[petsc-users] petsc error RE pc_mg_levels usage
Boris borisbou at buffalo.edu
Wed Oct 7 18:04:14 CDT 2015
Hello,
I am working on a toy Laplace problem (p1.C attached) investigating some
multigrid projection matrices when using finite differences. Things seem
to work as expected when running with :
./p1 -da_grid_x 21 -da_grid_y 21 -mat_view -pc_type mg -pc_mg_levels 1
But if I change pc_mg_levels to 2 or 3, I generate the error below.
Any insights as to what I could be doing wrong would be much appreciated.
Boris
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: Local index 169 too large 168 (max) at 4
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
[0]PETSC ERROR: ./p1 on a gcc-4.8.4-mpich-3.1.4-openblas-0.2.14-opt
named bender.eng.buffalo.edu by borisbou Wed Oct  7 18:06:35 2015
[0]PETSC ERROR: Configure options
--prefix=/bender1/data/shared/software/libs/petsc/3.5.4/gcc/4.8.4/mpich/3.1.4/openblas/0.2.14/opt
--with-debugging=false --COPTFLAGS="-O3 -mavx" --CXXOPTFLAGS="-O3 -mavx"
--FOPTFLAGS=-O3 --with-shared-libraries=1
--with-mpi-dir=/bender1/data/shared/software/libs/mpich/3.1.4/gcc/4.8.4
--with-mumps=true --download-mumps=1 --with-metis=true
--download-metis=1 --with-parmetis=true --download-parmetis=1
--with-superlu=true --download-superlu=1 --with-superludir=true
--download-superlu_dist=1 --with-blacs=true --download-blacs=1
--with-scalapack=true --download-scalapack=1 --with-hypre=true
--download-hypre=1
--with-blas-lib="[/bender1/data/shared/software/libs/openblas/0.2.14/gcc/4.8.4/lib/libopenblas.so]"
--with-lapack-lib="[/bender1/data/shared/software/libs/openblas/0.2.14/gcc/4.8.4/lib/libopenblas.so]"
[0]PETSC ERROR: #1 ISLocalToGlobalMappingApply() line 401 in
/bender1/data/shared/software/builddir/petsc-1HCwjW/petsc-3.5.4/src/vec/is/utils/isltog.c
[0]PETSC ERROR: #2 MatSetValuesLocal() line 1982 in
/bender1/data/shared/software/builddir/petsc-1HCwjW/petsc-3.5.4/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 MatSetValuesStencil() line 1383 in
[0]PETSC ERROR: #4 FormJacobian() line 366 in p1.C
[0]PETSC ERROR: #5 SNESComputeJacobian() line 2193 in
/bender1/data/shared/software/builddir/petsc-1HCwjW/petsc-3.5.4/src/snes/interface/snes.c
[0]PETSC ERROR: #6 KSPComputeOperators_SNES() line 527 in
[0]PETSC ERROR: #7 KSPSetUp() line 256 in
/bender1/data/shared/software/builddir/petsc-1HCwjW/petsc-3.5.4/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #8 PCSetUp_MG() line 803 in
/bender1/data/shared/software/builddir/petsc-1HCwjW/petsc-3.5.4/src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: #9 PCSetUp() line 902 in
/bender1/data/shared/software/builddir/petsc-1HCwjW/petsc-3.5.4/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #10 KSPSetUp() line 306 in
[0]PETSC ERROR: #11 KSPSolve() line 418 in
[0]PETSC ERROR: #12 SNESSolve_NEWTONLS() line 232 in
/bender1/data/shared/software/builddir/petsc-1HCwjW/petsc-3.5.4/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #13 SNESSolve() line 3743 in
[0]PETSC ERROR: #14 main() line 147 in p1.C
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 63) - process 0
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151007/3ab85d3a/attachment.c>
