[petsc-users] DMPlex: Ghost points after DMRefine
Morten Nobel-Jørgensen mono at mek.dtu.dk
Mon Nov 30 07:01:49 CST 2015
I have a very simple unstructured mesh composed of two triangles (four vertices) with one shared edge using a DMPlex:
After distributing this mesh to two processes, each process owns a triangle. However one process owns tree vertices, while the last vertex is owned by the other process.
The problem occurs after uniformly refining the dm. The mesh now looks like this:
The new center vertex is now not listed as a ghost vertex but instead exists as two individual points.
Is there any way that this new center vertex could be created as a ghost vertex during refinement?
Kind regards,
Morten
Ps. Here are some code snippets for getting global point index and test of point is a ghost point:
int localToGlobal(DM dm, PetscInt point){
    const PetscInt* array;
    ISLocalToGlobalMapping ltogm;
    DMGetLocalToGlobalMapping(dm,&ltogm);
    ISLocalToGlobalMappingGetIndices(ltogm, &array);
    PetscInt res = array[point];
    if (res < 0){ // if ghost
        res = -res +1;
    return res;
bool isGhost(DM dm, PetscInt point){
    return array[point]<0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151130/52d239a8/attachment.html>
