[petsc-users] on SNESSetJacobian semantics
Thu Oct 22 09:40:04 CDT 2015
On Thu, Oct 22, 2015 at 9:37 AM, Marco Zocca <zocca.marco at gmail.com> wrote:
> Thank you, but this is not really helping;
> why are there two slots to supply the Jacobian of the same function, i.e.
> Amat and J ?
Amat is just the storage, not the values. J computes the values.
   Matt
> Marco
> On 22 October 2015 at 16:30, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Oct 22, 2015 at 9:20 AM, Marco Zocca <zocca.marco at gmail.com>
>> wrote:
>>> The signature of SNESSetJacobian is
>>> PetscErrorCode  SNESSetJacobian(SNES snes,Mat Amat,Mat
>>> Pmat,PetscErrorCode (*J)(SNES,Vec,Mat,Mat,void*),void *ctx)
>>> however it would seem redundant to supply both a constant matrix and a
>>> function to compute the Jacobian.
>>> The manual says of J "(if NULL then SNES retains any previously set
>>> value": this would only apply to linear functions, is this correct?
>> It means, if you give NULL, but have previously called SetJacobian() then
>> it uses the function pointer previously passed
>> rather than setting it to NULL.
>>   Matt
>>> Why then are there not two monomorphic "SetJacobian" functions, one for
>>> linear maps that wouldn't require recomputation and one for every other
>>> case ?
>>> Coming from a functional background, I find reasoning with "NULL" to be
>>> very error-prone.
>>> Thank you,
>>> Marco
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151022/d22dd167/attachment.html>
