[petsc-users] DMCreateMatrix with some dense row
Sang pham van pvsang002 at gmail.com
Tue Oct 27 20:18:18 CDT 2015
Hi Barry,
I made my function for preallocating the DM matrix. I am using immersed
boundary method to solve a problem of solid mechanics (3D, linear
elasticity).
At every solid nodes, I have 3 unknowns for displacement in 3 directions
(nc=3), my DM has box stencil. Thus, at a node I have 3 equations, for each
equation I preallocate 27*3  = 81 entries.
When running the code, I got many of the following error  when setting
values into the preallocated matrix:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range!
[0]PETSC ERROR: Local index 1496271904 too large 121500 (max) at 0!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.4.5, Jun, 29, 2014
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./sasMAIN on a arch-linux-cxx-opt named sang by sang Wed
Oct 28 07:34:37 2015
[0]PETSC ERROR: Libraries linked from
/home/sang/petsc/petsc-3.4.5/arch-linux-cxx-opt/lib
[0]PETSC ERROR: Configure run at Thu Sep  3 23:04:15 2015
[0]PETSC ERROR: Configure options --download-mpich=1
--with-scalar-type=real --with-clanguage=cxx --download-mumps=1
--download-blacs=1 --download-parmetis=1 --download-scalapack=1
--with-debugging=0 --download-hypre=1 --with-fc=gfortran --download-metis=1
-download-cmake=1 --download-f-blas-lapack=1
[0]PETSC ERROR:
[0]PETSC ERROR: ISLocalToGlobalMappingApply() line 444 in
/home/sang/petsc/petsc-3.4.5/src/vec/is/utils/isltog.c
[0]PETSC ERROR: MatSetValuesLocal() line 1968 in
/home/sang/petsc/petsc-3.4.5/src/mat/interface/matrix.c
[0]PETSC ERROR: MatSetValuesStencil() line 1339 in
Can you please explain to me what is possible reason for this error? it
looks like there is problem with the mapping from LocaltoGobal index, but
that part I just copy from the original code.
One more question I have is that, when preallocating for a node, as you can
see in my below code (based on original PETSc code), since I have 3
equations, I preallocated 3 rows (in rows[l] array), each row has a number
of columns index, all column indices of the three rows are stored in the
cols[] array. At this point I don't understand how PETSc know in that
cols[] arrays which column indices belonging to the first(second/third)
row? Please help me to understand this.
Thank you very much.
Pham
Below are my code for preallocating the DM matrix;
PetscErrorCode sasMatVecPetsc::DMCreateMatrix_DA_3d_MPIAIJ_pvs(DM da,Mat
pMat, sasSmesh* mesh,sasVector<int>& solidcells,sasVector<int>&
isolidcellnearBI,sasVector<int>& solidcellnearBI,sasVector<int>&
forcing_or_ghost_cells)
  PetscErrorCode         ierr;
  PetscInt               xs,ys,nx,ny,i,j,slot,gxs,gys,gnx,gny;
  PetscInt               m,n,dim,s,*cols = NULL,k,nc,*rows =
NULL,col,cnt,l,p,*dnz = NULL,*onz = NULL;
  PetscInt
istart,iend,jstart,jend,kstart,kend,zs,nz,gzs,gnz,ii,jj,kk;
  MPI_Comm               comm;
  PetscScalar            *values;
  DMDABoundaryType       bx,by,bz;
  ISLocalToGlobalMapping ltog,ltogb;
  DMDAStencilType        st;
  PetscFunctionBegin;
  ierr =
DMDAGetInfo(da,&dim,&m,&n,&p,0,0,0,&nc,&s,&bx,&by,&bz,&st);CHKERRQ(ierr);
// nc = 3
  col  = 2*s + 1;
  ierr = DMDAGetCorners(da,&xs,&ys,&zs,&nx,&ny,&nz);CHKERRQ(ierr);
  ierr =
DMDAGetGhostCorners(da,&gxs,&gys,&gzs,&gnx,&gny,&gnz);CHKERRQ(ierr);
  ierr = PetscObjectGetComm((PetscObject)da,&comm);CHKERRQ(ierr);
  ierr =
PetscMalloc2(nc,PetscInt,&rows,col*col*col*nc*nc,PetscInt,&cols);CHKERRQ(ierr);
  ierr = DMGetLocalToGlobalMapping(da,&ltog);CHKERRQ(ierr);
  ierr =
MatPreallocateInitialize(comm,nc*nx*ny*nz,nc*nx*ny*nz,dnz,onz);CHKERRQ(ierr);
  nCells = mesh->nCells;
  sasVector<int> cell_type(mesh->nCells,0);
  for(int i=0;i<solidcells.N;i++)  cell_type[solidcells[i]] = 1;
  for(int i=0;i<forcing_or_ghost_cells.N;i++)
 cell_type[forcing_or_ghost_cells[i]] = 2;
  for(i = 0;i<nCells;i++)
    slot = mesh->Cells_ijk[i].i - gxs + gnx*(mesh->Cells_ijk[i].j - gys) +
gnx*gny*(mesh->Cells_ijk[i].k - gzs);
    cnt = 0;
    if(cell_type[i]==0) /// fluid cells
      for (l=0; l<nc; l++)
        cols[cnt++] = l + nc*slot;
        rows[l] = l + nc*slot;
    if(cell_type[i]==1) /// solid cells:
       for (int ll=0; ll<nc; ll++)
        for (ii=-1; ii<2; ii++) {
          for (jj=-1; jj<2; jj++) {
            for (kk=-1; kk<2; kk++) {
                cols[cnt++] = ll + nc*(slot + ii + gnx*jj + gnx*gny*kk);
        rows[l] = l + nc*(slot);
    if(cell_type[i]!=2)
    ierr =
MatPreallocateSetLocal(ltog,nc,rows,ltog,cnt,cols,dnz,onz);CHKERRQ(ierr);
  MatCreate(comm,&pMat);
MatSetSizes(pMat,nc*gnx*gny*gnz,nc*gnx*gny*gnz,nc*gnx*gny*gnz,nc*gnx*gny*gnz);
  MatSetType(pMat,MATAIJ);
  ierr = MatSetBlockSize(pMat,nc);CHKERRQ(ierr);
  ierr = MatSeqAIJSetPreallocation(pMat,0,dnz);CHKERRQ(ierr);
  ierr = MatMPIAIJSetPreallocation(pMat,0,dnz,0,onz);CHKERRQ(ierr);
  ierr = MatPreallocateFinalize(dnz,onz);CHKERRQ(ierr);
  ierr = MatSetLocalToGlobalMapping(pMat,ltog,ltog);CHKERRQ(ierr);
  ierr = PetscFree2(rows,cols);CHKERRQ(ierr);
  PetscFunctionReturn(0);
On Sun, Oct 25, 2015 at 12:46 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Oct 24, 2015, at 1:43 AM, Sang pham van <pvsang002 at gmail.com> wrote:
> > Thank you, Dave,
> > Can I just call My_DMCreateMatrix_DA_3d_MPIAIJ(DM da, Mat J, void*
> my_context) when I need to create my matrix, and forget about
> DMDASetGetMatrix()?
>   You can do that if that is all you need. In some contexts when something
> else in PETSc needs to create a specific matrix (like with geometric
> multigrid) then that code calls DMCreateMatrix() which would then use your
> creation routine.
>    So, in summary you can start by just calling your own routine and
> convert it to use DMSetGetMatrix() later if you need to.
>   Barry
> > Thank you.
> > Pham
> > On Sat, Oct 24, 2015 at 1:33 PM, Dave May <dave.mayhem23 at gmail.com>
> wrote:
> > If you need to access a user defined context from within your
> CreateMatrix function, you can attach it to the DM via PetscObjectCompose
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscObjectCompose.html
> > If your context is not a petsc object, you can use
> PetscContainerCreate(),
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscContainerCreate.html#PetscContainerCreate
> > You would then set your user context pointer inside the container and
> then use PetscObjectCompose() to attach the container to the DM
> > Thanks,
> >   Dave
> > On 24 October 2015 at 06:04, Sang pham van <pvsang002 at gmail.com> wrote:
> > Hi Barry,
> > The routine DMCreateMatrix_DA_3d_MPIAIJ has 2 input arguments (DM da,
> Mat J), the function pointer in DMDASetGetMatrix() only accept function
> with that two arguments.
> > As you suggested, I am writing a routine (based on
> DMCreateMatrix_DA_3d_MPIAIJ()) to preallocate the matrix in the way I wish,
> to do that I think It needs to have one more input argument:
> My_DMCreateMatrix_DA_3d_MPIAIJ(DM da, Mat J, void* my_context). But
> DMDASetGetMatrix() will not accept pointer of this function. Please give a
> suggestion to overcome this.
> > Thank you.
> > Pham
> > On Fri, Sep 4, 2015 at 1:24 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >     Look at DMCreateMatrix_DA_2d_MPIAIJ  (or the 3d version if working
> in 3d)   You need to copy this routine and add whatever additional
> preallocation information you need.   Then call DMDASetGetMatrix()  so that
> the DM will use your routine to create the matrix for you.
> >    Barry
> > > On Sep 3, 2015, at 11:28 AM, Sang pham van <pvsang002 at gmail.com>
> wrote:
> > > Hi,
> > > I am using DMCreateMatrix to create matrix from a existed DM object
> and defined stencil.
> > > In my code, boundary nodes need to involve many inner nodes, thus
> matrix rows corresponding to boundary nodes are almost dense. How can I
> tell petsc that those rows need to be preallocated with more entries? I
> don't want to use MatMPIAIJSetPreallocation() since advantages of DM might
> be lost.
> > > Many thanks.
> > > Sam.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151028/774ade5b/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151028/774ade5b/attachment-0001.bin>
