[petsc-users] Zeroed solution after 0 iterations
Wed Apr 13 11:42:09 CDT 2016
   John,
    Thank you for the report. It was a bug in our code. I have fixed the code in the master and next branch of the PETSc repository. We will be making a PETSc release in the next few days that will have the fix.
   Barry
> On Apr 13, 2016, at 9:13 AM, John Mousel <john.mousel at gmail.com> wrote:
> Barry,
> I've attached a small example that replicates this behavior.
> John
> On Wed, Apr 13, 2016 at 9:25 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    John,
>     We'll need the full code to debug this. It doesn't see this should happen.
>    Barry
> > On Apr 13, 2016, at 7:11 AM, John Mousel <john.mousel at gmail.com> wrote:
> > I have a colleague who is trying to run some simple test cases. He noticed if he provides the solution vector as the exact solution with a non-zero guess tagged, that the solution vector is zeroed upon return after 0 iterations. The system is just a 5x5 matrix corresponding to a heat equation with Dirichlet BCs. I've copied the KSPView below. He's using petsc-3.6.3.
> > John
> > solution before kspsolve:Vec Object: 1 MPI processes
> >   type: mpi
> > Process [0]
> > 300
> > 300
> > 300
> > 300
> > 300
> > KSP Object: 1 MPI processes
> >   type: bcgs
> >   maximum iterations=100
> >   tolerances:  relative=1e-15, absolute=1e-50, divergence=10000
> >   right preconditioning
> >   using nonzero initial guess
> >   using UNPRECONDITIONED norm type for convergence test
> > PC Object: 1 MPI processes
> >   type: ilu
> >     ILU: out-of-place factorization
> >     0 levels of fill
> >     tolerance for zero pivot 2.22045e-14
> >     matrix ordering: natural
> >     factor fill ratio given 1, needed 1
> >       Factored matrix follows:
> >         Mat Object:         1 MPI processes
> >           type: seqaij
> >           rows=5, cols=5
> >           package used to perform factorization: petsc
> >           total: nonzeros=25, allocated nonzeros=25
> >           total number of mallocs used during MatSetValues calls =0
> >             using I-node routines: found 1 nodes, limit used is 5
> >   linear system matrix = precond matrix:
> >     type: seqaij
> >     rows=5, cols=5
> > solution after kspsolve:Vec Object: 1 MPI processes
> >   type: mpi
> > Process [0]
> > 0
> > 0
> > 0
> > 0
> > 0
> <ex1.c>
