[petsc-users] Ordering with MatCreateNest and MPI
FRANCAVILLA MATTEO ALESSANDRO d019598 at polito.it
Thu Apr 7 05:31:51 CDT 2016
I'm trying to use a matrix composed of different sub-matrix blocks; I create
the matrix with MatCreateNest(). I'm finding it hard to understand the
ordering (in MPI applications) of the result of MatMult operations.
Apparently the result of the multiplication is correct, except that both
input and output vectors go through some sort of permutation. How should I
use the MatMult routine, i.e. how to pass the input vector with the correct
ordering and how to get the correct ordering of the result?
Below a simple Fortran example to demonstrate what I'm trying to do (running
the example with 1 process works fine, with  2 or more processes I don't
understand how to get the correct ordering). When using standard matrices
(i.e., not MatNest) I've never had to care about orderings.
Alessandro
PROGRAM Main
implicit none
#include <petsc/finclude/petscsys.h>
#include <petsc/finclude/petscvec.h>
#include <petsc/finclude/petscmat.h>
!                       PETSc variables
Vec						:: x, b
Mat						:: matArray(4), A
PetscInt				:: II, JJ, FromRow, ToRow, IMAT
PetscErrorCode    		:: IERR
PetscInt, ALLOCATABLE     :: INDICES(:)
PetscScalar, ALLOCATABLE  :: VALUES(:)
PetscInt, PARAMETER		:: N = 2			! size of sub-matrices
CALL PetscInitialize(PETSC_NULL_CHARACTER,IERR)
ALLOCATE(INDICES(N),VALUES(N))
INDICES = (/ (ii, ii=0, N-1) /)
! Form 4 blocks of size NxN
DO IMAT = 1, 4
	CALL
MatCreateDense(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,N,N,PETSC_NULL_SCALAR,matArray(IMAT),IERR)
	CALL MatGetOwnershipRange(matArray(IMAT),FromRow,ToRow,IERR)
	DO II = FromRow, ToRow-1
		DO JJ = 1, N
	    	VALUES(JJ) = (IMAT-1)*100 + N*II + JJ
		END DO
	  	CALL
MatSetValues(matArray(IMAT),1,II,N,INDICES,VALUES,INSERT_VALUES,IERR)
	END DO
	CALL MatAssemblyBegin(matArray(IMAT),MAT_FINAL_ASSEMBLY,IERR)
	CALL MatAssemblyEnd(matArray(IMAT),MAT_FINAL_ASSEMBLY,IERR)
END DO
! Form a 2x2 block matrix made as [ matArray(1) matArray(2) ; matArray(3)
matArray(4) ]
! If N = 2 the matrix is:
! A =            [   1   2 | 101 102 ;
!          	  3   4 | 102 103 ;
!		___________________
!               201 202 | 401 402 ;
!	     203 204 | 403 404 ]
CALL
MatCreateNest(PETSC_COMM_WORLD,2,PETSC_NULL_OBJECT,2,PETSC_NULL_OBJECT,matArray,A,IERR)
CALL MatCreateVecs(A,x,b,IERR)
CALL VecSet(x,0.+0.*PETSC_i,IERR)
CALL VecSetValues(x,1,2,(1.+0.*PETSC_i),INSERT_VALUES,IERR)
CALL VecAssemblyBegin(x,IERR)
CALL VecAssemblyEnd(x,IERR)
CALL VecView(x,PETSC_VIEWER_STDOUT_WORLD,IERR)
CALL MatMult(A,x,b,IERR)
! A*x extracts the 3rd column of A
CALL VecView(b,PETSC_VIEWER_STDOUT_WORLD,IERR)
DEALLOCATE(INDICES,VALUES)
CALL PetscFinalize(IERR)
END PROGRAM
