[petsc-users] eigensolution error with slepc
Jose E. Roman jroman at dsic.upv.es
Mon Apr 4 11:54:28 CDT 2016
> El 4 abr 2016, a las 18:43, Manav Bhatia <bhatiamanav at gmail.com> escribió:
> Thanks!
> I upgraded to 3.6.3 and ran the code, and it went through all the load steps without problem.
> A followup question:
> It seems like the eigenvalues are sorted based on abs(lambda). If I am interested in only the lowest N eigenvalues greater than 0, is there a way to tell slepc to ignore all eigenvalues less than 0?
> Thanks,
> Manav
You can try a user-defined sorting criterion as in this example:
http://slepc.upv.es/documentation/current/src/eps/examples/tutorials/ex18.c.html
