[petsc-users] compile fortran module with PETSc
Sat Apr 2 17:23:24 CDT 2016
On Sat, Apr 2, 2016 at 5:20 PM, Josh Lo <ysjosh.lo at gmail.com> wrote:
> Hi,
> I am trying to compile my main source code with module.
> I need PETSc in both main code and module, so I include the header file in
> both.
> it gives me some error when compiling.
> The error is:
> src/main.F:2.9:
>       use fmodule
>          2
> Error: Symbol 'mpi_source' at (1) conflicts with symbol from module
> 'fmodule', use-associated at (2)
> /Users/XXXXXXX/Desktop/project/petsc/petsc_3.6.3_install/include/mpif.h:10:30:
>         PARAMETER (MPI_SOURCE=3,MPI_TAG=4,MPI_ERROR=5)
>                               1
> Error: Cannot change attributes of USE-associated symbol mpi_source at (1)
> it goes on and on, most relates to MPI.
> my main source code is like:
> program main
> USE fmodule
> implicit none
> #include "petsc/finclude/petsc.h"
> end program main
> the module:
> module fmodule
> end module fmodule
> if the I don't include the header file in module, then it is no error,
> but I do need petsc in my module.
> How can I solve this problem?
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html
Change the include.
  Thanks
     Matt
> Thanks,
> Lo
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160402/05fcb872/attachment.html>
