[petsc-users] on SNESSetJacobian semantics
Thu Oct 22 13:33:45 CDT 2015
> On Oct 22, 2015, at 9:20 AM, Marco Zocca <zocca.marco at gmail.com> wrote:
> The signature of SNESSetJacobian is
> PetscErrorCode  SNESSetJacobian(SNES snes,Mat Amat,Mat Pmat,PetscErrorCode (*J)(SNES,Vec,Mat,Mat,void*),void *ctx)
> however it would seem redundant to supply both a constant matrix and a function to compute the Jacobian.
> The manual says of J "(if NULL then SNES retains any previously set value": this would only apply to linear functions, is this correct?
> Why then are there not two monomorphic "SetJacobian" functions, one for linear maps that wouldn't require recomputation and one for every other case ?
  For the linear case you can just pass in a function J that simply returns without changing the matrices.
  Barry
> Coming from a functional background, I find reasoning with "NULL" to be very error-prone.
   Agreed. Limitation of C and the style of API we selected of trying to minimize the number of different functions in the interface.
> Thank you,
> Marco
