[petsc-users] PetscBool in PETSc 3.1? (Ubuntu Precice)
Dominic Meiser dmeiser at txcorp.com
Mon Oct 26 10:04:24 CDT 2015
On 10/25/2015 10:40 AM, Florian Lindner wrote:
> Hello,
> our build system Travis uses the old Ubuntu Precice Pangolin version that comes with PETSc 3.1.
FWIW petsc master or maint build relatively quickly on travis' build
machines (2-5 minutes depending on how many third party packages you
need). If you're able to use travis' containerized infrastructure you
can cache the PETSc builds reducing the PETSc build times to near 0.
I've done that for a couple of my projects and it turned out to be
really easy, see for example here:
https://github.com/d-meiser/SuperContinuum
Have a look at .travis.yml and utilities/get_petsc.sh.
Cheers,
Dominic
> While trying to activate petsc for our CI tests, I get the message that the type PetscBool wasn't found. I downloaded http://packages.ubuntu.com/precise/libpetsc3.1-dev and grepped for PetscBool, found non.
> Just to make sure I didn't screw it up, is it true, that there is no PetscBool in version 3.1?
> Is there a PPA known that provides newer PETSc versions to Precice Pangolin
> Thanks,
> Florian
Dominic Meiser
Tech-X Corporation
5621 Arapahoe Avenue
Boulder, CO 80303
USA
Telephone: 303-996-2036
Fax: 303-448-7756
www.txcorp.com
