[petsc-users] Problem when getting matrix values owned by other processor
Yaoyu Hu huyaoyu1986 at gmail.com
Thu Apr 14 12:00:44 CDT 2016
Hi Hong,
I think what you said about the ISs for MatGetSubMatrices() are right.
Today I tried to run my program to get submatrix by
MatGetSubMatrices() twice. One time with ISs created with
PETSC_COMM_WORLD and the other time with PETSC_COMM_SELF. I was
creating a 6x3 submatrix on each processor from a 570x3 parallel dense
matrix. There are only 2 processors in total. The results are as
follows:
======== submatrix with ISs created with PETSC_COMM_WORLD =========
Processor 0
Mat Object: 1 MPI processes
  type: seqdense
2.7074996615625420e+10 6.8399452804377966e+11 -1.2730861976538324e+08
2.7359996580000423e+10 8.2079343365253589e+11 6.3654303672968522e+06
2.9639996295000458e+10 1.9151846785225828e+12 -1.0184686034752984e+08
2.9924996259375465e+10 1.1947308948674746e+12 -3.8181422587255287e+08
5.4149993231250839e+10 2.6675786593707410e+13 -4.9650360873402004e+09
Processor 1
  type: seqdense
5.4149993231250839e+10 1.9183199555758315e+12 5.9880080526417112e+08
7.8374990203126236e+10 5.7441876402563477e+12 1.7367770705944958e+09
8.0939989882501266e+10 5.7347670250898613e+12 1.7900992494213123e+09
8.1509989811251282e+10 5.7751527083651416e+12 1.8027055821637158e+09
8.4074989490626328e+10 6.1543675577970762e+12 1.8557943339637902e+09
1.0829998646250171e+11 9.5915997778791719e+12 2.9940040263208551e+09
==== end of submatrix with ISs created with PETSC_COMM_WORLD ======
======== submatrix with ISs created with PETSC_COMM_SELF =========
Processor 0
  type: seqdense
Processor 1
  type: seqdense
==== end of submatrix with ISs created with PETSC_COMM_SELF ======
The results are identical. I really agree with you that only
sequential ISs should be used when creating submatrix by
MatGetSubMatrices(). The above results may be just a coincidence.
I take your suggestions and I am using only sequential ISs with
MatGetSubMatrices() now.
Yet another question: Can I use IS which have duplicate entries in it?
The documentation of MatGetSubMatrices() says that "The index sets may
not have duplicate entries", so I think no duplicated entries are
allowed in the IS. But again, I just tried IS which have duplicated
entries. And the resultant submatrices for each processor seemd to be
correct. In fact, in the above sample submatrices I showed, the
submatrix owned by Processor 0 has its row IS specified as [x, x, a,
b, c, d]. Where 'x' means the duplicated entries in the IS. Then I got
two identical rows in the submatrix owned by Processor 0.
But I think I was doing this incorrectly.
Thanks.
HU Yaoyu
> Yaoyu:
>  "MatGetSubMatrices() can extract ONLY sequential submatrices
>    (from both sequential and parallel matrices). Use MatGetSubMatrix()
>    to extract a parallel submatrix."
> Using parallel IS for MatGetSubMatrices() definitely incorrect, unless you
> only use one process.
>> And further. I checked the submatrices I obtained by
>> MatGetSubMatrices() with both parallel ISs and sequential ISs. The
>> submatrices are identical. Is it means that I could actually use
>> parallel IS (created with PETSC_COMM_WORLD) ?
> What did you compare with?  I do not understand what submatrices would
> obtain with parallel IS using more than one process.
> Hong
>> > Yaoyu :
>> > MatGetSubMatrices() returns sequential matrices.
>> > IS must be sequential, created with PETSC_COMM_SELF.
>> > See petsc/src/mat/examples/tests/ex42.c
>> > Check your submatrices.
>> > Hong
>> > Hi everyone,
>> >> I am trying to get values owned by other processors of a parallel
>> matrix.
>> >> I tried to create a sub-matrix by using MatGetSubMatrices(), and then
>> >> MatGetRow() on the sub-matrix. But MatGetRow() give me the following
>> >> error message:
>> >> ===== Error message begins =====
>> >> No support for this operation for this object type
>> >> only local rows
>> >> ===== Error message ends =====
>> >> The parallel matrix is a parallel dense matrix. The ISs for
>> >> MatGetSubMatrices() are created using ISCreateGeneral() and
>> >> PETSC_COMM_WORLD. The row IS is sorted by ISSort().
>> >> What did I mistake while using the above functions? Is there a better
>> >> way to get access to matrix values owned by other processor?
>> >> Thanks!
>> >> HU Yaoyu
>> > -------------- next part --------------
>> > An HTML attachment was scrubbed...
>> > URL: <
>> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160413/6be45909/attachment.html
>> > _______________________________________________
>> > petsc-users mailing list
>> > petsc-users at mcs.anl.gov
>> > https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
>> > End of petsc-users Digest, Vol 88, Issue 41
