[petsc-users] Vec is locked read only
Rongliang Chen rl.chen at siat.ac.cn
Sat Apr 2 07:46:26 CDT 2016
But I need to setup the boundary conditions for the solution vector X,
which is in FormMassTimeStep().
Best regards,
Rongliang
On 04/02/2016 08:37 PM, Matthew Knepley wrote:
> On Sat, Apr 2, 2016 at 7:37 AM, Rongliang Chen <rl.chen at siat.ac.cn
> <mailto:rl.chen at siat.ac.cn>> wrote:
>     Hi Matt,
>     How to check in the explicit method? This kind of errors does come
>     out in the explicit method.
> You said "that is I use the explicit method with the same function
> FormMassTimeStep(), this error disappeared"
>     What do you mean "You should never be changing the input guess"?
>     Do you mean that the value of the solution vector X in
>     FormFunction are not allowed to be changed by the user defined
>     function?
> Yes.
>    Matt
>     Best regards,
>     Rongliang
>     On 04/02/2016 08:19 PM, Matthew Knepley wrote:
>>     On Sat, Apr 2, 2016 at 7:15 AM, Rongliang Chen
>>     <rl.chen at siat.ac.cn <mailto:rl.chen at siat.ac.cn>> wrote:
>>         Hi Matt,
>>         That's right. The FormMassTimeStep() is inside the
>>         FormFunction() and I call the FormFunction() in this way:
>>         SNESSetFunction(user->snes, algebra->f, FormFunction,
>>         (void*)user). How can I know the X is read-only or not?
>>     Exactly that you get this error message, and it should be in the
>>     documentation.
>>         If I do not use the SNESSolve, that is I use the explicit
>>         method with the same function FormMassTimeStep(), this error
>>         disappeared. So it seems that the SNESSolve locked the vector X.
>>     Then we need to put that check in the explicit method as well.
>>     You should never be changing the input guess.
>>       Thanks,
>>         Matt
>>         Best regards,
>>         Rongliang
>>         On 04/02/2016 07:59 PM, Matthew Knepley wrote:
>>>         On Sat, Apr 2, 2016 at 6:49 AM, Rongliang Chen
>>>             Hi Dave,
>>>             I did not call any VecGetArrary and VecGetArraryRead in
>>>             function FormMassTimeStepFunction().
>>>         It looks like you have a function FormMassTimeStep() inside
>>>         your FormFunction() method. This
>>>         has an argument X, the solution guess, which is read-only.
>>>         However, you are calling DMLocalToGlobal()
>>>         using that X, which is illegal, since its read-only. Is this
>>>         right?
>>>            Matt
>>>             Best regards,
>>>             Rongliang
>>>             On 04/02/2016 06:20 PM, Dave May wrote:
>>>>             On 2 April 2016 at 11:18, Rongliang Chen
>>>>                 Hi Shri,
>>>>                 Thanks for your reply.
>>>>                 Do you mean that I need to change the
>>>>                 VecGetArrary() in
>>>>                 /home/rlchen/soft/petsc-3.6.3/src/dm/interface/dm.c
>>>>                 to VecGetArrayRead()?
>>>>             No - you should change it in your function
>>>>             The input vector x passed into SNESComputeFunction() is
>>>>             read only.
>>>>                 I tried it and I got a warning when I make the petsc:
>>>>                 /home/rlchen/soft/petsc-3.6.3/src/dm/interface/dm.c: In
>>>>                 function ‘DMLocalToGlobalBegin’:
>>>>                 /home/rlchen/soft/petsc-3.6.3/src/dm/interface/dm.c:1913:5:
>>>>                 warning: passing argument 2 of ‘VecGetArrayRead’
>>>>                 from incompatible pointer type [enabled by default]
>>>>                 In file included from
>>>>                 /home/rlchen/soft/petsc-3.6.3/include/petscmat.h:6:0,
>>>>                 from /home/rlchen/soft/petsc-3.6.3/include/petscdm.h:6,
>>>>                 from
>>>>                 /home/rlchen/soft/petsc-3.6.3/include/petsc/private/dmimpl.h:6,
>>>>                 from
>>>>                 /home/rlchen/soft/petsc-3.6.3/src/dm/interface/dm.c:1:
>>>>                 /home/rlchen/soft/petsc-3.6.3/include/petscvec.h:420:29:
>>>>                 note: expected ‘const PetscScalar **’ but argument
>>>>                 is of type ‘PetscScalar **’
>>>>                 Best regards,
>>>>                 Rongliang
>>>>                 Rongliang Chen,   PhD
>>>>                 Associate Professor
>>>>                 Laboratory for Engineering and Scientific Computing
>>>>                 Shenzhen Institutes of Advanced Technology
>>>>                 Chinese Academy of Sciences
>>>>                 Address: 1068 Xueyuan Avenue, Shenzhen University
>>>>                 Town, Shenzhen, Guangdong (518055), P. R. China
>>>>                 E-mail: rl.chen at siat.ac.cn <mailto:rl.chen at siat.ac.cn>
>>>>                 Phone: +86-755-86392312 <tel:%2B86-755-86392312>
>>>>                 On 04/02/2016 05:03 PM, Abhyankar, Shrirang G. wrote:
>>>>                     Use VecGetArrayRead instead of VecGetArray
>>>>                     http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetArray
>>>>                     Read.html
>>>>                     Shri
>>>>                     -----Original Message-----
>>>>                     From: Rongliang Chen <rl.chen at siat.ac.cn
>>>>                     Date: Saturday, April 2, 2016 at 3:51 AM
>>>>                     To: PETSc users list <petsc-users at mcs.anl.gov
>>>>                     <mailto:petsc-users at mcs.anl.gov>>,
>>>>                     "rongliang.chan at gmail.com
>>>>                     <mailto:rongliang.chan at gmail.com>"
>>>>                     <rongliang.chan at gmail.com
>>>>                     <mailto:rongliang.chan at gmail.com>>
>>>>                     Subject: [petsc-users] Vec is locked read only
>>>>                         Dear All,
>>>>                         My code got the following error messages,
>>>>                         but the code works well for
>>>>                         the petsc optimized version
>>>>                         (--with-debugging=0). Anyone can tell me how
>>>>                         to fix this problem?
>>>>                         Best regards,
>>>>                         Rongliang
>>>>                         [0]PETSC ERROR: --------------------- Error
>>>>                         Message
>>>>                         [0]PETSC ERROR: Object is in wrong state
>>>>                         [0]PETSC ERROR:  Vec is locked read only,
>>>>                         argument # 1
>>>>                         [0]PETSC ERROR: See
>>>>                         http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>                         for trouble shooting.
>>>>                         [0]PETSC ERROR: Petsc Release Version
>>>>                         3.6.3, Dec, 03, 2015
>>>>                         [0]PETSC ERROR: ./Nwtun on a 64bit-debug
>>>>                         named rlchen by rlchen Sat Apr
>>>>                         2 15:40:32 2016
>>>>                         [0]PETSC ERROR: Configure options
>>>>                         --download-blacs --download-scalapack
>>>>                         --download-metis --download-parmetis
>>>>                         --download-exodusii
>>>>                         --download-netcdf --download-hdf5
>>>>                         --with-mpi-dir=/home/rlchen/soft/Program/mpich2-shared
>>>>                         --with-debugging=1 --download-fblaslapack
>>>>                         --download-chaco
>>>>                         [0]PETSC ERROR: #1 VecGetArray() line 1646 in
>>>>                         /home/rlchen/soft/petsc-3.6.3/src/vec/vec/interface/rvector.c
>>>>                         [0]PETSC ERROR: #2 DMLocalToGlobalBegin()
>>>>                         line 1913 in
>>>>                         [0]PETSC ERROR: #3
>>>>                         FormMassTimeStepFunction() line 191 in
>>>>                         /home/rlchen/soft/3D_fluid/FiniteVolumeMethod/PETScCodes/codefor3.6/SetupF
>>>>                         unctions.c
>>>>                         [0]PETSC ERROR: #4 FormFunction() line 46 in
>>>>                         unctions.c
>>>>                         [0]PETSC ERROR: #5 SNESComputeFunction()
>>>>                         line 2067 in
>>>>                         /home/rlchen/soft/petsc-3.6.3/src/snes/interface/snes.c
>>>>                         [0]PETSC ERROR: #6 SNESSolve_NEWTONLS()
>>>>                         line 184 in
>>>>                         /home/rlchen/soft/petsc-3.6.3/src/snes/impls/ls/ls.c
>>>>                         [0]PETSC ERROR: #7 SNESSolve() line 3906 in
>>>>                         [0]PETSC ERROR: #8 SolveTimeDependent()
>>>>                         line 843 in
>>>>                         /home/rlchen/soft/3D_fluid/FiniteVolumeMethod/PETScCodes/codefor3.6/Nwtun.
>>>>                         c
>>>>                         [0]PETSC ERROR: #9 main() line 452 in
>>>>                         c
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160402/76c1c4cd/attachment-0001.html>
