[petsc-users] Error configuring PETSc with SUNDIALS (to solve stiff PDE)
Sun Nov 29 11:56:52 CST 2015
On Sun, Nov 29, 2015 at 11:50 AM, namu patel <namu.patel7 at gmail.com> wrote:
> Attached is my configuration log file.
Satish, the idiotic Sundials configure cannot find mpicc even when its
passed in as the C compiler:
MPI-C Settings
checking if using MPI-C script... yes
checking if absolute path to mpicc was given... no
checking for mpicc... none
   Unable to find a functional MPI-C compiler.
   Try using --with-mpicc to specify a MPI-C compiler script,
   --with-mpi-incdir, --with-mpi-libdir and --with-mpi-libs
   to specify the locations of all relevant MPI files, or
   --with-mpi-root to specify the base installation directory
   of the MPI implementation to be used.
   Disabling the parallel NVECTOR module and all parallel examples...
Do we have to give -with-mpicc as an argument?
     Matt
> Thanks,
> Namu
> On Sun, Nov 29, 2015 at 11:48 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> You must send configure.log
>>   Thanks,
>>     Matt
>> On Sun, Nov 29, 2015 at 11:42 AM, namu patel <namu.patel7 at gmail.com>
>> wrote:
>>> Hello All,
>>> I was trying to configure PETSc with SUNDIALS so that I may use PVODE to
>>> solve a stiff hyperbolic PDE of the form
>>> A(x) u_tt = K [B(x) u_x - F(x, u, u_x, t)]_x ,  t > 0,  0 < x < L ,
>>> u_x(0, t) = u_x(L, t) = 0 ,
>>> u(x, 0) = u_t(x, 0) = 0 ,
>>> where K >> 1. I was reading around to see what may be a good numerical
>>> implementation for such a problem and it can be tricky here because the
>>> stiffness is both in the linear part and the nonlinear forcing term.
>>> I want to try PVODE availble in the SUNDIALS package. When I try to
>>> configure PETSc with SUNDIALS, I get the message:
>>> Downloaded sundials could not be used. Please check install in
>>> /Users/namupatel/Softwares/PETSc/3.6.2/linux-dbg
>>>   File "./config/configure.py", line 363, in petsc_configure
>>>     framework.configure(out = sys.stdout)
>>>   File
>>> "/Users/namupatel/Softwares/PETSc/3.6.2/config/BuildSystem/config/framework.py",
>>> line 1081, in configure
>>>     self.processChildren()
>>>   File
>>> line 1070, in processChildren
>>>     self.serialEvaluation(self.childGraph)
>>>   File
>>> line 1051, in serialEvaluation
>>>     child.configure()
>>>   File
>>> "/Users/namupatel/Softwares/PETSc/3.6.2/config/BuildSystem/config/package.py",
>>> line 677, in configure
>>>     self.executeTest(self.configureLibrary)
>>>   File
>>> "/Users/namupatel/Softwares/PETSc/3.6.2/config/BuildSystem/config/base.py",
>>> line 126, in executeTest
>>>     ret = test(*args,**kargs)
>>>   File
>>> line 592, in configureLibrary
>>>     for location, directory, lib, incl in self.generateGuesses():
>>>   File
>>> line 332, in generateGuesses
>>>     raise RuntimeError('Downloaded '+self.package+' could not be used.
>>> Please check install in '+d+'\n')
>>> Two questions:
>>> 1. How can I resolve the above error?
>>> 2. Are there any recommendations to solving the stiff PDE stated above
>>> so that I can experiment to see what may be an efficient implementation?
>>> Thank you,
>>> Namu
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151129/9ff3be02/attachment.html>
