[petsc-users] Vec is locked read only
Rongliang Chen rl.chen at siat.ac.cn
Sat Apr 2 07:15:39 CDT 2016
Hi Matt,
That's right. The FormMassTimeStep() is inside the FormFunction() and I
call the FormFunction() in this way: SNESSetFunction(user->snes,
algebra->f, FormFunction, (void*)user). How can I know the X is
read-only or not?
If I do not use the SNESSolve, that is I use the explicit method with
the same function FormMassTimeStep(), this error disappeared. So it
seems that the SNESSolve locked the vector X.
Best regards,
Rongliang
On 04/02/2016 07:59 PM, Matthew Knepley wrote:
> On Sat, Apr 2, 2016 at 6:49 AM, Rongliang Chen <rl.chen at siat.ac.cn
> <mailto:rl.chen at siat.ac.cn>> wrote:
>     Hi Dave,
>     I did not call any VecGetArrary and VecGetArraryRead in function
>     FormMassTimeStepFunction().
> It looks like you have a function FormMassTimeStep() inside your
> FormFunction() method. This
> has an argument X, the solution guess, which is read-only. However,
> you are calling DMLocalToGlobal()
> using that X, which is illegal, since its read-only. Is this right?
>    Matt
>     Best regards,
>     Rongliang
>     On 04/02/2016 06:20 PM, Dave May wrote:
>>     On 2 April 2016 at 11:18, Rongliang Chen <rl.chen at siat.ac.cn
>>         Hi Shri,
>>         Thanks for your reply.
>>         Do you mean that I need to change the VecGetArrary() in
>>         /home/rlchen/soft/petsc-3.6.3/src/dm/interface/dm.c to
>>         VecGetArrayRead()?
>>     No - you should change it in your function
>>     The input vector x passed into SNESComputeFunction() is read only.
>>         I tried it and I got a warning when I make the petsc:
>>         /home/rlchen/soft/petsc-3.6.3/src/dm/interface/dm.c: In
>>         function ‘DMLocalToGlobalBegin’:
>>         /home/rlchen/soft/petsc-3.6.3/src/dm/interface/dm.c:1913:5:
>>         warning: passing argument 2 of ‘VecGetArrayRead’ from
>>         incompatible pointer type [enabled by default]
>>         In file included from
>>         /home/rlchen/soft/petsc-3.6.3/include/petscmat.h:6:0,
>>         from /home/rlchen/soft/petsc-3.6.3/include/petscdm.h:6,
>>         from
>>         /home/rlchen/soft/petsc-3.6.3/include/petsc/private/dmimpl.h:6,
>>         from /home/rlchen/soft/petsc-3.6.3/src/dm/interface/dm.c:1:
>>         /home/rlchen/soft/petsc-3.6.3/include/petscvec.h:420:29:
>>         note: expected ‘const PetscScalar **’ but argument is of type
>>         ‘PetscScalar **’
>>         Best regards,
>>         Rongliang
>>         Rongliang Chen,   PhD
>>         Associate Professor
>>         Laboratory for Engineering and Scientific Computing
>>         Shenzhen Institutes of Advanced Technology
>>         Chinese Academy of Sciences
>>         Address: 1068 Xueyuan Avenue, Shenzhen University Town,
>>         Shenzhen, Guangdong (518055), P. R. China
>>         E-mail: rl.chen at siat.ac.cn <mailto:rl.chen at siat.ac.cn>
>>         Phone: +86-755-86392312 <tel:%2B86-755-86392312>
>>         On 04/02/2016 05:03 PM, Abhyankar, Shrirang G. wrote:
>>             Use VecGetArrayRead instead of VecGetArray
>>             http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetArray
>>             Read.html
>>             Shri
>>             -----Original Message-----
>>             From: Rongliang Chen <rl.chen at siat.ac.cn
>>             Date: Saturday, April 2, 2016 at 3:51 AM
>>             To: PETSc users list <petsc-users at mcs.anl.gov
>>             <mailto:petsc-users at mcs.anl.gov>>,
>>             "rongliang.chan at gmail.com <mailto:rongliang.chan at gmail.com>"
>>             <rongliang.chan at gmail.com <mailto:rongliang.chan at gmail.com>>
>>             Subject: [petsc-users] Vec is locked read only
>>                 Dear All,
>>                 My code got the following error messages, but the
>>                 code works well for
>>                 the petsc optimized version (--with-debugging=0).
>>                 Anyone can tell me how
>>                 to fix this problem?
>>                 Best regards,
>>                 Rongliang
>>                 [0]PETSC ERROR: --------------------- Error Message
>>                 [0]PETSC ERROR: Object is in wrong state
>>                 [0]PETSC ERROR:  Vec is locked read only, argument # 1
>>                 [0]PETSC ERROR: See
>>                 http://www.mcs.anl.gov/petsc/documentation/faq.html
>>                 for trouble shooting.
>>                 [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03,
>>                 2015
>>                 [0]PETSC ERROR: ./Nwtun on a 64bit-debug named rlchen
>>                 by rlchen Sat Apr
>>                 2 15:40:32 2016
>>                 [0]PETSC ERROR: Configure options --download-blacs
>>                 --download-scalapack
>>                 --download-metis --download-parmetis --download-exodusii
>>                 --download-netcdf --download-hdf5
>>                 --with-mpi-dir=/home/rlchen/soft/Program/mpich2-shared
>>                 --with-debugging=1 --download-fblaslapack
>>                 --download-chaco
>>                 [0]PETSC ERROR: #1 VecGetArray() line 1646 in
>>                 /home/rlchen/soft/petsc-3.6.3/src/vec/vec/interface/rvector.c
>>                 [0]PETSC ERROR: #2 DMLocalToGlobalBegin() line 1913 in
>>                 [0]PETSC ERROR: #3 FormMassTimeStepFunction() line 191 in
>>                 /home/rlchen/soft/3D_fluid/FiniteVolumeMethod/PETScCodes/codefor3.6/SetupF
>>                 unctions.c
>>                 [0]PETSC ERROR: #4 FormFunction() line 46 in
>>                 unctions.c
>>                 [0]PETSC ERROR: #5 SNESComputeFunction() line 2067 in
>>                 /home/rlchen/soft/petsc-3.6.3/src/snes/interface/snes.c
>>                 [0]PETSC ERROR: #6 SNESSolve_NEWTONLS() line 184 in
>>                 /home/rlchen/soft/petsc-3.6.3/src/snes/impls/ls/ls.c
>>                 [0]PETSC ERROR: #7 SNESSolve() line 3906 in
>>                 [0]PETSC ERROR: #8 SolveTimeDependent() line 843 in
>>                 /home/rlchen/soft/3D_fluid/FiniteVolumeMethod/PETScCodes/codefor3.6/Nwtun.
>>                 c
>>                 [0]PETSC ERROR: #9 main() line 452 in
>>                 c
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160402/a37004a0/attachment-0001.html>
