[petsc-users] Prelloc: Get coordinates of local diagonal submatrix
Florian Lindner mailinglists at xgm.de
Wed Apr 6 10:12:43 CDT 2016
Hello,
in order to preallocate I have to know whether a non-zero will be in the local diagonal submatrix or not.
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html
says:
The DIAGONAL portion of the local submatrix of a processor can be defined as the submatrix which is obtained by extraction the part corresponding to the rows r1-r2 and columns c1-c2 of the global matrix, where r1 is the first row that belongs to the processor, r2 is the last row belonging to the this processor, and c1-c2 is range of indices of the local part of a vector suitable for applying the matrix to. This is an mxn matrix. In the common case of a square matrix, the row and column ranges are the same and the DIAGONAL part is also square. The remaining portion of the local submatrix (mxN) constitute the OFF-DIAGONAL portion.
Therefore I compute the begin and end rows and cols like that:
  int ownerRangeBeginA = _matrixA.ownerRange().first;
  int ownerRangeEndA = _matrixA.ownerRange().second;
  // Uses: MatGetVecs(_matrixA.matrix, &vector, nullptr);
  petsc::Vector diagTest{_matrixA, "test", petsc::Vector::RIGHT};
  int localDiagColBegin = diagTest.ownerRange().first;
  int localDiagColEnd = diagTest.ownerRange().second;
  Debug("Local Submatrix Rows = " << ownerRangeBeginA << " / " << ownerRangeEndA <<
        ", Local Submatrix Cols = " << localDiagColBegin << " / " << localDiagColEnd);
It's a little bit tainted by my PETSc C++ helper function, but I think you get the code.
Is there a way to do it more elegantly? Without instantiating a vector just for the purpose of gettings its owner range? And then testing a if an index is inside the local diagonal submatrix?
Florian
