[petsc-users] petsc cmake config - BUILD_SHARED_LIBS
Tue Oct 13 11:13:21 CDT 2015
Jed might have better suggestion [wrt cmake code and petsc]
You might have to explain why you can't use FindPETSc.cmake - and need
PETScConfig.cmake.
Satish
On Tue, 13 Oct 2015, Arne Morten Kvarving wrote:
> Right. Then I will keep patching as there is no other easy way to use petsc in a portable way. Too many defines used in too many headers for me to do bother writing my own find rule.
> Thanks for your answers.
> -------- Opprinnelig melding --------
> Fra: Satish Balay <balay at mcs.anl.gov>
> Dato: 13.10.2015 17.53 (GMT+01:00)
> Til: Arne Morten Kvarving <Arne.Morten.Kvarving at sintef.no>
> Ko: petsc-users <petsc-users at mcs.anl.gov>
> Emne: Re: [petsc-users] petsc cmake config - BUILD_SHARED_LIBS
> As mentioned - PETScConfig.cmake is primarily for building PETSc - and
> not equivalent to .pc file
> It gets used when 'make all-cmake' is used instead of the default
> 'make all' to build petsc libraries.
> [This mode is deprecated - and not properly tested - and I see its currenty broken]
> Jed had a tool FindPETSc.cmake - which is a tool for the user to
> detect petsc config via cmake.
> https://github.com/jedbrown/cmake-modules/
> Is this what you are using?
> Satish
> > Yes I am aware and i can reset and such.
> > This is about the why, not the how. The config file has nothing to do with the petsc build system, it is for users of petsc, like a .pc file (pkgconfig).
> > The code in question builds a number of convenience libraries for shared code between multiple apps. I want these static at times but in general shared for installs. This I control using the intended cmake mechanism - namely the BUILD_SHARED_LIBS variable. Petsc breaks this since it overrides the value passed by the user.
> > I would rather avoid hacking my buildsystem to workaround petsc bugs. Right now i need to deploy a patched petsc everywhere for this reason - to remove the useless variable writing in the cmake config file. Because as you say shared libs should normally be used.
> > Dato: 13.10.2015 16.56 (GMT+01:00)
> > Ko: petsc-users at mcs.anl.gov
> > Well the current code has the option of building petsc via cmake [but
> > this mode is deprecated - and the default build uses straight gnumake]
> > So if you configure PETSc with --shared-libraries=1 [default] - this
> > flag is set in conf/PETScConfig.cmake
> > So you can rebuild petc with --shared-libraries=0 - and this flag will
> > go away.
> > BTW: I'm not sure why this affects your application. [as applications
> > don't build libraries]. Or is it that you have a library that builds
> > over PETSc?
> > [in this case - it generally makes sense to build it as shared anyway]
> > Also - I'm guessing - there must be a way for you to reset this variable in
> > your cmake config - if thats whats requred by your app.
> > Jed should be able to confirm..
> > Satish
> > > hi there;
> > > why does the cmake config file set the BUILD_SHARED_LIBS variable? this
> > > affects all buildsystem where the config file is included, and has 0 effect on
> > > the actual petsc side of things.
> > > i don't see why petsc should decided whether i want to use static libraries in
> > > my application or not.
> > > i can keep hacking around it, or supply a patch to get rid of it. but i
> > > figured i'd ask for the reasoning first.
> > > if this should have gone to -dev, i'm sorry. i thought it fit better here.
> > > arnem
