[petsc-users] Compute initial guess multiple times
Fri Oct 9 14:06:52 CDT 2015
> On Oct 9, 2015, at 1:58 PM, Leonardi Filippo <filippo.leonardi at sam.math.ethz.ch> wrote:
> Actually I used to use KSPSolve directly, then I've started using KSPSetCompute... because (if I remember correctly) (as you mention) I wanted KSPComputeMatrix to compute all the coarse matrices for me.
> Now I switched to completely use algebraic multigrid or galerkin computed matrices, so I can revert back to use the KSPSolve directly, but, for testing purposes, it may be good to keep being able to use PCMG.
> My question now is: can I use SetComputeMatrix() and then call KSPSolve(ksp,b,x)? (I forgot if i need to use b,x = NULL or not when using the compute matrix routine.)
   What about providing the ComputeMatrix() but NOT the computerrhs or computeinitialguess?  Make sure to call KSPSetInitialGuessNonzero() so KSP doesn't zero out the x you pass in).
  Barry
> Da: Barry Smith [bsmith at mcs.anl.gov]
> Inviato: venerdì 9 ottobre 2015 20.49
> A: Leonardi  Filippo
> Cc: petsc-users at mcs.anl.gov
> Oggetto: Re: [petsc-users] Compute initial guess multiple times
>  The current model is a bit wonky.
>    At the first call to KSPSolve after a call to KSPSetComputeOperators the computematrix, computerhs, and computeinitialguess are called.
>    In subsequent calls to KSPSolve ONLY the computerhs is called.
>    So for example
>      KSPSetComputeOperators()
>      KSPSolve   -- computematrix, rhs, initial guess called
>      KSPSolve  --- computerhs called
>      KSPSetComputerOperators()
>   Note that the KSPSetCompute...() functions are just one particular way of using KSP.  You can also use the "standard" interface
>     Set values into matrix and rhs and initial guess (call KSPSetInitialGuessNonzero)
>     KSPSolve(ksp,b,x)
>     change values in b, this would use the current values in x as the initial guess for the next solve
>     KSPSolve(ksp,b,x)
>     change values in b and x
>     KSPSolve()
>     Change values in matrix and b and x (for initial guess)
>     KSPSolve()
>    This gives you exact detailed control over when and what you set in initial guesses.
>    Is there a particular reason for your problem that it is better to use the KSPSetCompute...() interface?
>   Barry
>  Note I wrote the KSPSetCompute...() interface so that PCMG could "build its own" coarse grid matrix values without the user needing to set values for all the levels before calling KSPSolve.
>> On Oct 9, 2015, at 5:04 AM, Filippo Leonardi <filippo.leonardi at sam.math.ethz.ch> wrote:
>> So, I want to solve a system Ax = b multiple times, reuse A with different bs.
>> It is natural to set differents initial guesses each time for iterative
>> solvers.
>> And
>> KSPSetComputeInitialGuess(ksp,ComputeGuess,&user);
>> is what PETSc provide for setting the Guess.
>> I am unsure if I am making something wrong, but it seems to me that this
>> function is called only once the matrix is first setted up. I want to be
>> called each time.
>> See my modified ex32.c for comparison.
>> ./ex32 -pc_type mg -pc_mg_type full -ksp_type fgmres -ksp_monitor_short -
>> pc_mg_levels 3 -mg_coarse_pc_factor_shift_type nonzero -
>> ksp_initial_guess_nonzero
>> Thanks.
>> Best,
>> Filippo<ex32.c>
