e+01 ||r(i)||/||b|| 2.309962160657e-05
> 284 KSP unpreconditioned resid norm 1.097928047676e+00 true resid norm
> 6.983706716123e+01 ||r(i)||/||b|| 2.298956496018e-05
> 285 KSP unpreconditioned resid norm 1.096490152934e+00 true resid norm
> 7.414445779601e+01 ||r(i)||/||b|| 2.440750876614e-05
> 286 KSP unpreconditioned resid norm 1.094691490227e+00 true resid norm
> 7.634526287231e+01 ||r(i)||/||b|| 2.513198866374e-05
> 287 KSP unpreconditioned resid norm 1.093560358328e+00 true resid norm
> 7.003716824146e+01 ||r(i)||/||b|| 2.305543595061e-05
> 288 KSP unpreconditioned resid norm 1.093357856424e+00 true resid norm
> 6.964715939684e+01 ||r(i)||/||b|| 2.292704949292e-05
> 289 KSP unpreconditioned resid norm 1.091881434739e+00 true resid norm
> 7.429955169250e+01 ||r(i)||/||b|| 2.445856390566e-05
> 290 KSP unpreconditioned resid norm 1.091817808496e+00 true resid norm
> 7.607892786798e+01 ||r(i)||/||b|| 2.504431422190e-05
> 291 KSP unpreconditioned resid norm 1.090295101202e+00 true resid norm
> 6.942248339413e+01 ||r(i)||/||b|| 2.285308871866e-05
> 292 KSP unpreconditioned resid norm 1.089995012773e+00 true resid norm
> 6.995557798353e+01 ||r(i)||/||b|| 2.302857736947e-05
> 293 KSP unpreconditioned resid norm 1.089975910578e+00 true resid norm
> 7.453210925277e+01 ||r(i)||/||b|| 2.453511919866e-05
> 294 KSP unpreconditioned resid norm 1.085570944646e+00 true resid norm
> 7.629598425927e+01 ||r(i)||/||b|| 2.511576670710e-05
> 295 KSP unpreconditioned resid norm 1.085363565621e+00 true resid norm
> 7.025539955712e+01 ||r(i)||/||b|| 2.312727520749e-05
> 296 KSP unpreconditioned resid norm 1.083348574106e+00 true resid norm
> 7.003219621882e+01 ||r(i)||/||b|| 2.305379921754e-05
> 297 KSP unpreconditioned resid norm 1.082180374430e+00 true resid norm
> 7.473048827106e+01 ||r(i)||/||b|| 2.460042330597e-05
> 298 KSP unpreconditioned resid norm 1.081326671068e+00 true resid norm
> 7.660142838935e+01 ||r(i)||/||b|| 2.521631542651e-05
> 299 KSP unpreconditioned resid norm 1.078679751898e+00 true resid norm
> 7.077868424247e+01 ||r(i)||/||b|| 2.329953454992e-05
> 300 KSP unpreconditioned resid norm 1.078656949888e+00 true resid norm
> 7.074960394994e+01 ||r(i)||/||b|| 2.328996164972e-05
> Linear solve did not converge due to DIVERGED_ITS iterations 300
> KSP Object: 2 MPI processes
>   type: fgmres
>     GMRES: restart=300, using Modified Gram-Schmidt Orthogonalization
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=300, initial guess is zero
>   tolerances:  relative=1e-09, absolute=1e-20, divergence=10000
>   right preconditioning
>   using UNPRECONDITIONED norm type for convergence test
> PC Object: 2 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, factorization DIAG
>     Preconditioner for the Schur complement formed from Sp, an assembled
> approximation to S, which uses (lumped, if requested) A00's diagonal's
> inverse
>     Split info:
>     Split number 0 Defined by IS
>     Split number 1 Defined by IS
>     KSP solver for A00 block
>       KSP Object:      (fieldsplit_u_)       2 MPI processes
>         type: preonly
>         maximum iterations=10000, initial guess is zero
>         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>         left preconditioning
>         using NONE norm type for convergence test
>       PC Object:      (fieldsplit_u_)       2 MPI processes
>         type: lu
>           LU: out-of-place factorization
>           tolerance for zero pivot 2.22045e-14
>           matrix ordering: natural
>           factor fill ratio given 0, needed 0
>             Factored matrix follows:
>               Mat Object:               2 MPI processes
>                 type: mpiaij
>                 rows=184326, cols=184326
>                 package used to perform factorization: mumps
>                 total: nonzeros=4.03041e+08, allocated nonzeros=4.03041e+08
>                 total number of mallocs used during MatSetValues calls =0
>                   MUMPS run parameters:
>                     SYM (matrix type):                   0
>                     PAR (host participation):            1
>                     ICNTL(1) (output for error):         6
>                     ICNTL(2) (output of diagnostic msg): 0
>                     ICNTL(3) (output for global info):   0
>                     ICNTL(4) (level of printing):        0
>                     ICNTL(5) (input mat struct):         0
>                     ICNTL(6) (matrix prescaling):        7
>                     ICNTL(7) (sequentia matrix ordering):7
>                     ICNTL(8) (scalling strategy):        77
>                     ICNTL(10) (max num of refinements):  0
>                     ICNTL(11) (error analysis):          0
>                     ICNTL(12) (efficiency control):
>   1
>                     ICNTL(13) (efficiency control):
>   0
>                     ICNTL(14) (percentage of estimated workspace
> increase): 20
>                     ICNTL(18) (input mat struct):
>   3
>                     ICNTL(19) (Shur complement info):
>   0
>                     ICNTL(20) (rhs sparse pattern):
>   0
>                     ICNTL(21) (solution struct):
>  1
>                     ICNTL(22) (in-core/out-of-core facility):
>   0
>                     ICNTL(23) (max size of memory can be allocated
> locally):0
>                     ICNTL(24) (detection of null pivot rows):
>   0
>                     ICNTL(25) (computation of a null space basis):
>  0
>                     ICNTL(26) (Schur options for rhs or solution):
>  0
>                     ICNTL(27) (experimental parameter):
>   -24
>                     ICNTL(28) (use parallel or sequential ordering):
>  1
>                     ICNTL(29) (parallel ordering):
>  0
>                     ICNTL(30) (user-specified set of entries in inv(A)):
>  0
>                     ICNTL(31) (factors is discarded in the solve phase):
>  0
>                     ICNTL(33) (compute determinant):
>  0
>                     CNTL(1) (relative pivoting threshold):      0.01
>                     CNTL(2) (stopping criterion of refinement):
> 1.49012e-08
>                     CNTL(3) (absolute pivoting threshold):      0
>                     CNTL(4) (value of static pivoting):         -1
>                     CNTL(5) (fixation for null pivots):         0
>                     RINFO(1) (local estimated flops for the elimination
> after analysis):
>                       [0] 5.59214e+11
>                       [1] 5.35237e+11
>                     RINFO(2) (local estimated flops for the assembly after
> factorization):
>                       [0]  4.2839e+08
>                       [1]  3.799e+08
>                     RINFO(3) (local estimated flops for the elimination
> after factorization):
>                       [0]  5.59214e+11
>                       [1]  5.35237e+11
>                     INFO(15) (estimated size of (in MB) MUMPS internal
> data for running numerical factorization):
>                     [0] 2621
>                     [1] 2649
>                     INFO(16) (size of (in MB) MUMPS internal data used
> during numerical factorization):
>                       [0] 2621
>                       [1] 2649
>                     INFO(23) (num of pivots eliminated on this processor
>                       [0] 90423
>                       [1] 93903
>                     RINFOG(1) (global estimated flops for the elimination
> after analysis): 1.09445e+12
>                     RINFOG(2) (global estimated flops for the assembly
> after factorization): 8.0829e+08
>                     RINFOG(3) (global estimated flops for the elimination
> after factorization): 1.09445e+12
>                     (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
> (0,0)*(2^0)
>                     INFOG(3) (estimated real workspace for factors on all
> processors after analysis): 403041366
>                     INFOG(4) (estimated integer workspace for factors on
> all processors after analysis): 2265748
>                     INFOG(5) (estimated maximum front size in the complete
> tree): 6663
>                     INFOG(6) (number of nodes in the complete tree): 2812
>                     INFOG(7) (ordering option effectively use after
> analysis): 5
>                     INFOG(8) (structural symmetry in percent of the
> permuted matrix after analysis): 100
>                     INFOG(9) (total real/complex workspace to store the
> matrix factors after factorization): 403041366
>                     INFOG(10) (total integer space store the matrix
> factors after factorization): 2265766
>                     INFOG(11) (order of largest frontal matrix after
> factorization): 6663
>                     INFOG(12) (number of off-diagonal pivots): 0
>                     INFOG(13) (number of delayed pivots after
> factorization): 0
>                     INFOG(14) (number of memory compress after
> factorization): 0
>                     INFOG(15) (number of steps of iterative refinement
> after solution): 0
>                     INFOG(16) (estimated size (in MB) of all MUMPS
> internal data for factorization after analysis: value on the most memory
> consuming processor): 2649
>                     INFOG(17) (estimated size of all MUMPS internal data
> for factorization after analysis: sum over all processors): 5270
>                     INFOG(18) (size of all MUMPS internal data allocated
> during factorization: value on the most memory consuming processor): 2649
>                     INFOG(19) (size of all MUMPS internal data allocated
> during factorization: sum over all processors): 5270
>                     INFOG(20) (estimated number of entries in the
> factors): 403041366
>                     INFOG(21) (size in MB of memory effectively used
> during factorization - value on the most memory consuming processor): 2121
>                     INFOG(22) (size in MB of memory effectively used
> during factorization - sum over all processors): 4174
>                     INFOG(23) (after analysis: value of ICNTL(6)
> effectively used): 0
>                     INFOG(24) (after analysis: value of ICNTL(12)
> effectively used): 1
>                     INFOG(25) (after factorization: number of pivots
> modified by static pivoting): 0
>                     INFOG(28) (after factorization: number of null pivots
> encountered): 0
>                     INFOG(29) (after factorization: effective number of
> entries in the factors (sum over all processors)): 403041366
>                     INFOG(30, 31) (after solution: size in Mbytes of
> memory used during solution phase): 2467, 4922
>                     INFOG(32) (after analysis: type of analysis done): 1
>                     INFOG(33) (value used for ICNTL(8)): 7
>                     INFOG(34) (exponent of the determinant if determinant
> is requested): 0
>         linear system matrix = precond matrix:
>         Mat Object:        (fieldsplit_u_)         2 MPI processes
>           type: mpiaij
>           rows=184326, cols=184326, bs=3
>           total: nonzeros=3.32649e+07, allocated nonzeros=3.32649e+07
>             using I-node (on process 0) routines: found 26829 nodes, limit
> used is 5
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object:      (fieldsplit_lu_)       2 MPI processes
>         type: preonly
>       PC Object:      (fieldsplit_lu_)       2 MPI processes
>         type: lu
>                 type: mpiaij
>                 rows=2583, cols=2583
>                 total: nonzeros=2.17621e+06, allocated nonzeros=2.17621e+06
>   1
>   0
> increase): 20
>   3
>   0
>   0
>  1
>   0
> locally):0
>   0
>  0
>  0
>   -24
>  1
>  0
>  0
>  0
>  0
> 1.49012e-08
> after analysis):
>                       [0] 5.12794e+08
>                       [1] 5.02142e+08
> factorization):
>                       [0]  815031
>                       [1]  745263
>                       [0]  5.12794e+08
>                       [1]  5.02142e+08
>                     [0] 34
>                     [1] 34
>                       [0] 34
>                       [1] 34
>                       [0] 1158
>                       [1] 1425
> after analysis): 1.01494e+09
> after factorization): 1.56029e+06
> after factorization): 1.01494e+09
> (0,0)*(2^0)
> processors after analysis): 2176209
> all processors after analysis): 14427
> tree): 699
>                     INFOG(6) (number of nodes in the complete tree): 15
> analysis): 2
> matrix factors after factorization): 2176209
> factors after factorization): 14427
> factorization): 699
> factorization): 0
> factorization): 0
> after solution): 0
> consuming processor): 34
> for factorization after analysis: sum over all processors): 68
> during factorization: value on the most memory consuming processor): 34
> during factorization: sum over all processors): 68
> factors): 2176209
> during factorization - value on the most memory consuming processor): 30
> during factorization - sum over all processors): 59
> encountered): 0
> entries in the factors (sum over all processors)): 2176209
> memory used during solution phase): 16, 32
> is requested): 0
>         linear system matrix followed by preconditioner matrix:
>         Mat Object:        (fieldsplit_lu_)         2 MPI processes
>           type: schurcomplement
>             Schur complement A11 - A10 inv(A00) A01
>             A11
> MPI processes
>                 type: mpiaij
>                 rows=2583, cols=2583, bs=3
>                 total: nonzeros=117369, allocated nonzeros=117369
>                   not using I-node (on process 0) routines
>             A10
>                 type: mpiaij
>                 rows=2583, cols=184326, rbs=3, cbs = 1
>                 total: nonzeros=292770, allocated nonzeros=292770
>             KSP of A00
> processes
>                 type: preonly
> divergence=10000
> processes
>                 type: lu
>                         type: mpiaij
> calls =0
>           1
>           0
> increase): 20
>           3
>           0
>           0
>          1
>           0
> locally):0
>           0
>          0
>          0
>           -24
> ordering):        1
>          0
> inv(A)):    0
> phase):    0
>          0
>  0.01
> 1.49012e-08
> elimination after analysis):
>                               [0] 5.59214e+11
>                               [1] 5.35237e+11
> assembly after factorization):
>                               [0]  4.2839e+08
>                               [1]  3.799e+08
> elimination after factorization):
>                               [0]  5.59214e+11
>                               [1]  5.35237e+11
> internal data for running numerical factorization):
>                             [0] 2621
>                             [1] 2649
> used during numerical factorization):
>                               [0] 2621
>                               [1] 2649
> processor after factorization):
>                               [0] 90423
>                               [1] 93903
> elimination after analysis): 1.09445e+12
> assembly after factorization): 8.0829e+08
> elimination after factorization): 1.09445e+12
> (determinant): (0,0)*(2^0)
> on all processors after analysis): 403041366
> factors on all processors after analysis): 2265748
> complete tree): 6663
> tree): 2812
> after analysis): 5
> the permuted matrix after analysis): 100
> store the matrix factors after factorization): 403041366
> matrix factors after factorization): 2265766
> after factorization): 6663
> factorization): 0
> factorization): 0
> refinement after solution): 0
> internal data for factorization after analysis: sum over all processors):
> 5270
> allocated during factorization: value on the most memory consuming
> processor): 2649
> allocated during factorization: sum over all processors): 5270
> factors): 403041366
> used during factorization - value on the most memory consuming processor):
> 2121
> used during factorization - sum over all processors): 4174
> pivots modified by static pivoting): 0
> pivots encountered): 0
> number of entries in the factors (sum over all processors)): 403041366
> of memory used during solution phase): 2467, 4922
> done): 1
> determinant is requested): 0
> 2 MPI processes
>                   type: mpiaij
> nodes, limit used is 5
>             A01
>                 type: mpiaij
>                 rows=184326, cols=2583, rbs=3, cbs = 1
>                   using I-node (on process 0) routines: found 16098 nodes,
> limit used is 5
>           type: mpiaij
>           rows=2583, cols=2583, rbs=3, cbs = 1
>           total: nonzeros=1.25158e+06, allocated nonzeros=1.25158e+06
>     type: mpiaij
>     rows=186909, cols=186909
>     total: nonzeros=3.39678e+07, allocated nonzeros=3.39678e+07
>       using I-node (on process 0) routines: found 26829 nodes, limit used
> is 5
> KSPSolve completed
> Giang
> On Sun, Apr 17, 2016 at 1:15 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Sat, Apr 16, 2016 at 6:54 PM, Hoang Giang Bui <hgbk2008 at gmail.com>
>> wrote:
>>> Hello
>>> I'm solving an indefinite problem arising from mesh tying/contact using
>>> Lagrange multiplier, the matrix has the form
>>> K = [A P^T
>>>        P   0]
>>> I used the FIELDSPLIT preconditioner with one field is the main variable
>>> (displacement) and the other field for dual variable (Lagrange multiplier).
>>> The block size for each field is 3. According to the manual, I first chose
>>> the preconditioner based on Schur complement to treat this problem.
>> However, I will comment below
>>> The parameters used for the solve is
>>> -ksp_type gmres
>> You need 'fgmres' here with the options you have below.
>>> -ksp_max_it 300
>>> -fieldsplit_u_pc_type hypre
>> I would just use MUMPS here to start, especially if it works on the whole
>> problem. Same with the one below.
>>    Matt
>>> -fieldsplit_u_pc_hypre_type boomeramg
>>> -fieldsplit_u_pc_hypre_boomeramg_coarsen_type PMIS
>>> -fieldsplit_lu_pc_type hypre
>>> -fieldsplit_lu_pc_hypre_type boomeramg
>>> -fieldsplit_lu_pc_hypre_boomeramg_coarsen_type PMIS
>>> For the test case, a small problem is solved on 2 processes. Due to the
>>> decomposition, the contact only happens in 1 proc, so the size of Lagrange
>>> multiplier dofs on proc 0 is 0.
>>> 0: mIndexU.size(): 80490
>>> 0: mIndexLU.size(): 0
>>> 1: mIndexU.size(): 103836
>>> 1: mIndexLU.size(): 2583
>>> However, with this setup the solver takes very long at KSPSolve before
>>> going to iteration, and the first iteration seems forever so I have to stop
>>> the calculation. I guessed that the solver takes time to compute the Schur
>>> complement, but according to the manual only the diagonal of A is used to
>>> approximate the Schur complement, so it should not take long to compute
>>> this.
>>> Note that I ran the same problem with direct solver (MUMPS) and it's
>>> able to produce the valid results. The parameter for the solve is pretty
>>> standard
>>> -ksp_type preonly
>>> -pc_type lu
>>> -pc_factor_mat_solver_package mumps
>>> Hence the matrix/rhs must not have any problem here. Do you have any
>>> idea or suggestion for this case?
>>> Giang
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160417/0dc9f181/attachment-0001.html>
