[petsc-users] DMCreateMatrix with some dense row
Dave May dave.mayhem23 at gmail.com
Sat Oct 24 01:33:26 CDT 2015
If you need to access a user defined context from within your CreateMatrix
function, you can attach it to the DM via PetscObjectCompose
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscObjectCompose.html
If your context is not a petsc object, you can use PetscContainerCreate(),
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscContainerCreate.html#PetscContainerCreate
You would then set your user context pointer inside the container and then
use PetscObjectCompose() to attach the container to the DM
  Dave
On 24 October 2015 at 06:04, Sang pham van <pvsang002 at gmail.com> wrote:
> Hi Barry,
> The routine DMCreateMatrix_DA_3d_MPIAIJ has 2 input arguments (DM da, Mat
> J), the function pointer in DMDASetGetMatrix() only accept function with
> that two arguments.
> As you suggested, I am writing a routine (based on DMCreateMatrix_DA_3d_MPIAIJ())
> to preallocate the matrix in the way I wish, to do that I think It needs to
> have one more input argument: My_DMCreateMatrix_DA_3d_MPIAIJ(DM da, Mat
> J, void* my_context). But DMDASetGetMatrix() will not accept pointer of
> this function. Please give a suggestion to overcome this.
> Thank you.
> Pham
> On Fri, Sep 4, 2015 at 1:24 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>     Look at DMCreateMatrix_DA_2d_MPIAIJ  (or the 3d version if working in
>> 3d)   You need to copy this routine and add whatever additional
>> preallocation information you need.   Then call DMDASetGetMatrix()  so that
>> the DM will use your routine to create the matrix for you.
>>    Barry
>> > On Sep 3, 2015, at 11:28 AM, Sang pham van <pvsang002 at gmail.com> wrote:
>> > Hi,
>> > I am using DMCreateMatrix to create matrix from a existed DM object and
>> defined stencil.
>> > In my code, boundary nodes need to involve many inner nodes, thus
>> matrix rows corresponding to boundary nodes are almost dense. How can I
>> tell petsc that those rows need to be preallocated with more entries? I
>> don't want to use MatMPIAIJSetPreallocation() since advantages of DM might
>> be lost.
>> > Many thanks.
>> > Sam.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151024/854db5c8/attachment.html>
