[petsc-users] A question on finite difference Jacobian
Jed Brown jed at jedbrown.org
Tue Oct 6 15:33:31 CDT 2015
"Zou (Non-US), Ling" <ling.zou at inl.gov> writes:
> Hi All,
> If the non-zero pattern of a finite difference Jacobian needs 20 colors to
> color it (20 comes from MatFDColoringView, the non-zero pattern is
> pre-determined from mesh connectivity), is it true that PETSc needs 40
> functions evaluation to get the full Jacobian matrix filled? This is
> because that a perturbation per color needs two function evaluation
> according to PETSc manual (ver 3.6, page 123, equations shown in the middle
> of the page).
Note that F(u) has already been evaluated and is the same for all the
perturbation directions.  A centered difference would require two
evaluations per direction, as you say.
> But I only see 20 function evaluations. I probably have some
> misunderstanding somewhere. Any suggestions?
> Ling
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151006/48b38ee3/attachment.pgp>
