[petsc-users] fieldsplit preconditioner for indefinite matrix
Hoang Giang Bui hgbk2008 at gmail.com
Sat Apr 16 17:54:10 CDT 2016
Hello
I'm solving an indefinite problem arising from mesh tying/contact using
Lagrange multiplier, the matrix has the form
K = [A P^T
       P   0]
I used the FIELDSPLIT preconditioner with one field is the main variable
(displacement) and the other field for dual variable (Lagrange multiplier).
The block size for each field is 3. According to the manual, I first chose
the preconditioner based on Schur complement to treat this problem.
The parameters used for the solve is
-ksp_type gmres
-ksp_max_it 300
-ksp_gmres_restart 300
-ksp_gmres_modifiedgramschmidt
-pc_fieldsplit_type schur
-pc_fieldsplit_schur_fact_type diag
-pc_fieldsplit_schur_precondition selfp
-pc_fieldsplit_detect_saddle_point
-fieldsplit_u_pc_type hypre
-fieldsplit_u_pc_hypre_type boomeramg
-fieldsplit_u_pc_hypre_boomeramg_coarsen_type PMIS
-fieldsplit_lu_pc_type hypre
-fieldsplit_lu_pc_hypre_type boomeramg
-fieldsplit_lu_pc_hypre_boomeramg_coarsen_type PMIS
For the test case, a small problem is solved on 2 processes. Due to the
decomposition, the contact only happens in 1 proc, so the size of Lagrange
multiplier dofs on proc 0 is 0.
0: mIndexU.size(): 80490
0: mIndexLU.size(): 0
1: mIndexU.size(): 103836
1: mIndexLU.size(): 2583
However, with this setup the solver takes very long at KSPSolve before
going to iteration, and the first iteration seems forever so I have to stop
the calculation. I guessed that the solver takes time to compute the Schur
complement, but according to the manual only the diagonal of A is used to
approximate the Schur complement, so it should not take long to compute
this.
Note that I ran the same problem with direct solver (MUMPS) and it's able
to produce the valid results. The parameter for the solve is pretty standard
-ksp_type preonly
-pc_type lu
-pc_factor_mat_solver_package mumps
Hence the matrix/rhs must not have any problem here. Do you have any idea
or suggestion for this case?
Giang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160417/13fc1800/attachment.html>
