[petsc-users] Problem setting Jacobian matrix in complementarity problem
Christopher Athaide cnathaide at yahoo.com
Mon Apr 11 14:04:16 CDT 2016
I am trying to solve a mixed complementarity problem using the TAO SSILS
Solver .
C(x) = A x + d ,    l <= x <= u
where A = n x n matrix
               D = n x 1 vector
The Jacobian matrix is equal to the matrix A and is constant at each
iteration.
I have setup the Jacobian update function
PetscErrorCode FormJacobian(Tao, Vec X, Mat H, Mat, void *ptr)
AppCtx         *data = (AppCtx *)ptr;
                PetscErrorCode ierr;
                PetscInt       N;
                PetscInt       zero = 0;
                PetscScalar    *d, v;
                PetscBool      assembled;
                PetscFunctionBegin;
                ierr = MatAssembled(H, &assembled); CHKERRQ(ierr);
                if (assembled) { ierr = MatZeroEntries(H); CHKERRQ(ierr); }
                /* Get pointers to vector data */
                VecGetSize(X, &N);
                for (auto i = zero; i != N; ++i)
                                for (auto j = zero; j != N; ++j)
                                                ierr = MatGetValue(data->A,
i, j, &v);
                                                ierr = MatSetValue(H, i, j,
v, INSERT_VALUES);
                /* Assemble the matrix */
                ierr = MatSetOption(H, MAT_IGNORE_ZERO_ENTRIES, PETSC_TRUE);
CHKERRQ(ierr);
                ierr = MatAssemblyBegin(H, MAT_FINAL_ASSEMBLY);
CHKERRQ(ierr);
                ierr = MatAssemblyEnd(H, MAT_FINAL_ASSEMBLY); CHKERRQ(ierr);
                PetscFunctionReturn(0);
In this case, after iterating over all the row and column indexes and
assembling the matrix the function seems to run correctly.
But when I try to copy the matrix
ierr = MatConvert(data->A, MATSAME, MatReuse::MAT_INITIAL_MATRIX, &H);
CHKERRQ(ierr);
CHKERRQ(ierr);
I get the following error messages.
Problem size: 259 rows
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Not for unassembled matrix
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
[0]PETSC ERROR: Unknown Name on a arch-mswin-c-debug named LAGRANGE by
Christopher Mon Apr 11 19:57:37 2016
[0]PETSC ERROR: Configure options --with-cc="win32fe cl" --with-fc=0
--with-mpi=0 --download-f2cblaslapack=1 --with-debugging=1
[0]PETSC ERROR: #1 MatMult() line 2210 in
C:\Apps\Projects\petsc-3.6.3\src\mat\interface\matrix.c
[0]PETSC ERROR: #2 MatDFischer() line 284 in C:\Apps\Projects
\petsc-3.6.3\src\tao\util\tao_util.c
[0]PETSC ERROR: #3 Tao_SSLS_FunctionGradient() line 64 in C:\Apps\Projects
\petsc-3.6.3\src\tao\complementarity\impls\ssls\ssls.c
[0]PETSC ERROR: #4 TaoLineSearchComputeObjectiveAndGradient() line 941 in
C:\Apps\Projects \petsc-3.6.3\src\tao\linesearch\interface\taolinesearch.c
[0]PETSC ERROR: #5 TaoSolve_SSILS() line 64 in C:\Apps\Projects
\petsc-3.6.3\src\tao\complementarity\impls\ssls\ssils.c
[0]PETSC ERROR: #6 TaoSolve() line 204 in C:\Apps\Projects\
petsc-3.6.3\src\tao\interface\taosolver.c
[0]PETSC ERROR: #7 run_complementarity() line 394 in c:\apps\projects
\complementarity.cpp
I am new to PETSC. Can anyone help me?
Thanks
Chris Athiade
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160411/648000c1/attachment.html>
