[petsc-users] eigensolution error with slepc
Manav Bhatia bhatiamanav at gmail.com
Mon Apr 4 10:49:07 CDT 2016
I just sent you the updated matrices on slepc-main.
Sorry about sending the wrong matrices earlier.
Manav
> On Apr 4, 2016, at 9:42 AM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Ok. So, I ran ex7 with the same command-line options in your email, and got a result. This is on my Mac OS X, without any changes to the lapack/blas/slepc library.
> I also ran my code on a linux machine with lapack/blas build from source (obtained from netlib), and got the same error as on my mac.
> Not sure how to go about debugging this.
> -Manav
>> On Apr 4, 2016, at 3:46 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>>> El 3 abr 2016, a las 22:17, Manav Bhatia <bhatiamanav at gmail.com> escribió:
>>> I just send you the matrices.
>>> Thanks,
>>> Manav
>> I cannot reproduce the problem. I was able to compute the eigenvalues without problems with Krylov-Schur (note that I scaled matrix A by 1e7 because the eigenvalues are tiny):
>> $ ./ex7 -f1 A.petsc -f2 B.petsc -eps_gen_hermitian
>> Generalized eigenproblem stored in file.
>> Reading REAL matrices from binary files...
>> Number of iterations of the method: 1
>> Number of linear iterations of the method: 17
>> Solution method: krylovschur
>> Number of requested eigenvalues: 1
>> Stopping condition: tol=1e-08, maxit=768
>> Linear eigensolve converged (6 eigenpairs) due to CONVERGED_TOL; iterations 1
>>           k             ||Ax-kBx||/||kx||
>>      11.410228            3.18851e-09
>>       1.323631            2.33005e-09
>>       1.323631            3.98884e-09
>>       0.224497            1.24334e-08
>>       0.168344            9.81685e-08
>>       0.129229            4.85372e-08
>> Note that I am solving the problem as a GHEP, and this gives far better residuals than solving as a GNHEP. The Arnoldi solver did not fail either.
>> I don't know what caused your error. You can try configuring with the source Lapack: --download-f2cblaslapack
>> Jose
