[petsc-users] Number of levels of multigrid : 2-3 is sufficient ??
Wed Oct 14 10:02:35 CDT 2015
On Wed, Oct 14, 2015 at 10:01 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> On 14 October 2015 at 16:50, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Oct 14, 2015 at 7:34 AM, Timothée Nicolas <
>> timothee.nicolas at gmail.com> wrote:
>>> OK, I see. Does it mean that the coarse grid solver is by default set up
>>> with the options -ksp_type preonly -pc_type lu ? What about the
>>> multiprocessor case ?
>> Small scale: We use redundant LU
>> Large Scale: We use GAMG
> Is your answer what "you" recommend, or what PETSc does by default?
> Your answer gives the impression that PETSc makes a decision regarding the
> choice of either redundant/LU or gamg based on something - e.g. the size of
> the matrix, the number of cores (or some combination of the two).
> Is that really what is happening inside PCMG?
No, the default is redundant LU, and then you can decide to use GAMG.
   Matt
>>    Matt
>>> Thx
>>> Timothee
>>> 2015-10-14 21:22 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>> On Tue, Oct 13, 2015 at 9:23 PM, Timothée Nicolas <
>>>>> Dear all,
>>>>> I have been playing around with multigrid recently, namely with
>>>>> /ksp/ksp/examples/tutorials/ex42.c, with /snes/examples/tutorial/ex5.c and
>>>>> with my own implementation of a laplacian type problem. In all cases, I
>>>>> have noted no improvement whatsoever in the performance, whether in CPU
>>>>> time or KSP iteration, by varying the number of levels of the multigrid
>>>>> solver. As an example, I have attached the log_summary for ex5.c with
>>>>> nlevels = 2 to 7, launched by
>>>>> mpiexec -n 1 ./ex5 -da_grid_x 21 -da_grid_y 21 -ksp_rtol 1.0e-9
>>>>> -da_refine 6 -pc_type mg -pc_mg_levels # -snes_monitor -ksp_monitor
>>>>> -log_summary
>>>>> where -pc_mg_levels is set to a number between 2 and 7.
>>>>> So there is a noticeable CPU time improvement from 2 levels to 3
>>>>> levels (30%), and then no improvement whatsoever. I am surprised because
>>>>> with 6 levels of refinement of the DMDA the fine grid has more than 1200
>>>>> points so with 3 levels the coarse grid still has more than 300 points
>>>>> which is still pretty large (I assume the ratio between grids is 2). I am
>>>>> wondering how the coarse solver efficiently solves the problem on the
>>>>> coarse grid with such a large number of points ? Given the principle of
>>>>> multigrid which is to erase the smooth part of the error with relaxation
>>>>> methods, which are usually efficient only for high frequency, I would
>>>>> expect optimal performance when the coarse grid is basically just a few
>>>>> points in each direction. Does anyone know why the performance saturates at
>>>>> low number of levels ? Basically what happens internally seems to be quite
>>>>> different from what I would expect...
>>>> A performance model that counts only flops is not sophisticated enough
>>>> to understand this effect. Unfortunately, nearly all MG
>>>> books/papers use this model. What we need is a model that incorporates
>>>> memory bandwidth (for pulling down the values), and
>>>> also maybe memory latency. For instance, your relaxation pulls down all
>>>> the values and makes a little progress. It does few flops,
>>>> but lots of memory access. An LU solve does a little memory access,
>>>> many more flops, but makes a lots more progress. If memory
>>>> access is more expensive, then we have a tradeoff, and can understand
>>>> using a coarse grid which is not just a few points.
>>>>   Thanks,
>>>>      Matt
>>>>> Best
>>>>> Timothee
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151014/5b2a3984/attachment-0001.html>
