[petsc-users] HDF5 vec output with DMPlex
Adrian Croucher a.croucher at auckland.ac.nz
Thu Oct 15 23:14:53 CDT 2015
hi
On 16/10/15 16:54, Matthew Knepley wrote:
> No, that should work. This is how we do it in PyLith. There must be
> some setup problem. When you look at the HDF5 file. Does
> it have a dimension for timestep?
No, it doesn't.
Is there any extra setup I might need to do to get it to work? I've
attached a minimal example code, mesh and output.
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 84611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151016/84978acb/attachment-0001.html>
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151016/84978acb/attachment-0001.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151016/84978acb/attachment-0001.obj>
Type: application/x-hdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151016/84978acb/attachment-0001.hdf>
