[petsc-users] eigensolution error with slepc
Jose E. Roman jroman at dsic.upv.es
Mon Apr 4 11:47:53 CDT 2016
> El 4 abr 2016, a las 18:32, David Knezevic <david.knezevic at akselos.com> escribió:
> Hi Jose,
> I'm interested to know more about this comment from your email below:
> "You can also try the symmetric-indefinite solver, but this is not recommended since it is not numerically stable."
> I frequently use SLEPc's symmetric-indefinite solver for buckling eigenvalue problems (which are naturally symmetric and indefinite), and this works well in my experience. But, based on your comment, I was wondering if you would recommend a different solver for this case?
> Thanks,
> David
The symmetric-indefinite solver is based on non-symmetric Lanczos, which is not guaranteed to be numerically stable (it does not rely on orthogonal projections as Arnoldi). In practice, it means that the method may break down or get unstable (in our implementation we detect the latter). For many problems the indefinite solver will provide the solution without problems, but no guarantees it will always work.
Details of the indefinite solver can be found in section 3 of this paper: http://dx.doi.org/10.1007/s10543-016-0601-5
Jose
