[petsc-users] user defined algorithm for newton solver
Michael Povolotskyi mpovolot at purdue.edu
Thu Oct 8 12:26:16 CDT 2015
Dear Petsc developers and users,
I'm solving a nonlinear system with PETSc.
Often simple Newton iterations do not work and I have to use either
linear search or trust region.
I would like to use my own algorithm to find a next iteration
approximation to solution if the Newton step does not improve the
residual. As far as I can see I have to define my own SNELLineSearch
object. Is there any example that shows how to do it?
Thank you,
Michael.
Michael Povolotskyi, PhD
Research Assistant Professor
Network for Computational Nanotechnology
Hall for Discover and Learning Research, Room 441
West Lafayette, IN 47907
Phone (765) 4949396
