[petsc-users] DMPlexCreateLocalVec Within a function
Matthew Kury mkury at berkeley.edu
Fri Apr 15 18:23:20 CDT 2016
Hello,
	I have done some reading and I have not been able to find out what the proper way to create and use vectors within a function.
	If I have a function that passes in dm and V then:
		DMPlexGetLocalVec(dm, &VLocal) ;
		DMGlobalToLocalBegin(dm,V,INSERT_VALUES,VLocal);
		DMGlobalToLocalEnd(dm,V,INSERT_VALUES,VLocal) ;
		VecGetArray(VLoc,VLocalArray);
		“Stuff with VLocalArray”
		VecRestoreArray(VLoc,VLocalArray);
		DMLocalToGlobalBegin(dm,VLocal,ADD_VALUES,V);
		DMLocalToGlobalEnd(dm,VLocal,ADD_VALUES,V);
		DMRestoreLocalVector(dm,&VLocal);
	The second time I call the function I get errors with the VecGetArray() function.  I would appreciate any advice as to what is going wrong.
Thank you,
Matthew
