[petsc-users] .pc file does not include dependencies
Fri Nov 27 09:25:31 CST 2015
On Fri, 27 Nov 2015, Arne Morten Kvarving wrote:
> On 25/11/15 20:29, Satish Balay wrote:
> > On Wed, 25 Nov 2015, Satish Balay wrote:
> > > I'll check why libs are listed as libfoo.a instead of -lfoo in this file.
> > Ok - the following patch should fix the issue. Could you try it out?
> sorry for the late response, time zone differences and out-of-officing.
> it works just fine. thanks a lot satish. hopefully this can land and there's a
> 3.6.3 not too far the line =)
Yes - the patch is now in 'maint' branch - and will be in 3.6.3 patch update.
Satish
