[petsc-users] configuring petsc without downloading packages
Thu Oct 22 13:50:01 CDT 2015
On Thu, Oct 22, 2015 at 1:42 PM, David Liu <daveliu at mit.edu> wrote:
> Hi, I have a simple question that I could not find a comprehensive answer
> anywhere on the website or manual, though I found examples of what I'm
> trying to do. Say I want to build a version of PETSc with some external
> package, such as MUMPS or SuperLU_DIST. I can do this by using flags such
> as "--download-superlu_dist" when I am configuring. However, what if I
> already have SuperLU_DIST, say either by installing it by myself from the
> SuperLU_DIST source, or from a previous configuration of PETSc, i.e. with
> downloaded files sitting in ${PETSC_DIR}/${PETSC_ARCH}/externalpackages?
> How can I save the trouble of re-downloading a package that I already have?
> For MPI, I can specify using "--with-mpi-dir", or I can simply have mpirun
> and mpicc, etc in my path. But is there a standard way to do this for
> external packages that you usually download? I vaguely recall reading
> somewhere that you can simply do
> --download-superlu_dist=${PATH_TO_SUPERLU_DIST}
> but that notation obviously seems a little weird.
1) If you already have it in externalpackages/ it will not download it again
2) If you download the tarball yourself, then
--download-<package>=<path/to/tarball> will use it
3) If you installed the package yourself,
--with-<package>-dir=</path/to/package> will use that
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151022/add3e048/attachment.html>
