[petsc-users] Number of levels of multigrid : 2-3 is sufficient ??
Timothée Nicolas timothee.nicolas at gmail.com
Wed Oct 14 21:32:20 CDT 2015
Thank you Barry for pointing this out. Indeed on a system with no debugging
the Jacobian evaluations no longer dominate the time (less than 10%).
However the rest is similar, except the improvement from 2 to 3 levels is
much better. Still it saturates after levels=3. I understand it in terms of
CPU time thanks to Matthew's explanations, however what surprises me more
is that KSP iterations are not more efficient. At the least, even if it
takes more time to have more levels because of memory issues, I would
expect KSP iterations to converge more rapidly with more levels, but it is
not the case as you can see. Probably there is also a rationale behind this
but I cannot see easily.
I send the new outputs
Best
Timothee
2015-10-15 3:02 GMT+09:00 Barry Smith <bsmith at mcs.anl.gov>:
> 1) Your timings are meaningless! You cannot compare timings when built
> with all debugging on, PERIOD!
>       #                          WARNING!!!                    #
>       #   This code was compiled with a debugging option,      #
>       #   To get timing results run ./configure                #
>       #   using --with-debugging=no, the performance will      #
>       #   be generally two or three times faster.              #
> 2) Please run with -snes_view .
> 3) Note that with 7 levels
> SNESJacobianEval      21 1.0 2.4364e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 54  0  0  0  0  54  0  0  0  0     0
> with 2 levels
> SNESJacobianEval       6 1.0 2.2441e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 34  0  0  0  0  34  0  0  0  0     0
> The Jacobian evaluation is dominating the time! Likely if you fix the
> debugging this will be less the case
>   Barry
> > On Oct 13, 2015, at 9:23 PM, Timothée Nicolas <
> timothee.nicolas at gmail.com> wrote:
> > Dear all,
> > I have been playing around with multigrid recently, namely with
> /ksp/ksp/examples/tutorials/ex42.c, with /snes/examples/tutorial/ex5.c and
> with my own implementation of a laplacian type problem. In all cases, I
> have noted no improvement whatsoever in the performance, whether in CPU
> time or KSP iteration, by varying the number of levels of the multigrid
> solver. As an example, I have attached the log_summary for ex5.c with
> nlevels = 2 to 7, launched by
> > mpiexec -n 1 ./ex5 -da_grid_x 21 -da_grid_y 21 -ksp_rtol 1.0e-9
> -da_refine 6 -pc_type mg -pc_mg_levels # -snes_monitor -ksp_monitor
> -log_summary
> > where -pc_mg_levels is set to a number between 2 and 7.
> > So there is a noticeable CPU time improvement from 2 levels to 3 levels
> (30%), and then no improvement whatsoever. I am surprised because with 6
> levels of refinement of the DMDA the fine grid has more than 1200 points so
> with 3 levels the coarse grid still has more than 300 points which is still
> pretty large (I assume the ratio between grids is 2). I am wondering how
> the coarse solver efficiently solves the problem on the coarse grid with
> such a large number of points ? Given the principle of multigrid which is
> to erase the smooth part of the error with relaxation methods, which are
> usually efficient only for high frequency, I would expect optimal
> performance when the coarse grid is basically just a few points in each
> direction. Does anyone know why the performance saturates at low number of
> levels ? Basically what happens internally seems to be quite different from
> what I would expect...
> > Best
> > Timothee
> <ex5_2_levels_of_multigrid.log><ex5_3_levels_of_multigrid.log><ex5_4_levels_of_multigrid.log><ex5_5_levels_of_multigrid.log><ex5_6_levels_of_multigrid.log><ex5_7_levels_of_multigrid.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151015/caad9909/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151015/caad9909/attachment-0006.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151015/caad9909/attachment-0007.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151015/caad9909/attachment-0008.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151015/caad9909/attachment-0009.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151015/caad9909/attachment-0010.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151015/caad9909/attachment-0011.obj>
