[petsc-users] ILU preconditioner hangs with some zero elements on the diagonal
Hong hzhang at mcs.anl.gov
Tue Oct 27 12:36:33 CDT 2015
Matt:
> On Tue, Oct 27, 2015 at 11:13 AM, Hong <hzhang at mcs.anl.gov> wrote:
>> Gary :
>> I tested your mat.bin using
>> petsc/src/ksp/ksp/examples/tutorials/ex10.c
>> ./ex10 -f0 $D/mat.bin -rhs 0 -ksp_monitor_true_residual -ksp_view
>>   Mat Object:   1 MPI processes
>>     type: seqaij
>>     rows=588, cols=588
>>     total: nonzeros=11274, allocated nonzeros=11274
>>     total number of mallocs used during MatSetValues calls =0
>>       using I-node routines: found 291 nodes, limit used is 5
>> Number of iterations =   0
>> Residual norm 24.2487
>> It does not converge, neither hangs.
This is the default GMRES/ILU.
Hong
> As you said, matrix is non-singular, LU gives a solution
>> ./ex10 -f0 $D/mat.bin -rhs 0 -ksp_monitor_true_residual -pc_type lu
>>   0 KSP preconditioned resid norm 3.298891225772e+03 true resid norm
>> 2.424871130596e+01 ||r(i)||/||b|| 1.000000000000e+00
>>   1 KSP preconditioned resid norm 1.918157196467e-12 true resid norm
>> 5.039404549028e-13 ||r(i)||/||b|| 2.078215409241e-14
>> Number of iterations =   1
>>   Residual norm < 1.e-12
>> Is this the same matrix as you mentioned?
> Hong, could you run ILU on it as well?
>   Thanks,
>     Matt
>> Hong
>>> On Tue, Oct 27, 2015 at 9:10 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Tue, Oct 27, 2015 at 9:06 AM, Gary Rebt <gary.rebt at gmx.ch[
>>> gary.rebt at gmx.ch]> wrote:
>>> Dear petsc-users,
>>> While using the FEniCS package to Solve a simple Stokes' flow problem, I
>>> have run into problems with PETSc preconditioners. In particular, I would
>>> like to use ILU (no parallel version) along with GMRES to solve my linear
>>> system but the solver just hangs indefinitely
>>> at MatLUFactorNumeric_SeqAIJ_Inode without outputting anything. CPU usage
>>> is at 100% but even for a tiny system (59x59 for minimal test case), the
>>> solver does not seem to manage to push through it after 30 mins.
>>> PETSc version is 3.6 and the matrix for the minimal test case is as
>>> follows :
>>> http://pastebin.com/t3fvdkaS[http://pastebin.com/t3fvdkaS]
>>> Hanging is a bug. We will check it out.
>>> I do not have any way to read in this ASCII. Can you output a binary
>>> version
>>>   -mat_view binary:mat.bin
>>>   Thanks,
>>>      Matt
>>> It contains zero diagonal entries, has a condition number of around 1e3
>>> but is definitely non-singular. Direct solvers manage to solve the system
>>> as well as GMRES without preconditioner (although after many iterations for
>>> a 59x59 system..).
>>> This will never work. Direct solvers work because they pivot away the
>>> zeros, but ILU is defined by having no pivoting.
>>>   Thanks,
>>>      Matt
>>> Playing with the available options here
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCILU.html[http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCILU.html]
>>> did not seem to solve the issue (even after activating diagonal_fill and/or
>>> nonzeros_along_diagonal) although sometimes error 71 is returned which
>>> stands for zero pivot detected. Are there yet other options that I have not
>>> considered? The default ILU factorization in MATLAB returns satisfactory
>>> problems without errors so surely it must be possible with PETSc?
>>> As for the choice of ILU, I agree it might be suboptimal in this setting
>>> but I do need it for benchmarking purposes.
>>> Best regards,
>>> Gary
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151027/094fd314/attachment.html>
